BeebAsm
SteveF
Re: BeebAsm
Post by SteveF »
Thanks for taking a look at that, I've built your branch and works fine.
Shall I create an issue for this and link to your branch so this doesn't get forgotten for the next release?
ctr
Re: BeebAsm
Post by ctr »
That would be great, thank you.
SteveF
Re: BeebAsm
Post by SteveF »
6502
Re: BeebAsm
Post by 6502 »
Just a quick question, does BeebAsm support string variables?
Such as:
CONSTANT_NAME = "FOOBAR"
ORG &1900
.start
    EQUS CONSTANT_NAME
.end
sweh
Re: BeebAsm
Post by sweh »
I'm willing to be proved wrong, but I don't think so.
However, macros may meet the requirement, depending,
MACRO CONSTANT_NAME
  EQUS "FOOBAR"
ENDMACRO
ORG &1900
.start
    CONSTANT_NAME
.end
Off the top of my head, I can't think of a scenario where a string isn't used in an EQUS so the macro may suffice.
Rgds
Stephen
6502
Re: BeebAsm
Post by 6502 »
sweh wrote:
Thu Nov 05, 2020 1:20 am
MACRO CONSTANT_NAME
  EQUS "FOOBAR"
ENDMACRO
ORG &1900
.start
    CONSTANT_NAME
.end
Yes just tested it and that works. Using a macro is a little clunky, but I guess it does the job.
ReubenS
Re: BeebAsm
Post by ReubenS »
I need a little help getting Beebasm to build Starquake from source...
Starquake is basically one big file that contains 1 large chunk and 3 small chunks, all concatenated together. This big file loads from disc at &1200 and the large chunk is immediately relocated to &E00, while the 3 smaller chunks are relocated to other addresses.
I think I understand the relocdemo sample but I can't see how to go about doing *multiple* relocations. Should I be aiming to do a different SAVE for each chunk? If so, then what loads them all?
VectorEyes
Re: BeebAsm
Post by VectorEyes »
ReubenS wrote:
Wed Dec 16, 2020 11:44 pm
So it's one big file that gets loaded, then some code is executed that relocates the big chunk and the 3 smaller chunks, and then you jump to the 'main game start' code, something like that?
One approach might be to assemble the chunks at the 'destination' locations, SAVE all four of them out (to the local filesystem, not to the SSD) ... then have a second assembly pass that uses INCBIN to include each of them at the place they're meant to go when they're part of the one big file... then SAVE out the big file (along with the code that does the runtime relocation etc).
There are various other ways to do it but that approach seems simple and easy to implement.
Rich Talbot-Watkins
Re: BeebAsm
Post by Rich Talbot-Watkins »
There's also a COPYBLOCK <start>, <end>, <dest> command which you might be able to use to shift blocks of code around after they've been assembled. That might work for you, though you'd need to be careful that you copy them in such an order that you don't overwrite anything you need to preserve. Generally, the trick would be to copy the block with the highest address destination first.
ORG &400
.block1
\\ stuff
.block1end
ORG &900
.block2
\\ stuff
.block2end
ORG &E00
.block3
\\ stuff
.block3end
load = &1200
block1load = load
block2load = block1load + (block1end - block1)
block3load = block2load + (block2end - block2)
entryload = block3load + (block3end - block3)
COPYBLOCK block3, block3end, block3load
COPYBLOCK block2, block2end, block2load
COPYBLOCK block1, block1end, block1load
ORG entryload
.entry
\\ relocation code here
JMP start
.end
SAVE "Code", load, end, entry
I have no idea if that will actually work, but it looks as though it might.
(Note: this is a different technique to the relocdemo, which assembles to its final location but patches address references in the entry point code which will be loaded at a higher position. This makes use of the fourth parameter in SAVE, to supply a reload address.)
ReubenS
Re: BeebAsm
Post by ReubenS »
Thanks for the pointers, guys.
I was considering hacking at the "SAVE" command so that "SAVE+" (or something like that) appends to the previously saved file...
alastairhm
Re: BeebAsm
Post by alastairhm »
I've recently got a new Mac laptop from work with Catalina installed, the version of beebasm I previously downloaded didn't work I assume because it was 32 bit.
So I had to compile my own 64 bit version.
If you need a MacOs 64 bit version as well you can download it from here http://blog.0x32.co.uk/posts/beebasm/
julie_m
Re: BeebAsm
Post by julie_m »
Would it be possible to add a feature to BeebAsm where PUTTEXT, INCBIN et al can launch a shell with two extra environment variables, one containing all the source code seen so far and the other with -v output so far; run an external command; and use its STDOUT in the disc image?
garfield
Re: BeebAsm
Post by garfield »
Another request for the excellent BeebAsm is: multi-line comments
i.e. the equivalent to /* */ in C and C++
It is a minor chore to put a single backslash before each line, so some "opening" and "closing" sequence to denote ignorable comments would be great.
Thanks again Rich and all.
SteveF
Re: BeebAsm
Post by SteveF »
I've pulled together some of the recent fixes onto the proposed-updates branch (https://github.com/stardot/beebasm/tree ... ed-updates). It would be good to get these labelled up as beebasm 1.10, in particular mungre's fix for the "JMP .label" case where 1.09 just silently assembles 0 (https://github.com/stardot/beebasm/issues/44).
Can people please test this to see if it builds correctly for them and assembles their projects OK?
If I missed anyone's code submissions please let me know. (There have been some good ideas for improvement proposed and I hope someone will implement some of them at some point, but I don't personally have the time to do that right now.)
Here's the relevant bit of the changelog:
??/??/????  1.10  Documented "$" and "%" as literal prefixes (thanks to
                  cardboardguru76 for pointing this out).
                  Fixed silently treating label references starting with "."
                  as 0 (thanks to mungre for this fix).
                  Allowed "-h" and "-help" options to see help.
                  Fixed tokenisation of BASIC pseudo-variables in some cases.
                  Fixed incorrect line number for errors inside macros with
                  blank lines inside them.
                  Fixed incorrect line numbers from PUTBASIC in some cases.
Re: BeebAsm
Post by tricky »
Did you get my CALLSTACK$ request/sample implementation?
viewtopic.php?p=280427#p280427
SteveF
Re: BeebAsm
Post by SteveF »
tricky wrote:
Tue Apr 06, 2021 2:36 pm
I hadn't picked this up but I've now tidied your implementation up slightly and pushed a version of this on the https://github.com/stardot/beebasm/tree ... -callstack branch, which also includes all of the other proposed-updates changes. Please take a look and let me know if you're happy with it, and if it still works correctly - I've only given it a light test.
I'll merge that onto proposed-updates later, in the meantime if people could build and test the tricky-fileline-callstack branch as the possible beebasm 1.10 release candidate I'd appreciate it.
Re: BeebAsm
Post by tricky »
Thanks, I'll give it a try tonight.
Sorry, I don't do git.
Re: BeebAsm
Post by tricky »
Thanks,
Still builds straight out of the box with the supplied VS2010 proj and sol.
CALLSTACK$ seems OK, but as it doesn't support -dd or -labels <labels file> I can't give it a full test.
SteveF
Re: BeebAsm
Post by SteveF »
Thanks for trying that tricky. If you can give me a pointer to not-too-hacky code implementing -dd and -labels I will see if I can polish those up for inclusion too. (I won't search the forum myself in case there are newer/better implementations I might miss...)
Re: BeebAsm
Post by tricky »
I thought that they were already in, but I'll have a look!
Re: BeebAsm
Post by tricky »
This is my version that came from a proposed updates version that I think was based on 1.09.
It also include -writes 99 to set the number of accesses that the disc shows as having.
It is just the src folder without the VS2010 folder.
src.zip
(67.13 KiB) Downloaded 3 times
SteveF
Re: BeebAsm
Post by SteveF »
Thanks tricky. I've tweaked that (mainly a bit of variable renaming to avoid errors on g++) and it's on https://github.com/stardot/beebasm/tree ... ricky-misc - this has CALLSTACK$ and FILELINE$ as well and all the other proposed-updates stuff.
I've very lightly tested this and it seems to be working but please try it and let me know how you get on. Edited to add: if it seems to be working, it would be good if you could compare the labels file generated with one from your current local beebasm build to help catch any glitches.
Steve
Re: BeebAsm
Post by tricky »
Thanks, great job and sorry it was so hacky in the first place!
It doesn't build with the supplied project because of the use of C++11 (I think it was 11).
for (const Label & label : m_labelList)
It doesn't build with 2013
..\commands.cpp(157): error C2039: 'max' : is not a member of 'std'
VS2019 works with updated WDK and toolset.
I've attached an updated .vcxproj
The solution will still default to 2010, but you can right click and "open with" or update the .sln
labels and disc images are binary identical.
BeebAsm.zip
(1.34 KiB) Downloaded 4 times
SteveF
Re: BeebAsm
Post by SteveF »
Thanks for testing that, good to know the output is still the same!
I've pushed changes to https://github.com/stardot/beebasm/tree ... ricky-misc to rewrite that C++11 code in a hopefully C++98-compatible way (it does at least build on g++ with --std=c++98). I hope that's OK but it seemed a shame to break C++98 compatibility just for this.
I haven't yet added your new BeebAsm.vcxproj - should I replace the existing VS2010/BeebAsm.vcxproj with this, or should I create a new VS2019/BeebAsm.vcxproj which is your new version? Do we need to put something in the README telling users what to do? As you can probably tell I'm not too well up on the finer points of VS...
Re: BeebAsm
Post by tricky »
There is no need to have it if it still builds fine with the old one.
If you do want to include it, I have just realised that it probably has source control entries which won't be helpful for anyone else!
I'll remove them and create a new .sln to go with the .vcxproj, they can then be placed in a VS2019 folder (for consistency).
SteveF
Re: BeebAsm
Post by SteveF »
Thanks tricky, I'll add the VS2019 directory to the repo when you have the contents ready (no rush) and with a bit of luck someone will have an old Visual Studio they can test the existing VS2010 directory with - I think there's a fair chance that will still work now I've tweaked the problems you mentioned earlier (e.g. the C++11-style for loop), I just can't test myself.
Re: BeebAsm
Post by tricky »
That builds fine with 2010.
SteveF
Re: BeebAsm
Post by SteveF »
Excellent, thanks for testing!
Return to “development tools”
