24-bit Arithmetic in 6502
Post by BeebMaster » Fri Jul 24, 2020 3:53 pm
I've been trying for quite a few years to understand why the L3 file server doesn't always work out free disc space correctly and I think I am getting close to understanding it now.
Briefly, when a disc is initialised for file server use, you feed it a value of sectors per cylinder which it then uses to write a sector of free-space-bitmaps at the first sector of each cylinder, one bit per sector, clear is used, set is free. When the file server starts, it reads all these sectors and works out how much space there is.
So, tell it there are 256 sectors per cylinder, and it will write its maps at sector 256, 512, 768, etc. all through the disc.
Except some larger values which I would expect to work just don't. Values up to 2040 work, above that they don't work. There are 2 bytes reserved for number of sectors per cylinder, so 65536 should be the maximum, though realistically 2048 is the maximum as this is the total number of "bits" which will fit in a 256-byte map sector.
With some Pi 1MHz SCSI debug tracing, I think I know what it's doing, and possibly why.
Take the case of 2040 sectors per cylinder. The file server should read sectors 2040, 4080, 6120, 8160 etc. in steps of 2040 all the way up to 2095080, if it's a 512MB ADFS disc image. It does this, so it works.
In the case of 2048 sectors per cylinder something goes wrong early on. It should read 2048, 4096, 6144, 8192 etc, but it doesn't. It reads 2048, then 4096, then jumps to 528384, then 1052672, then 1576960, which is the last one before the end of the disc.
I think this is because there is a calculation error when working out which is the next sector to read. More than likely Acorn never anticipated discs with 2048 sectors per cylinder, (16 heads x 63 maximum sectors per track = 1008 probably being a realistic maximum amount contemplated in the 1980s), so this bit of the code may never have been thoroughly tested.
This, then is what should happen:
	Byte>>	2	 1        0
        Bit >>  76543210 76543210 76543210
2048		00000000 00001000 00000000
4096		00000000 00010000 00000000
6144		00000000 00011000 00000000
8192		00000000 00100000 00000000
etc
But this is what actually happens:
	Byte>>	2	 1        0
528384		00001000 00010000 00000000
1052672		00010000 00010000 00000000
1576960		00011000 00010000 00000000
So it looks to me when it is doing 4096+2048, instead of setting bit 3 of byte 1, it is actually setting bit 3 of byte 2 and ending up with 528384.
At the next calculation, it's operating solely on byte 2, shifting a bit left, which is what it does on byte 1 when going from 2048 to 4096.
Could some simple error in the arithmetic code be causing this, like forgetting to clear the carry flag or somesuch, which would muck things up with values over 2040 but work for 2040 or lower?
Re: 24-bit Arithmetic in 6502
Post by roland » Thu Jul 30, 2020 8:11 pm
I can't see any logic in these errors. It would it make easier if you have a disassembly listing of the code that does this calculation. Can you post that here?
Post by BeebMaster » Thu Jul 30, 2020 11:07 pm
I think there are other factors at work than a simple calculation error unfortunately, including the interdependence of several other variables used throughout the source code.
It's here if it's any help for this particular problem:
viewtopic.php?f=3&t=11366&p=254487#p254353
I did isolate what I think is the routine which calculates the next disc sector to read, and converted it to real BBC BASIC 6502 assembler and ran it, but it worked as expected.
Return to “programming”
