Two DEFPROCs, one ENDPROC?
julie_m
Post by julie_m » Wed Sep 02, 2020 9:38 pm
I think we've all seen assembler code like this:
.add16
CLC
.adc16
JSRadd16_1
.add16_1
LDAwkspace,X
ADCwkspace,Y
STAwkspace,X
INX
INY
RTS
with multiple entry points into the same code, so two JSRs can hit the same RTS.
Can you do something similar in BASIC, with a DEFPROC between another DEFPROC and an ENDPROC, to give the option to execute or skip a section of code? Something like
DEFPROCexport
OSCLI"SP."+V$
DEFPROCfake_export
L%=0
*/VDUMP
*SP.
ENDPROC
and then PROCfake_export will perform a "fake" variable dump (allowing any egregious errors to be spotted), but PROCexport will do it for real?
cmorley
Re: Two DEFPROCs, one ENDPROC?
Post by cmorley » Wed Sep 02, 2020 9:47 pm
Just try it:
   10PROCA
   20PROCB
   30END
   40DEFPROCA
   50PRINT"a";
   60DEFPROCB
   70PRINT"b"
   80ENDPROC
Post by roland » Wed Sep 02, 2020 9:53 pm
I must say that the result surprises me. I didn't expect that....
Richard Russell
Post by Richard Russell » Wed Sep 02, 2020 10:06 pm
This is a pattern I commonly use:
      DEF PROCone : LOCAL type% : type% = 1
      DEF PROCtwo : LOCAL type% : type% = 2
      DEF PROCthree : LOCAL type% : type% = 3
      REM rest of procedure
      ENDPROC
This is particularly handy when the multiple procedures share common local state, typically (in BBC BASIC for Windows or BBC BASIC for SDL 2.0) some PRIVATE variables:
      PRIVATE shared_variables, arrays(), structures{}
It's actually quite tricky to achieve shared local state between multiple PROCs/FNs any other way in BBC BASIC.
They don't all have to be PROCs (or all FNs) either:
      DEF FNtwo : LOCAL type% : type% = 2
      IF type% = 1 THEN ENDPROC ELSE = result
This is the kind of thing a compiler would find difficult!
Post by lurkio » Wed Sep 02, 2020 10:47 pm
      ENDPROC
Ah, yes. This is possible thanks to the fact that DEF is treated like REM, which is a fact that I learnt from this unforgettable exchange in 2014:
viewtopic.php?f=2&t=8388&p=89696&hilit= ... rem#p89696
:idea:
julie_m
Post by julie_m » Wed Sep 02, 2020 10:59 pm
Well, it seems to work, behaves exactly as expected and does not do anything too crazy with the stack either (as shown by selecting a graphics mode and changing HIMEM to somewhere inside the framebuffer).
Richard Russell
Post by Richard Russell » Thu Sep 03, 2020 1:01 am
There's a good reason why DEF behaves as REM, it's not the whim that Jonathan implies. It was a requirement of the BBC's specification that BBC BASIC should be substantially compatible with Microsoft BASIC (of the day) and Microsoft BASIC supports single-line functions that can go anywhere in the program. Indeed I think single-line functions of this sort pre-date multi-line functions in BASIC generally.
So this kind of code was required to be acceptable:
      numerator = 22
      denominator = 7
      DEF FNdivide(a,b) = a/b
      PRINT FNdivide(numerator, denominator)
Hence DEF, if encountered in normal execution, must behave as REM.
Post by BeebMaster » Thu Sep 03, 2020 11:28 am
I use this construction occasionally, as in:
 5200DEFFNread(buffer,start,blockcount,drive):opcode=8
 5300DEFFNwrite(buffer,start,blockcount,drive):opcode=&A
 5400=FNosword(buffer,start,blockcount,drive,opcode)
Actually I was a bit worried about that in case when calling FNread it did process the FNwrite line and set the opcode to &A which would have been disastrous - but it works.
Soruk
Post by Soruk » Thu Sep 03, 2020 1:54 pm
I love threads like this. I decided to test this in Matrix Brandy, and while multi-entry procedures worked as expected, the REM behaviour of the DEF line wasn't... (it is now)
Return to “programming”
