Incrementing a 2-byte number
Naomasa298
Post by Naomasa298 » Wed May 27, 2020 3:37 am
Can someone tell me if I'm missing something here:
This:
INC &70
BNE skiphigh
INC &71
.skiphigh
is faster than:
CLC
LDA &70
ADC #1
STA &70
LDA #0
ADC &71
STA &71
The first takes 12 cycles if the high byte needs to be incremented, 8 cycles if not.
The second takes 18 cycles.
Or have I got this completely wrong?
Re: Incrementing a 2-byte number
Post by jgharston » Wed May 27, 2020 5:18 am
Nope, perfectly correct, and a standard programming paradigm for a multi-byte increment.
cmorley
Post by cmorley » Wed May 27, 2020 7:37 am
Worth noting too that the first is 6 bytes and the second is 13 bytes so a big code space saving.
Naomasa298
Post by Naomasa298 » Wed May 27, 2020 11:21 am
Thanks to you both!
Oh, I didn't know that. I thought I'd just been really clever there for a minute. :lol:
VectorEyes
Post by VectorEyes » Wed May 27, 2020 12:18 pm
This is a great example of the various trade-offs you have to make when optimising code for space vs. speed, but there are other considerations as well: side-effects (or lack thereof) and cycle timing predictability.
INC &70
BNE skiphigh
INC &71
.skiphigh
Takes: Either 8 or 12 cycles. (No good if you need it always to take the same number of cycles).
Doesn't affect A.
N and Z flags set to either the result of incrementing the low byte, or the high.
CLC
LDA &70
ADC #1
STA &70
LDA #0
ADC &71
STA &71
Takes: 18 cycles (good if you need consistent timings)
Sets A to high byte of result (which you might want to immediately use).
N, V, Z and C flags set to result of incrementing the high byte.
kieranhj
Post by kieranhj » Wed May 27, 2020 2:06 pm
The more masochistic cycle-counter might do...
INC &70         ; 5c
BNE skiphigh
; not taken     ; 2c
INC &71         ; 5c
BNE done        ; 3c (unlikely to be incrementing &FFFF or use BRA)
.skiphigh
; branch taken  ; 3c
NOP             ; 2c
NOP             ; 2c
.done
; constant time ; 15c
; total         ; 12 bytes
:wink:
0xC0DE
Post by 0xC0DE » Wed May 27, 2020 3:20 pm
Did somebody call me? :lol:
0xC0DE
:arrow: Follow me on Twitter
:arrow: Visit my YouTube channel featuring my demos for Acorn Electron and BBC Micro
dp11
Post by dp11 » Wed May 27, 2020 4:31 pm
........ cut ....................
; total         ; 12 bytes
:wink:
I'll raise you this code :
INC &70         ; 5c
BEQ inchigh   ; 2/3c
BNE skip1	     ;3c
.skip1
BNE done     ;3c
.inchigh
INC &71         ; 5c
.done
; constant time ; 13c
; total         ; 10 bytes
if I have my maths right
kieranhj
Post by kieranhj » Wed May 27, 2020 5:34 pm
INC &70         ; 5c
BEQ inchigh   ; 2/3c
BNE skip1	     ;3c
.skip1
BNE done     ;3c
.inchigh
INC &71         ; 5c
.done
; total         ; 10 bytes
=D> Very nice! There's always another cycle to be squeezed when you need it most. [-o<
Naomasa298
Post by Naomasa298 » Wed May 27, 2020 5:39 pm
Dear god, you people...
:wink: =D>
VectorEyes
Post by VectorEyes » Wed May 27, 2020 5:56 pm
Now try doing this when the preceding and following code is writing to the CRTC registers, which are 1MHz, so you have to take account of whether each CPU cycle is on an even or odd 1MHz tick and adjust the timings for STA <register> accordingly because of cycle-stretching... :D
Post by sweh » Thu May 28, 2020 12:55 am
You should see the work MartinB originally did for UPURS and then Dave (hoglet)'s updates. To bit-bang the User Port at 115,200 baud you only have 8.68us per bit, on average! And part of that is spent at 1Mhz 'cos of slow-bus access... Amazing work by both of them!
Post by tricky » Thu May 28, 2020 6:25 am
Also, watch out for crossing a page boundary with the branches! Iirc
Post by jgharston » Thu May 28, 2020 10:04 pm
I worked out a multi-byte decrement, and was really pleased with myself, then turned over a page in Zaks, and there it was! :)
Post by MartinB » Thu May 28, 2020 11:31 pm
sweh wrote:You should see the work MartinB originally did for UPURS and then Dave (hoglet)'s updates. To bit-bang the User Port at 115,200 baud you only have 8.68us per bit, on average! And part of that is spent at 1Mhz 'cos of slow-bus access....
Thank-you Stephen, you are very kind sir! 8)
I’m certainly no games programmer and have always admired what folks achieve by chasing the screen around at cycle level. I did actually have one such foray with a game called Clowns over on RS (as it was) and I learned a lot from our own RTW but in the end I think I just burned out.
Then later, when I conceived UPURS, I was suddenly thrown in at the deep end again and I was forced to spend countless hours sharpening my skills at cycle juggling because it was either right and working to a cycle or fatally busted - there was no middle ground. Mixing this with variable-speed hardware was an additional challenge but ultimately very satisfying.
I certainly appreciate why threads like this have a curious magnetism for us retro-programmers..... :)
Return to “programming”
