Sprite Areas... VDU redirection to...
On RISC OS was it possible to redirect the VDU stream to a sprite area, ( or alternatively to a specific window with the WIMP) and then use the normal VDU and PLOT commands?
I was considering if I suggested something to certain other developers of more recent implementations, but wanted to make sure I understand the older ways of doing things first.
Re: Sprite Areas... VDU redirection to...
Yes - OS_SpriteOp 60 does it. A quick trawl through my Programmer's Reference manuals seems to indicate that this came in with RISC OS 2 (i.e. post Arthur).
And used in things like SmallTask which ran as a Wimp application and redirected a single-tasking application's output to the multi-tasking desktop window.
The suggestion I was going to make to other developers was that someone implements an equivalent of OS_SpriteOP as a procedure library on modern implementations of BBC BASIC.
In BBC BASIC for SDL, IMGLIB allows for a 'sprite' to be loaded from a file... ( Writing an importer for RISC OS style sprite areas would be a third party extension to it.) MUTLWIN has code to save and restore the VDU variables on a context switch. It doesn't seem unfeasible for a third-party to figure out how to combine these to have teh ability for VDU commands to be rendered on 'Surfaces' as well as 'Windows'... Hmmm...Struck out comment, see comments further..
- Richard Russell
Both BBC BASIC for Windows and BBC BASIC for SDL 2.0 also allow you to redirect the VDU stream to another window (their respective MULTIWIN libraries do that) or to an in-memory surface/texture. The latter approach is used in many of David Williams' games, in which he draws graphics and/or text to a surface/texture that can be subsequently 'blitted' on demand.alex_farlie wrote: ↑Fri Jun 05, 2020 8:03 amIOn RISC OS was it possible to redirect the VDU stream to a sprite area, ( or alternatively to a specific window with the WIMP) and then use the normal VDU and PLOT commands?
In both of my dialects this can be achieved because the @memhdc% system variable contains the destination Device Context (BB4W) or Renderer (BBCSDL) to which all text and graphics are drawn. By changing the bitmap (BB4W) or texture (BBCSDL) selected into @memhdc% you can redirect the output elsewhere. The only caveat is that you must be very careful to restore the original destination (e.g. on an error).
So, unless I've missed something, what you are asking for can not only already be achieved but is a technique used in many existing BB4W and BBCSDL programs; it doesn't require me or a "third party" to implement something new. Of course if you are including Matrix Brandy in your set of 'modern' BBC BASICs it may be that currently it isn't able to do all those things, but I can't comment on that.
Thank you. It seems I'm over-thinking things. I need to re-read the documentation for the libraries you mention.Richard Russell wrote: ↑Fri Jun 05, 2020 10:01 amBoth BBC BASIC for Windows and BBC BASIC for SDL 2.0 also allow you to redirect the VDU stream to another window (their respective MULTIWIN libraries do that) or to an in-memory surface/texture. The latter approach is used in many of David Williams' games, in which he draws graphics and/or text to a surface/texture that can be subsequently 'blitted' on demand.alex_farlie wrote: ↑Fri Jun 05, 2020 8:03 amIOn RISC OS was it possible to redirect the VDU stream to a sprite area, ( or alternatively to a specific window with the WIMP) and then use the normal VDU and PLOT commands?
Looking at the libary code, it's seems to create a 'sprite' area under BBC BASIC for SDL, what needs to be created is a new "Texture" and then selecting that into @memhdc% with "SDL_SetRenderTarget", and swapping the VDU context.. This seems like a simplified version of the code from MULTIWIN in a simplified form (as there isn't depending on the application the need to create a new window, or render context.)Richard Russell wrote: ↑Fri Jun 05, 2020 10:01 amSo, unless I've missed something, what you are asking for can not only already be achieved but is a technique used in many existing BB4W and BBCSDL programs; it doesn't require me or a "third party" to implement something new. Of course if you are including Matrix Brandy in your set of 'modern' BBC BASICs it may be that currently it isn't able to do all those things, but I can't comment on that.alex_farlie wrote: ↑Fri Jun 05, 2020 8:03 amIOn RISC OS was it possible to redirect the VDU stream to a sprite area, ( or alternatively to a specific window with the WIMP) and then use the normal VDU and PLOT commands?
A "sprite" created in this way could then be plotted using the routine in IMGLIB.
No new functions needed, as FNmake_a_sprite(w,h) and PROC_vdutosprite(x) being things I could write myself .
- Richard Russell
I wasn't suggesting that you adapt the code in MULTIWIN (which redirects the output to a new window) in order to redirect the output to a new bitmap/texture; obviously these are rather different in detail. I've listed below the code to do the latter.alex_farlie wrote: ↑Fri Jun 05, 2020 11:05 amLooking at the libary code, it's seems to create a 'sprite' area under BBC BASIC for SDL, what needs to be created is a new "Texture" and then selecting that into @memhdc% with "SDL_SetRenderTarget", and swapping the VDU context.
Well, if you want to create a 'sprite' in a file, such as could then be plotted using IMGLIB, then no output redirection is required! To do that you can simply draw to any rectangular region of the output window (e.g. a graphics viewport) in the usual way and then *SCREENSAVE it to a file. To prevent the drawn graphic being visible, even momentarily, you can temporarily disable the output using *REFRESH OFF.A "sprite" created in this way could then be plotted using the routine in IMGLIB.
Thinking in terms of redirecting the output in that case, whether to another window or to an in-memory bitmap/texture, is an unnecessary complication and would result in cross-platform incompatibility for no reason.
REM Demo of drawing to an in-memory bitmap (BB4W) or texture (BBCSDL)
bmw% = 160 : REM bitmap/texture width
bmh% = 120 : REM bitmap/texture height
REM Create the in-memory bitmap or texture:
IF INKEY$(-256) = "W" THEN
SYS "CreateCompatibleBitmap", @memhdc%, bmw%, bmh% TO newDest%
newDest%% = newDest%
ELSE
SYS "SDL_CreateTexture", @memhdc%, &16362004, 2, bmw%, bmh% TO newDest%%
IF @platform% AND &40 ELSE newDest%% = !^newDest%%
ENDIF
REM Protect from errors using an SEH block:
ok% = FALSE
ON ERROR LOCAL IF FALSE THEN
*REFRESH OFF
REM Save the original destination and select the new destination:
SYS "SelectObject", @memhdc%, newDest%% TO oldDest%
oldDest%% = oldDest%
ELSE
SYS "SDL_GetRenderTarget", @memhdc% TO oldDest%%
SYS "SDL_SetRenderTarget", @memhdc%, newDest%%
IF @platform% AND &40 ELSE oldDest%% = !^oldDest%%
ENDIF
REM Draw into the memory bitmap/texture:
GCOL 128+11 : GCOL 4
CLG : VDU 5,30 : PRINT "Hello world!";
ok% = TRUE
ENDIF : RESTORE ERROR
REM Restore original destination:
SYS "SelectObject", @memhdc%, oldDest%%
ELSE
SYS "SDL_SetRenderTarget", @memhdc%, oldDest%%
ENDIF
*REFRESH ON
REM Check for an error having occurred:
IF NOT ok% ERROR ERR, REPORT$
REM Do something with the in-memory bitmap/texture:
REM (left to the imagination)
REM Delete the bitmap/texture:
SYS "DeleteObject", newDest%%
ELSE
SYS "SDL_DestroyTexture", newDest%%, @memhdc%
ENDIF
END
Thank you again.Richard Russell wrote: ↑Fri Jun 05, 2020 11:42 amI wasn't suggesting that you adapt the code in MULTIWIN (which redirects the output to a new window) in order to redirect the output to a new bitmap/texture; obviously these are rather different in detail. I've listed below the code to do the latter.alex_farlie wrote: ↑Fri Jun 05, 2020 11:05 amLooking at the libary code, it's seems to create a 'sprite' area under BBC BASIC for SDL, what needs to be created is a new "Texture" and then selecting that into @memhdc% with "SDL_SetRenderTarget", and swapping the VDU context.
In respect of BBC BASIC for SDL, the texture "handle" returned by your code, can be supplied directly to the PROC_imgPlot routine in IMGLIB
Goes off to write up a wiki-page. Are you okay with the example code above being quoted on the BBC BASIC Programmers Reference wiki?)
- Richard Russell
Maybe, but it's a complicated approach (and incompatible with BB4W) compared with creating a file. Also IMGLIB won't automatically delete the texture as it would if loaded from file. I know some people have a dislike of creating temporary files, but modern Operating Systems handle file-cacheing so efficiently it's hardly any worse than keeping everything in memory.alex_farlie wrote: ↑Fri Jun 05, 2020 12:01 pmn respect of BBC BASIC for SDL, the texture "handle" returned by your code, can be supplied directly to the PROC_imgPlot routine in IMGLIB
No need, I've already done it: https://www.bbcbasic.co.uk/wiki/doku.ph ... ap_textureGoes off to write up a wiki-page.
