Plotting desktop sprites in mode 15
pdjstone
Post by pdjstone » Thu Sep 03, 2020 5:30 pm
I'm trying to plot some of the standard WIMP desktop sprites in mode 15, but I seem to be misunderstanding how to use ColourTrans_SelectTable. My reading of the documentation is that it should 'do the right thing' and map the sprite palette to the current mode. Am I using ColourTrans in the wrong way or should I be doing this in some other way? Is it something to do with using a 256-colour mode?
Here's my code:
10 MODE 15
15 size%=&85e8
20 DIM area% size%
30 DIM name% 13
40 DIM trans% 160
50 area%!0=size%:area%!8=16
60 SYS "OS_SpriteOp",9+256,area%
70 SYS "OS_SpriteOp",10+256,area%,"resources:$.resources.wimp.sprites"
80 SYS "OS_SpriteOp",8+256,area% TO ,,,n%
90 PRINT "Num sprites:", n%
100 FOR i%=1 TO n%
110 x%=(i% MOD 15)*78
120 y%=(i% DIV 15)*78+78
130 SYS "OS_SpriteOp",13+256,area%,name%,13,i%
140 SYS "ColourTrans_SelectTable",area%,name%,-1,-1,trans%,0
150 SYS "OS_SpriteOp",52+256,area%,name%,x%,y%,0,0,trans%
160 NEXT
markdryan
Re: Plotting desktop sprites in mode 15
Post by markdryan » Thu Sep 03, 2020 10:45 pm
There's a related question here:
https://www.riscosopen.org/forum/forums/11/topics/8980
The issue seems to be with 16 colour mode WIMP sprites without a palette. For these sprites, ColourTrans_SelectTable will return the wrong palette. Apparently, it returns the kernel palette and you want the Wimp Palette (the two being different in 4 and 16 colour modes). You need to use Wimp_ReadPixTrans instead. Try replacing line 140 with
SYS "Wimp_ReadPixTrans", 256, area%, name%, ,,, 0, trans%
Most but not all the sprites ( I think the ones that are already in mode 15 ) display properly when I do this.
pdjstone
Post by pdjstone » Fri Sep 04, 2020 9:03 am
Thanks! I didn't realise that some Wimp_ SWI's would work when the desktop was not active.
markdryan
Post by markdryan » Fri Sep 04, 2020 9:14 am
Neither did I. Thanks for posting the code example. It was good fun playing around with it.
Return to “programming”
