Mode 7 flip between pages
pixelblip
Post by pixelblip » Thu Oct 17, 2019 5:52 am
Hi there
I've been using Kieran's excellent Image to mode 7 converter. I am achieving new things with it! Really good bit of software I think you will all agree :D
Does anyone have any suggestions - I have a number of mode 7 images in edit tf at the moment . 7 of them.
I want to animate them. So my question is what format do I save them in from Edit tf to display on a beeb and also is there some code to load a series of mode 7 pages then flip between them quickly?
I do have another request but I'll pop that somewhere else....
Thanks for your help if you can offer any.
Re: Mode 7 flip between pages
Post by jgharston » Thu Oct 17, 2019 1:07 pm
As it's only 1K the simplest is a fast copy loop.
\ (src)=>start of source data
LDA #19:JSR OSBYTE :\ Wait for VSync
LDX #4:LDY #0
LDA #&7C:STA dst+1:STY dst+0
.loop
LDA (src),Y:STA (dst),Y
INY:BNE loop:DEX:BNE loop
RTS
pixelblip
Post by pixelblip » Thu Oct 17, 2019 6:20 pm
Thank you jgharston....I'll see if I can work that out......I'm no assembly expert and a real novice.....lets see...
dp11
Post by dp11 » Thu Oct 17, 2019 7:53 pm
LDX #4:LDY #0
.loop
RTS
The copy loop needs a little more work I think. It copies the same page 4 times
Post by jgharston » Thu Oct 17, 2019 9:47 pm
I was posting from work!
LDX #4:LDY #0
.loop
INY:BNE loop
INC src+1:INC dst+1
DEX:BNE loop
RTS
Andrew_Waite
Post by Andrew_Waite » Sun Nov 10, 2019 4:06 am
I think that the two programs below do something similar to what you are looking to achieve. They create animated images of Miner Willy and Technician Ted walking across the screen of the BBC Micro. Both programs create 20 different Mode 7 screens in the Beeb's main memory, then change registers 12 and 13 of the 6845 CRT controller chip to change the 'Display Start Address' to cycle through the 20 screens to produce the animated images of Miner Willy and Technician Ted.
Miner Willy :
viewtopic.php?t=14919&start=120#p218814
Technician Ted :
viewtopic.php?t=14919&start=120#p218885
Post by jgharston » Sun Nov 10, 2019 12:57 pm
I think that the two programs below do something similar to what you are looking to achieve. They create animated images of Miner Willy and Technician Ted walking across the screen of the BBC micro. Both programs create 20 different Mode 7 screens in the Beeb's main memory, then change registers 12 and 13 of the 6845 CRT controller chip to change the 'Display Start Address' to cycle through the 20 screens to produce the animated images of Miner Willy and Technician Ted.
This is a simple program that displays something then lets you scroll through memory. It can clearly be optimised.
   10 MODE7
   20 *ROMS
   30 *FX4,1
   40 ADDR%=&7C00
   50 REPEAT
   60 *FX19
   70 VDU23;12,((ADDR%DIV256)-&74)EOR&20;0;0;0
   80 VDU23;13,ADDR%;0;0;0
   90 A$=GET$
  100 IF A$=CHR$&8A:ADDR%=ADDR%+40
  110 IF A$=CHR$&8B:ADDR%=ADDR%-40
  120 ADDR%=ADDR% AND &FFFF
  130 UNTIL FALSE
Lardo Boffin
Post by Lardo Boffin » Sun Nov 10, 2019 3:10 pm
I didn’t know you could do that with Mode 7.
Could you double buffer mode 7 doing that? As opposed to 20 buffer!
Atom, issue 5
USA Model B
Post by jgharston » Sun Nov 10, 2019 8:16 pm
Yeah, I was sure that the MODE 7 screen was hardwired to the top 1K of RAM. I tested my posted code on BeebEm not on real hardware. My nagging suspicion is that with five address lines tied high on IC11, and only MA0-MA9 are passed through to the RAM, that forces the MODE 7 screen to be within the top 1024 bytes of screen RAM.
pixelblip
Post by pixelblip » Tue Nov 12, 2019 7:22 am
Thank you everyone that has been really useful and helpful. Interesting. I will study the code.
kieranhj
Post by kieranhj » Tue Nov 12, 2019 9:09 pm
It’s been long established that with CRTC linear addressing mode, as used for MODE 7, the screen address is generally restricted to the top 1024 bytes of lower RAM, so &7C00 to &7FFF. However on Model B there is also a mapping to &3C00 which can be used for buffer swapping. Sadly this isn’t available on Master, although you could swap SHADOW RAM in.
(Perhaps paging in 20K to buffer a 1K screen is a bit overkill, particularly when you can copy 1000 bytes reasonably quickly with an unrolled loop during vblank.)
Lardo Boffin
Post by Lardo Boffin » Tue Nov 12, 2019 11:25 pm
How would you go about using the &3C00 buffer process?
Atom, issue 5
USA Model B
kieranhj
Post by kieranhj » Wed Nov 13, 2019 10:54 pm
I’m sure there are some practical posts on here or maybe the old RetroSoftware programming forum. Otherwise check out the technical details on BeebWiki: http://beebwiki.mdfs.net/Address_translation#TTX_VDU
