IF INKEY-xy
AJW
IF INKEY-xy
Post by AJW » Sat Jul 04, 2020 9:07 pm
What is the machine code equivalent of IF INKEY-68 etc? I'm using:
LDA#&81:LDX#1:LDY#0:JSR&FFF4
but as I understand it this is roughly the same as A=INKEY(1) . Isn't INKEY-xy instant i.e. not 1 m/s delay?
Richard Russell
Re: IF INKEY-xy
Post by Richard Russell » Sat Jul 04, 2020 9:38 pm
-68 is &FFBC so you should be loading Y with &FF and X with &BC.
AJW
Re: IF INKEY-xy
Post by AJW » Sat Jul 04, 2020 11:38 pm
I thought X and Y hold the delay time?
Re: IF INKEY-xy
Post by jgharston » Sun Jul 05, 2020 12:17 am
Yes, and if the delay time is negative.....
AJW
Re: IF INKEY-xy
Post by AJW » Sun Jul 05, 2020 8:21 am
By -68 I mean a key number e.g.-68 for F, -69 for E.
Richard Russell
Re: IF INKEY-xy
Post by Richard Russell » Sun Jul 05, 2020 10:47 am
Yes. It's the parameter for INKEY which if positive is the maximum wait time and if negative is the key to be tested. Exactly the same is true in assembly language: the parameter goes into YX (as a 16-bit signed number) in that case, so again if it's positive it will set the wait time and if negative the key number. You are perhaps overthinking this: try doing what I suggested (set Y to &FF and X to &BC) and see what happens!
Re: IF INKEY-xy
Post by 1024MAK » Sun Jul 05, 2020 11:31 am
As said many times before, BBC BASIC does not do any I/O itself, it just passes parameters to the OS. The OS does the I/O and then returns values to BASIC...
So calling the relevant OS routine via machine code is the same as doing the same operation with the relevant BASIC I/O command/function.
AJW
Re: IF INKEY-xy
Post by AJW » Sun Jul 05, 2020 1:28 pm
So now i have to convert all my keys into 2s complement 16bit hex .
e.g.
2810 LDA#&81:LDX#1:LDY#0:JSR&FFF4 \inkey(1)
 2820 CPX#77:BNEek2:LDA#3:STA&8A:JSR updinput:LDA#1:STA&8B:RTS \m
 2830 .ek2 CPX#75:BNEek:LDA#4:STA&8A:JSR updinput:LDA#1:STA&8B:RTS \k
I assume EOR with 255 then add 1 to lower byte.
What is returned in A?
Richard Russell
Re: IF INKEY-xy
Post by Richard Russell » Sun Jul 05, 2020 1:47 pm
No, you don't: the assembler will do that for you:
      LDA#&81
      LDX#(-68 AND &FF)
      LDY#((-68 AND &FF00) / 256)
      JSR&FFF4
It's one of the powerful features of BBC BASIC's assembler that the entire range of BASIC functions is available to you when computing the values of (for example) immediate constants, so you can often make your life easier and reduce the opportunity for errors by making use of this.
OSBYTE doesn't return the result in A, it returns it in X. See the documentation.
AJW
Re: IF INKEY-xy
Post by AJW » Sun Jul 05, 2020 2:01 pm
So X as I read it will hold the internal key number?
Clever use of the BASIC assembler, thanks.
Richard Russell
Re: IF INKEY-xy
Post by Richard Russell » Sun Jul 05, 2020 3:29 pm
As 1024MAK commented, the assembly language code does exactly the same thing as the BASIC INKEY() function. That returns zero (FALSE) if the key is not currently pressed and -1 (TRUE) if it is, so that's what X contains on return when you do it in assembler.
You can always experiment using BASIC code to find out what happens:
      A% = 129
      X% = -68 AND &FF
      Y% = (-68 AND &FF00) / 256
      REPEAT
        PRINT ~USR(&FFF4)
      UNTIL FALSE
USR returns a 32-bit integer containing PYXA so you can see at a glance what is in each register.
AJW
Re: IF INKEY-xy
Post by AJW » Sun Jul 05, 2020 6:28 pm
Strange how I can do:
LDX#(-102 AND&FF)
but not:
CPX#(-1)
It has to be 255
Re: IF INKEY-xy
Post by sweh » Sun Jul 05, 2020 7:06 pm
LDX#(-102 AND&FF)
but not:
CPX#(-1)
It has to be 255
In both case the value has to be between 0 and 255 (inclusive) so the equivalent would be
CPX#(-1 AND &FF)
Naomasa298
Re: IF INKEY-xy
Post by Naomasa298 » Sun Jul 05, 2020 7:09 pm
LDX#(-102 AND&FF)
but not:
CPX#(-1)
It has to be 255
I assume this is because (-1) will be interpreted as a 32 bit number (&FFFFFFFF), which you cannot compare against. Convert it to an 8 bit number.
CPX#(-1 AND &FF), which is the same as CPX#255 (since &FFFFFFFF AND &FF = 255).
AJW
Re: IF INKEY-xy
Post by AJW » Sun Jul 26, 2020 7:30 pm
Apparently theres a way of peeking at &EC and ED that's hundres of cycles faster than Osbyte &81. Surprised noone mentioned it.
Return to “programming”
