A simple text adventure: MoonBase Escape
development and releases of new/rewritten text adventures
LordVaderUK
Post by LordVaderUK » Thu Apr 23, 2020 8:15 pm
As demo'ed this evening on the virtual ABUG, I've attached a disk image for my text adventure, MoonBase Escape.
Don't expect the new Zork, it's a relatively simple game, with a few puzzles to solve. I haven't yet been able to test it on real hardware, but it seems pretty happy on the B2 emulator. The only person who has played it is me - so there are surely still some bugs and issues in there that I've not yet found!
Please feel free to have a go, if you break it please let me know so I can fix the bugs :wink:
MOONBASE.ssd
(200 KiB) Downloaded 17 times
Loving my BBC Master 128
dp11
Re: A simple text adventure: MoonBase Escape
Post by dp11 » Thu Apr 23, 2020 9:37 pm
Running through ABE saves about 5K and makes it run faster.
Post by leenew » Thu Apr 23, 2020 9:47 pm
Perfect!
In the age old tradition of text adventures... one screen says Moonbase escape, and the other says Escape from moonbase. :roll:
Love it!
(I will add it to my list of things to play asap).
Lee
Post by lurkio » Thu Apr 23, 2020 9:48 pm
Heh. That's my line!
:wink:
Post by CMcDougall » Thu Apr 23, 2020 10:07 pm
& makes it run faster.
how can it run faster?? it's not turning basic into machine code.... :?
Nice job Vader =D> =D> =D>
Post by lurkio » Thu Apr 23, 2020 10:17 pm
The Pack routine in the PRES Advanced BASIC Editor will substitute resident integer variables for non-resident ones where possible -- and res int vars are slightly quicker to access than non-resident ones are. (Pack will shorten the names of non-integer vars too.)
Pack also uses lots of other techniques to compress a BASIC program -- and a smaller program is quicker for the BASIC interpreter to scan through when it's doing a GOTO or GOSUB.
Also, I suspect that a smaller program with short variables, etc., is generally quicker for the interpreter to parse than a larger, "wordier" program is.
Btw, I've uploaded the current version of Moonbase Escape to a temporary location on bbcmicro.co.uk in case anyone would like to play it online:
:idea:
Naomasa298
Post by Naomasa298 » Thu Apr 23, 2020 11:34 pm
Can I point something out with my pedant hat on?
The Moon isn't a planet. :)
Post by lurkio » Fri Apr 24, 2020 12:25 am
Not sure if this is a bug or if I've missed something: I ran out of life support and died, and the game said I didn't have a spacesuit, even though I was wearing a spacesuit!
Site Admin
Post by Arcadian » Fri Apr 24, 2020 5:21 am
I like ... 'Moonbase Escape' !
But that might be because there's already an 'Escape from Moonbase Alpha' game on the Beeb - hence going with the former title would help differentiate it.
Anyway thanks for giving us the demo in the meeting Andrew and cheers for making the download available - have given it a quick try but will have a proper go over the weekend!
Once any issues have been ironed out, do you think you could produce an Electron version?
(Oh, and I love the artwork and would love to 'publish' it one day in a swish disc wallet with floppy as you know! :) )
LordVaderUK
Post by LordVaderUK » Fri Apr 24, 2020 7:58 am
Had you repaired the spacesuit? As originally found it isn’t fully working...
Post by lurkio » Fri Apr 24, 2020 9:44 am
Thanks! PM sent.
:idea:
LordVaderUK
Post by LordVaderUK » Fri Apr 24, 2020 1:52 pm
#-o
LordVaderUK
Post by LordVaderUK » Fri Apr 24, 2020 1:54 pm
MoonBase Escape it is...
Would be happy to try and remake it for the Electron but I have no idea where to start. What are the restrictions, and where is a reliable emulator (ideally for Mac) to try it?
As for publishing it, the egotist in me says yes, but the realist in me says it needs a lot more work and development before I’d feel comfortable with anyone paying (any) money for it!
EdwardianDuck
Post by EdwardianDuck » Fri Apr 24, 2020 2:34 pm
The Electron lacks MODE 7 (1Kb) and MODE 6 (monochrome) requires 8Kb so that's going to consume 7Kb out of the 4.5Kb I think you had left.
Not that this helps at all...
Jeremy
Master 128 + RetroClinic DataCentre + Internal Pi Zero Coprocessor, MiST
BBC & Atari Software
dp11
Post by dp11 » Fri Apr 24, 2020 2:36 pm
Take the money and either donate it to charity or the running of ABUG/startdot etc. :D
Post by sydney » Fri Apr 24, 2020 2:37 pm
Jeremy
That gives 9.5k to spare so it should fit.
LordVaderUK
Post by LordVaderUK » Fri Apr 24, 2020 2:41 pm
Ok that gives me a starter for 10. Best Elk emulator?
Post by sydney » Fri Apr 24, 2020 4:47 pm
On a Mac? Pass.
Site Admin
Post by Arcadian » Fri Apr 24, 2020 5:10 pm
I don't have a Mac, but I suggested Clock Signal in the last Virtual ABug which EdwardianDuck went on to try and I think he said it worked reasonably well ... might not be perfect for arcade games but I'd imagine it should be fine for a text adventure...
Site Admin
Post by Arcadian » Fri Apr 24, 2020 5:13 pm
Oh I'm months away from being in a position to publish anything (as I think you saw, I've got lots of other new releases to get out of the door at the moment) so no time pressures at all, there's plenty of time for tweaks (and ports! If you're considering an Elk conversion!).
It would be nice to get the cover art converted into a loading screen as well ... I might drop a 'specialist' a line if you're happy for me to do so?
LordVaderUK
Post by LordVaderUK » Fri Apr 24, 2020 5:15 pm
Sure thing!
Post by lurkio » Fri Apr 24, 2020 7:32 pm
I probably don't understand the Electron very well, but how do I type a tilde symbol in Elkulator?!
(I'm running the Windows version of Elkulator under WINE on a Mac.)
Site Admin
Post by Arcadian » Fri Apr 24, 2020 7:47 pm
Try Ctrl and Left-Cursor
Post by lurkio » Fri Apr 24, 2020 7:54 pm
:oops: Thanks!
Yes, it seems to work quite well. And it has the advantage that you can paste text from macOS into the emulated Elk.
:idea:
EdwardianDuck
Post by EdwardianDuck » Sat Apr 25, 2020 11:37 am
Andy,
PM sent.
Here is my configuration in B2 to get (as far as I can tell) ABE working. I got as far as *BE & UTILS before lack of need to learn how to use it kicked in.
Jeremy
Post by lurkio » Sat Apr 25, 2020 11:51 am
I've found that instead of typing *BE followed by UTILS you can just type *B and it will take you straight to the Utils menu.
At the Utils menu, press P to run the Pack routine on the BASIC program that's currently in memory.
:idea:
Post by daveejhitchins » Sat Apr 25, 2020 12:45 pm
Please . . . Don't forget to keep you editable copy!!
Post by lurkio » Sat Apr 25, 2020 12:50 pm
Please . . . Don't forget to keep you[r] editable copy!!
Good point! I tend to keep the uncompressed BASIC source (with full REMs, spaces, long var names, etc.) in a text editor on macOS and then, whenever I want to compress and test the code, I copy and paste it into BeebEm, and then invoke Pack.
:idea:
dp11
Post by dp11 » Sat Apr 25, 2020 1:12 pm
Also you can test the uncompressed basic on the bigger machines e.g. Hi basic on a second processor or bas128 on a master.
iamaran
Post by iamaran » Sun Apr 26, 2020 1:25 pm
Ah...
Return to “new projects and releases: text and graphic adventures”
