Help archiving MIDI software
having trouble with an archived file? post in here!
courseddent
Post by courseddent » Wed Nov 20, 2019 3:17 pm
I've got a copy of EMR MIDI Track Performer v2 on 5.25" floppy. I'd like to get it archived, and access to it as an .ssd - there are archived versions of this around but they are all pre-v2 as far as I can tell. I can't do this as my floppy drive has broken, so was wondering if there was anyone that could help me with this? I'm in Bristol so even better if there's anyone around here. Happy to contribute towards any costs.
Thanks!
Re: Help archiving MIDI software
Post by flaxcottage » Wed Nov 20, 2019 4:43 pm
I could do this if you wish. I have already worked out the EMR disc protection.
No cost for cracking the disc - just P&P. :D
billcarr2005 here can also archive the discs so between us there should be no problem making a working SSD file.
Do you have the documentation as well?
courseddent
Post by courseddent » Wed Nov 20, 2019 4:53 pm
That's brilliant! Yes have all documentation etc. Can you PM me the address etc?
billcarr2005
Post by billcarr2005 » Wed Nov 27, 2019 8:01 pm
Has this been sent / received / archived yet? [-o<
Post by flaxcottage » Wed Nov 27, 2019 8:20 pm
The MIDI Tracker Performer has just been archived and can be downloaded from the educational archive website below. :D
The protection was interesting and a variant on a previous EMR title I had archived. The smallest change necessary was made to allow the title to be archived and this is documented on the website.
Although the SSD seems to work correctly I cannot fully confirm this without access to a working MIDI interface and MIDI instrument.
It is interesting that EMR does not use Shift-Break to start its titles. They use a command *EMR instead to run a file from disk.
Post by CMcDougall » Wed Nov 27, 2019 9:04 pm
so it's here : http://www.flaxcottage.com/Educational/ ... wnload.zip
EMR does not use Shift-Break to start its titles. They use a command *EMR instead to run a file from disC
so, just rename file EMR to !BOOT , then *OPT 4 2 8)
John, the other new one : Nuclear Reactor Simulation -longman1985
does not have a SSD within DL , just pics & manual.... :-s
Post by flaxcottage » Wed Nov 27, 2019 10:37 pm
Of course one could rename but then the copy would not be 'authentic'. :lol:
It just seemed strange that they did it that way.
Thanks for the heads up about the Nuclear Simulation. I've added the SSD now. No idea what happened there. Maybe I am getting old. :wink:
Post by danielj » Thu Nov 28, 2019 7:06 am
:D if we want to stay authentic we should be distributing HFEv3 files that keep the copy protection intact (and run on the gotek). Actually, facetiousness aside, I think from a preservation perspective this would be a really good thing (especially as many people are using goteks now, and greaseweazle can help make the files at a very low price).
Post by flaxcottage » Thu Nov 28, 2019 9:13 am
Oh, no! Not another standard for me understand. I have only just got used to SSD. #-o :shock: :lol:
Post by danielj » Thu Nov 28, 2019 9:25 am
:lol: the beauty of HFE is that there is no need to understand it! Consider it a photocopy of the disk surface :D
billcarr2005
Post by billcarr2005 » Thu Nov 28, 2019 1:49 pm
The "problem" with any low level files is that they strive to make disk images *seem* more complicated than they genuinely are :roll:
I'm not sure that the protection was removed, ie where memory location &95 was set to &1A
9EE OSW7F 9DA		Check protection
9F2 LDA #7F ; STA 95
9F9 LDA #0 ; CMP 9E4 ; BNE A04
A00 LDA #1A ; STA 95
A04 LDA #16 ; JSR OSWRCH
When the loading is finished, &95 currently contains &7F, which will trip up the code here
7309 LDA 95
730B CMP #1A
730D BNE 7309
I've removed the reliance on OSWORD&7F to load the data directly and saved off the necessary files
The only difference I can see between the v1.25 on a disk I have and v2.00 is the added functionality of setting up for other flavours of BBC machines (in PERFORM) which changes the locations for the primary interrupt vector.
MIDITRACK PERFORMER V2.00.zip
* Fully cracked! * ;)
(23.56 KiB) Downloaded 29 times
Post by flaxcottage » Thu Nov 28, 2019 2:06 pm
7309 LDA 95
730B CMP #1A
730D BNE 7309
Aaargh! You are quite correct. I HAD edited the code at &9EE to contain JMP &A00 which bypassed the protection checking and left &1A in location &95 but I forgot to save the changes. :oops:
When I checked the SSD version the code ran up to the MIDI Tracker screen and I could get no further since, I assume, the hardware was missing. With the change made the software runs just as it did before, which is weird.
Thanks for the other work done on the title. It was on my 'to-do' list but that is very long these days. :lol:
billcarr2005
Post by billcarr2005 » Thu Nov 28, 2019 2:36 pm
If the program is run and DEMO1 loaded up, then P to PLAY, you'll find that the SPACE BAR will never allow you to exit.
It's a more subtle, passive protection that might only be discovered after creating your magnum opus
Post by jgharston » Thu Nov 28, 2019 6:46 pm
Which is broken as it throws essentially random numbers around instead of reading the actual default vector from the actual default vector table pointed to by the actual default vector table vector.
billcarr2005
Post by billcarr2005 » Fri Nov 29, 2019 4:30 am
If the "essentially random numbers" happily coincide with the actual numbers, then I suppose it would work as the original authors had intended, in as far as they had originally tested it, when producing the software package?
(Also, the BASIC program doesn't PRINT "Setting up for the " when MASTER COMPACT is selected either - this appears to be the incorrect one, should be &E618 - or whatever would be read at the time, obviously? Master 128 presumably just caters for MOS3.20)
Return to “archive issues”
