Determining Graphics Modes
julie_m
Post by julie_m » Fri Sep 06, 2019 10:43 pm
Is there a proper way (e.g. an OSBYTE call) of determining the current screen mode which is portable across all the 6502-based BBC models?
I know about reading &355 on OS1.2 (model B), but does this also work on the Master 128 &c.? And what about running on a second processor, at the other end of the Tube?
Thanks in advance. J.
dv8
Re: Determining Graphics Modes
Post by dv8 » Sat Sep 07, 2019 12:20 am
OSBYTE &87 (135) returns the current screen mode in Y.
The value returned is always 0-7 regardless of whether a shadow mode (128-135) is in use.
&355 can be used on both the Model B and Master but only by code running on the i/o processor, it won't work across the Tube. The OSBYTE call should be used in preference to directly accessing the MOS variables.
tom_seddon
Post by tom_seddon » Sat Sep 07, 2019 12:32 am
$0355 is one of the VDU variables, which you can query using osbyte $a0. And on B+/M128, shadow RAM state is bit 4 of the VDU status byte, which you can query using osbyte $75. I assume that bit of the VDU status byte is always clear on the B? - might be worth checking the system type with osbyte $00, I don't know.
To restore the mode so detected, I think you just need to select modes 0-7 if shadow RAM off and modes 128-135 if shadow RAM on - then you'll always get the right result.
BeebWiki has a similar suggestion: http://beebwiki.mdfs.net/Reading_screen_mode - though it uses osbyte $87 to read the mode. That's an option, but I figure you might as well just read the VDU variables, the layout of which appears to be part of the API, judging by the Master Reference Manual part 1. (which is an excellent resource, being quite comprehensive, and about as modern and official a reference for the 8-bit Acorn MOS API as you'll find...)
--Tom
julie_m
Post by julie_m » Sat Sep 07, 2019 1:11 am
Brilliant. Thanks very much! I remember OSBYTE &87 on the BBC as being roughly equivalent to SCREEN$ on the Spectrum ..... forgot all about Y, though.
BCP (rather boringly) is not making any direct writes to screen memory, so it does not need to know if or not shadow memory is in use. I just need to know how many colours are available.
Post by jgharston » Sat Sep 07, 2019 10:17 am
It's not an option, it's *THE* *SPECIFIED* API.
Use OSBYTE &87, as that is the defined API to ask for the screen mode. Reading the VDU variable is reading a VDU variable, &0355 just /happens/ to just happen to contain a number related to the current screen MODE. The OP *SPECIFICALLY* asked for compatibility across all platforms. If the platform you're running on has extra MODEs, it's close to impossible that &355 will contain the MODE number - and in fact will destroy the functioning of the VDU drivers if it doesn't contain 0-7 - but the defined API for asking for the screen MODE - OSBYTE &87 - is the one that is able to be intercepted and changed.
Post by jgharston » Sat Sep 07, 2019 10:22 am
That's a different question. If you want to know how many colours are available, the question is "how many colours are available?" not "what is the current screen MODE?"
OSBYTE 160,96 returns the colour mask - the maximum number of colours minus 1 (which will be zero for MODE 7).
Post by Rich Talbot-Watkins » Sat Sep 07, 2019 12:37 pm
Although that's also reading a VDU variable, so that's as tied to an Acorn 8-bit platform as reading the current mode via VDU variable &55. On RISC OS you'd do it via SWI OS_ReadModeVariable, 3 (or 9).
I think if you're specifically targeting an Acorn 8-bit platform, reading the current mode via the VDU variable is just as valid as using OSBYTE 135 (and certainly quicker).
Last edited by Rich Talbot-Watkins on Sat Sep 07, 2019 1:01 pm, edited 1 time in total.
Return to “programming”
