Streaming sound from disk on a BBC Micro
pixelblip
Post by pixelblip » Thu Aug 08, 2019 8:41 pm
Hi
Do you think it's possible (or has anyone done it) streaming samples from disk on the BBC micro?
I know sample resolution is in 1 bit........I am just curious what could be achieved......and could it be done in Mode 2?
My aim might be to show some colour cycled pics with streaming audio. That could be fun.
I do appreciate the quality will be very poor but ....back in the day hearing any sampled sound was totally amazing........I do remember hearing a few demos back then and thought wow that's so cool.
I might also try a few pics with some Music 5000 music anyway.....maybe that might have to be Mode 7 pics....but this got me thinking....could it be done in Mode 2 with some sampled sound. Hmmmm :)
Oh just found this so maybe it's a yes....
https://www.youtube.com/watch?v=TMEtjLur4uM
Re: Streaming sound from disk on a BBC Micro
Post by tricky » Thu Aug 08, 2019 9:07 pm
I think you would need some serious compression to play samples from a floppy, but bitshifters did get the teletext version of BadApple streaming of real hardware.
cmorley
Post by cmorley » Thu Aug 08, 2019 9:59 pm
I just did a speed test on my B with 8271 & a real floppy. It will read 32K in 4s. 4K/s would be enough to stream either chiptune and/or sampled sound... I suppose you can do work, poll, do work, poll to reduce interrupt overhead if need be.
It'd be fairly low bitrate & bit depth digital audio but not impossible.
Easier would be ADFS and a hard disk/BeebSCSI.
pixelblip
Post by pixelblip » Fri Aug 09, 2019 7:23 am
Thanks for doing those tests.
If anyone has done this before and has any code or routines or is up for this please let us know.
I can get by in basic but that’s about it.......it’s going to need some 6502 isnt it...maybe one day I’ll sit down and learn it :D
Thanks all
Post by tricky » Fri Aug 09, 2019 9:38 am
Bitshifters Bad Apple
How much audio do you need, as at 8KB/s A disk (or two) won't last too long.
Post by steve3000 » Fri Aug 09, 2019 2:16 pm
I thought about whether streaming sampled sound would be possible back when I did my Bad Apple conversion, and although I didn't get round to writing any sound streaming code, I came to the conclusion that you would probably be able to do something interesting along these lines using a MMC/SD card interface...
pixelblip
Post by pixelblip » Fri Aug 09, 2019 6:14 pm
Thanks all.....
Not sure how long the clips would be. I guess it would more be a question of how many seconds can I get with say 5 mode 2 pictures on a floppy disk?
It doesn't have to be a floppy but I guess people would like it as an ssd or dsd ........
If each picture could have a loop of sound say 5 seconds each that would be cool.
scarybeasts
Post by scarybeasts » Tue Jun 02, 2020 10:52 pm
Just came across this older thread and wanted to link to this newer thread where I've implemented full-disc disc streaming: viewtopic.php?f=64&t=19549
Chris
Return to “programming”
