$70 100MHz (?????) 'scope
Post by daveejhitchins » Mon Nov 11, 2019 9:55 am
This would, probably, be ideal for fixing Beebs and Electrons - may just be good enough for the Archimedes too?? Note: Just a see-if-there-is-anything-there 'scope!
Lardo Boffin
Re: $70 100MHz (?????) 'scope
Post by Lardo Boffin » Mon Nov 11, 2019 9:58 am
Very interesting.
Atom, issue 5
Elk
USA Model B
TimoHartong
Post by TimoHartong » Wed Nov 27, 2019 9:20 pm
Some calculations: square waves the upper specified frequency of your scope should be 10 times. The official frequency of the Archimedes is 24 MHz so 250 MHz would be much better. Further to this, it looks more like a single channel oscilloscope which is perhaps a bit limited to do really useful work.
My personal opinion is that a scope is a nice instrument but a logic analyzer will be more useful.
Post by Elminster » Thu Nov 28, 2019 5:50 pm
5 times is usual quote by scope manufacturer to pickup 5th harmonic. So you would probably get a distorted but recognisable signal with 100Mhz, but 200Mhz should be fine.
60Mhz (digital signal) on my 350Mhz scope is fine.
Having watched the video for the mini scope I Don’t think 24Mhz would be realistic on it. But pretty cheap though.
julie_m
Post by julie_m » Thu Nov 28, 2019 6:21 pm
The first rule of oscilloscopes: Any oscilloscope is better than no oscilloscope.
Post by Elminster » Thu Nov 28, 2019 6:45 pm
Not if the signal displayed is garbage. And you could buy a decent second hand one instead (although $70 that would be a challenge)
Edit: should be okay for beebs though
Edit2:
I did have a quick play of putting a 25Mhz square wave into a scope and then bandwidth limiting it to 20Mhz. It obviously turns it into a sine wave and doubles the rising and falling times. But that might be good enough I suppose.
TimoHartong
Post by TimoHartong » Sat Nov 30, 2019 8:51 pm
That depends if you want to do proper diagnostics you should be able to trust your instrumentation and know how to use it
Post by 1024MAK » Sat Nov 30, 2019 9:31 pm
You should never, ever put 100% trust in your instruments or in any test gear / equipment. Even ‘good’ brands sometimes get things wrong. In the 1990s a big user of Fluke multimeters discovered that with an audio frequency pulsing DC signal, a particular model of theirs (and we are talking about a model that cost hundreds of (£) pounds) would give a different result depending on which way round you connected the test leads (polarity).
Always understand the limitations of the test equipment that you are using. ALL test equipment has limitations...
Post by Elminster » Sun Dec 01, 2019 11:07 am
It would be interesting, on a Beeb, to compare one of these, a logic probe and a bench scope. Not that I have time myself.
Gary C
Post by Gary C » Thu Apr 09, 2020 7:45 am
Thats certainly true. We used to use AVO 8's at work, and on volts the impedance was so low that the test procedures had to factor in the amount the meter pulled down the reading.
We also have some picoammeters calibrated to read down to 0.000000000001 Amps on the lowest range and just moving your arms changes the reading :)
Return to “development tools”
