Dirty WAV - is it possible to fix?
having trouble with an archived file? post in here!
MolMagMan
Post by MolMagMan »
I'm trying to archive "Yes Prime Minister" (it's probably already done somewhere but I'm experimenting).
I've tried recording the WAV file a couple of times now but I think the tape is damaged.
As can be seen from the screenshot, blocks 1, 2, 3 and 4 are very messy. There are some other areas in the wav which are similar - basically there are about 10 blocks which fail to convert to UEF. It's a shame because the rest of the tape seems really clean :(
The wav files are here ... https://drive.google.com/file/d/1l-5C7H ... sp=sharing
Is there any way to fix this?
Thank you :)
Re: Dirty WAV - is it possible to fix?
Post by BigEd »
I had a quick go with Audacity - see if the three blocks in the attached are any better.
(I did the same thing I did here.)
yes_prime_minister_days_1_2-fix.wav.zip
(892.05 KiB) Downloaded 10 times
MolMagMan
Post by MolMagMan »
Thanks BigEd :)
I get this when I import it into Audacity...
...and "WAV file not 8 bit" when I run it through makeuefam.
However - I equalised the original file as per your instructions, exported as unsigned 8bit pcm and it converted successfully - yay!
However - it doesn't load in b-em - boo :(
BigEd wrote:
Wed Dec 30, 2020 10:55 pm
Post by BigEd »
Ah, we must be a bit closer then... can you tell which block is bad when you load it?
mad
Post by mad »
Fixing a corrupt /dirty WAV is almost impossible with a Machine Code data program.
zooming in and redrawing the wav peek has helped me in the past, where the volume had dropped out.
But i think that was more blind luck than skill. ;)
When the program is written in BASIC.
it is easier to spot the odd corrupt converted byte in the listing.
Anyway here is a working version, so you can hex compare your test results.
yes pm.zip
(154.98 KiB) Downloaded 6 times
vanekp
Post by vanekp »
There is some strange sound in that recording I don't be-leave it will ever be readable with the interference that is in there. if a wave has drop out or interference like this the changes are very small you will ever make a working uef from it.
Peter.
Return to “archive issues”
