Big machine code programs
AJW
Post by AJW » Thu Jul 16, 2020 10:12 am
What do you prefer when flling thhe memory with machine code when the assembler listing gets too big for one assemble to memory? Multiple listings then *load from main BASIC program or *load from another machine code program e.g with OSFile or JSR&FFF7?
julie_m
Re: Big machine code programs
Post by julie_m » Thu Jul 16, 2020 2:43 pm
Well, for BCP, I broke the source code down into chunks, which can be assembled separately in order. There are several separate BASIC programs, each of which assembles a part of the code using OPT 4 / OPT 7. Entry points and workspace locations that need to be referred to in another part of the code are exported using *SPOOL / *EXEC. The code is *SAVEd specifying the correct reload address. All the resulting files fit together, so they can be *LOADed into their rightful location and *SAVEd as a single file.
Post by sweh » Thu Jul 16, 2020 3:21 pm
Back in the day I used a ROM assembler; originally ASM but then the free Lancs 65C02 assembler. This reads and writes to disk, so size isn't an issue.
Modern development I do on Linux with beebasm and then just copy the result to the Beeb.
Post by roland » Thu Jul 16, 2020 3:46 pm
Nowadays I also develop on Linux of Mac with CA65 or Beebasm. The editors are much nicer to work with (e.g. forward and backward scrolling through the source code) and assembling is much faster. Also porting code between Beeb/Elk and Atom is much easier with modern tools. I can use the same source code base and use variables to choose between the target platform.
Soon I can transfer my machine code over WiFi to my Atom or Electron :lol:
julie_m
Post by julie_m » Thu Jul 16, 2020 7:53 pm
I'm thinking of using BeebAsm for BCP, but hoping to keep it buildable on a real or emulated BBC Micro. My cunning plan is to write some scripts to help with the variable export process, by selecting only labels preceded by a blank line or contrived comment for export .....
Post by tricky » Thu Jul 16, 2020 9:30 pm
Back in the day, several BASIC programs each *SAVEing its bit and then loading the next and GOTO 10.
At the end, *LOAD all the bits and *SAVE the final "EXE".
Now beebasm it on the PC, straight to .SSD and auto boot in emulator for preliminary testing and debugging.
Naomasa298
Post by Naomasa298 » Thu Jul 16, 2020 9:42 pm
I'm actually curious as to what you mean by this.
kieranhj
Post by kieranhj » Fri Jul 17, 2020 9:32 am
The thought of trying to build a massive program like POP on a real BBC Micro brings me out in a sweat. :shock:
AJW
Post by AJW » Fri Jul 17, 2020 10:07 am
That would require some care and tricks to pass information from one code to another eg the music on and off locations which are in code2 and the key input routine which calls them in code1.
Also does beebasm remove assembler comments?
AJW
Post by AJW » Fri Jul 17, 2020 11:46 am
have a main macine code profmgram that loads in other blocks of machine code using osfile or the CLI (see User Guide).
Naomasa298
Post by Naomasa298 » Fri Jul 17, 2020 11:58 am
But you're not going to need the assembler listing in memory when you execute the program, so why do you need to load it from machine code? Why not just load it all in one go from a BASIC loader program?
Or just concatenate the different chunks into one file?
Unless the assembled code itself is too big for memory.
Post by jgharston » Fri Jul 17, 2020 1:04 pm
I similarly use a tool to assemble from disk, *ASSEM uses the BBC BASIC assembler to assemble from source files.
AJW
Post by AJW » Fri Jul 17, 2020 1:13 pm
*load I mean.
Naomasa298
Post by Naomasa298 » Fri Jul 17, 2020 2:06 pm
*load I mean.
Yes, I got that bit. I'm just not sure I see the need to load it in chunks via OSFILE calls. Just concatenate them and load the whole lot once.
Post by tricky » Fri Jul 17, 2020 7:35 pm
My friend bought ADE (I think that is the right name) and a second disc drive because one was too slow.
I can't remember his name, but he wrote an excellent millipede with sine wave GAME OVER iirc.
I think we went to a bbc micro fair or something in london and both bought sideways RAM, disc interfaces and floppy drives iirc.
Return to “programming”
