Raising an interrupt on the native arm Co-processor
dudleysoft71
Post by dudleysoft71 » Mon Jul 06, 2020 7:36 pm
I'm trying to raise in interrupt on the native arm Co-processor on PiTubeDirect. I tried to turn on the Interrupt on register 1 on the parasite side and during my vblank interrupt I write to register 1 data, according to the tube programming guide this should trigger an interrupt on the parasite, and looking at the source for the pi side it should trigger. I used OS_ChangeEnvironment to set a new escape handler, and nothing happens. I need to be able to generate a regular 50hz interrupt signal on the Pi because the frontier port requires a regular signal to generate the vsync signal for the running VM.
If anyone has any experience with interrupts over the tube who could help it would be appreciated.
Re: Raising an interrupt on the native arm Co-processor
Post by hoglet » Mon Jul 06, 2020 8:37 pm
You should be able to do what you want with events:
Use OS_ChangeEnvironment to replace the default EVENT_HANDLER with your own code.
Then use *FX 14, 4 (or the equivalent OSBYTE) to enable the VSYNC Event.
The default event handler doesn't do anything unless you have compiled with DEBUG_ARM defined:
https://github.com/hoglet67/PiTubeDirec ... ive.c#L107
dudleysoft71
Post by dudleysoft71 » Mon Jul 06, 2020 9:18 pm
Okay, thanks that sounds exactly what I need.
I'll give it a try tomorrow, hopefully once I've got it working the game should run at a better pace, currently its dependent on framerate which can make it just a little slow.
dudleysoft71
Post by dudleysoft71 » Wed Jul 08, 2020 5:03 pm
Just tried that out and it works a treat, a much better solution than fudging it into the flip and idle calls.
Return to “programming”
