Page 1 of 1
Moon Patrol for the beeb (New port, just starting)
Posted: Fri Jan 04, 2019 9:14 pm
by tricky
I've been thinking about doing moon patrol, I wasn't a big fan and the beeb version really put me off, but I'm coming around to the idea.
The ground is a bit boring at the mo' and this isn't a beebem version :(
I also need to improve my music converter.
Re: Moon Patrol for the beeb (New port, just starting)
Posted: Fri Jan 04, 2019 10:36 pm
by RobC
Looking good =D> =D> :D
Posted: Sun Jan 06, 2019 10:52 am
by AndyF
I concur that is a very promising start. =D>
Posted: Sun Jan 06, 2019 2:55 pm
by tricky
Thanks.
I had to tweak my VGM converter as the VGM for the music that I had found seemed to have been converted from ~60Hz to ~50Hz and back to ~60Hz and my converter was finding a 61.75Hz pattern! Anyway, reduced from 1K to 400 bytes and now plays at a speed much closer to the original (now a bit too fast). The "drums" repeat the same pattern, so I could reduce that to 200 bytes!
I have a few minor compromises in mind, but the result should feel very close.
I'm trying to think of a good encoding for the map between exactly the same ground/aliens vs random whilst still making it possible and predictable.
Memory is looking OK, but there won't be much to spare and I doubt that I will have room for the buildings or any extras, but I am open to suggestions.
Posted: Fri Jan 11, 2019 10:50 pm
by Arcadian
Tried both demos. Impressed! Eagerly looking forward to the next (and the next and the next and the next! :) ).
Posted: Fri Jan 11, 2019 11:37 pm
by tricky
Stalled a bit, just can't seem to stay awake!
I'll try to get a new demo by the end of the weekend.
Posted: Sat Jan 12, 2019 9:19 pm
by tricky
Managed to get a couple of hours to add a longer tune and the buggy - can't be controlled but does have suspension :D
4.5K free :cry:
PS If you have an old beebem, the sound will be awful due to a beebem bug - I will try to remember to work-a-round it for the next demo!
Posted: Sun Jan 13, 2019 4:13 pm
by tricky
URL:https://youtu.be/ISyFwWREmjM View at 720p+ for 50hz.
BeebEm version attached - sound is correct in some versions but way off in others!
Posted: Sun Jan 13, 2019 7:51 pm
by FourthStone
Looking good Tricky =D>
One of my favorite arcade games that I'd play at the local milk bar.
I'd collect soft drink bottles to collect the deposit, buy some lollies and then have a few plays on moon patrol, good times.
Posted: Thu Jan 17, 2019 12:24 am
by tricky
I've been having trouble sleeping and waking up!
Added moving SHIFT/RETURN and shooting up Z.
Debug output says 7K left.
Posted: Thu Jan 17, 2019 7:01 am
by jms2
That suspension is mesmerising....
Posted: Sat Jan 26, 2019 8:55 pm
by tricky
I've eventually managed to get back to MoonPatrol and got slightly sidetracked with why beebem's timing is off and it took about one second to "fix" it in the version I have!
void VideoDoScanLine(void) {
VideoState.VSyncState=(CRTC_SyncWidth>>4)+1;
I removed the +1 in the line above as the vsync ends one scan line too late.
I don't think this is the correct solution, and that it is more a case of two wrongs making a right as the colour changes are still one scan line off compared to b-em and real hardware.
Posted: Mon Jan 28, 2019 6:25 pm
by tricky
Added shots up and forward and alien bombs (but no aliens), so there is a bit of a game there.
I still need to tidy things up and order them correctly, but is should start to feel like MoonPatrol.
I might have to make it easier to dodge the bombs.
Z/X slower/faster
RETURN shoot up
SHIFT shoot forward (can't hit anything with this gun).
Posted: Sat Feb 02, 2019 12:07 pm
by tricky
Not getting very far very fast, so thought I would do something quick to get me going, so here is the VideoNuLA comparison screenshot.
Left: native beeb, Centre: Arcade, Right: beeb+NuLA
The beeb version currently has a slightly wider and taller play area but I have skimped a bit on the scenery and UI.
I moved the UI to the bottom so that the warning !!! are close to where you are looking for holes and not because it was easier to code :---)
I will probably tweak the UI area a bit more, but it should be OK for now.
Posted: Sat Feb 16, 2019 6:37 pm
by Dethmunk
:shock: Looks awesome Tricky. :)
I personally prefer the native BBC version for colour options. LOL :D Great stuff though loving it.
Posted: Sat Feb 16, 2019 10:02 pm
by tricky
Sorry it has stalled, I've been trying to get over a cold for a fortnight and am still having trouble breathing.
Posted: Sat Feb 23, 2019 4:00 pm
by Dethmunk
Get well soon Tricky. Moon Patrol is looking awesome. :D
Posted: Sat May 25, 2019 10:31 am
by tricky
Minor progress update:
URL:https://youtu.be/nZaieTuQ4bg View at 720p+ for 50hz.
Posted: Sat May 25, 2019 11:19 am
by lurkio
Absolutely ridiculous!
=D> =D> =D>
Posted: Sat May 25, 2019 7:16 pm
by Muddyfunster
This is looking great!
Posted: Sun May 26, 2019 2:40 am
by simonm
Love it. So smooth and the colours are great! Plus I'm a big fan of how you use the arcade fonts too. =D>
Posted: Sun May 26, 2019 10:19 am
by JudgeBeeb
Marvellous =D> =D> =D>
Posted: Sun May 26, 2019 3:52 pm
by mlouka
Excellent stuff -- great to see the progress you are making! =D>
Posted: Sun May 26, 2019 4:20 pm
by tricky
Thanks for all the kind words.
I got a bit bogged down writing different sprite routines for every object, most of them have multiple routines!
Now I have plenty of frame time, but not much memory and will have to combine a few of them to get the memory back!
I'm currently prepping for Revival and discovering that most of my "spare" beebs have developed faults, but I think I have enough now and will be able to get back to this after Revival.
Posted: Sun May 26, 2019 5:08 pm
by 0xC0DE
Great work! Very smooth scrolling indeed.
Posted: Sun May 26, 2019 5:13 pm
by Rich Talbot-Watkins
I know I say it every time, but I think this is probably your best conversion yet! Absolutely amazing bit of work!
Posted: Sun May 26, 2019 7:24 pm
by rmbrowngr
Very impressive. Very well done. =D>
Posted: Mon May 27, 2019 2:09 pm
by Muddyfunster
Thanks for the reminder on Revival!
