Z80 cross-compiler for Arcs?
pkersey
Post by pkersey » Wed Dec 04, 2019 2:39 pm
Hello.
Are there any Z80 cross-compilers available that would run on an A5000, possibly A3020?
Re: Z80 cross-compiler for Arcs?
Post by daveejhitchins » Wed Dec 04, 2019 4:38 pm
There’s the Cross32 - I still have a few copies. See here and PM me if you’re interested.
Post by jgharston » Wed Dec 04, 2019 6:04 pm
I either use Z80 BBC BASIC running on !Z80Tube, or ZMac:
http://mdfs.net/Software/Z80/ZMac/
I typically use ZMac with a command line with an Obey build file such as:
| Makefile for FastPrint
If "<ZMac$Dir>" = "" Then Error 0 !ZMac not seen
Set Here$Dir <Obey$Dir>
Echo Assembling
Run <ZMac$Dir>.ZMac -o <Here$Dir>.fastprn -x <Here$Dir>.fastprn/lst <Here$Dir>.fastprn1/asm
SetSpec <Here$Dir>.fastprn
ZX.BINtoTAP <Here$Dir>.fastprn <Here$Dir>.fastprn/tap fastprint
to build http://mdfs.net/Info/Comp/Spectrum/Prog ... stprn1.asm
pkersey
Post by pkersey » Sat Dec 07, 2019 5:15 pm
Thanks for the replies. :)
Post by jgharston » Sat Dec 07, 2019 10:10 pm
I've just re-read the thread, are you looking for, as you asked, a cross COMPILER, or a cross ASSEMBLER?
A compiler takes stuff that looks like main(a,b) { for (c=0; d++; c<d) { foo(); thing(c,a); } bar(b); } and converts it into a binary file that you can execute.
An assember takes stuff that looks like LD HL,&4000:LD D,H:LD E,L:INC D:LD (HL),0:LDIR:RET and converts it into a binary file that you can execute.
If you want a Z80 COMPILER for the Arc, you need to specify what language it compiles. The Z88 Development Kit compiles C and targets the Z80, and I believe it has been ported to RISC OS as it itself is written in fairly unexceptional C. The GNU gcc compiler has been ported to all sorts of platforms and has a target=Z80 module. I don't know of any compilers for other languages that target the Z80 and run on RISC OS.
Return to “development tools”
