BBC BASIC: DEFPROC "promotes" local integer variables?
Post by lurkio » Fri Jul 12, 2019 12:33 am
I was rummaging around in the listings for To Hell In A Hamper when I noticed what I thought was a surprising way of passing integer values between BASIC programs on the Beeb when a program CHAINs another program.
It seems that if the parameter to a procedure has the name of one of the resident integer variables -- say J% -- and if that procedure then CHAINs another program, then the value of J% inside the procedure in the first program -- where I presume J% is implicitly a LOCAL variable -- seems to be transferred to the "global" resident integer variable J% and is available to the CHAINed program.
Here's Example Program 1:
 10 J%=0
 20 PRINT J%
 30 PROCa(10)
 40 PRINT J%
 50 PROCb(10)
 60 END
 70 DEFPROCa(J%)
 80 J%=J%+1
 90 ENDPROC
100 DEFPROCb(J%)
110 CHAIN"2"
120 ENDPROC
And here's Example Program 2, which is CHAINed by Example Program 1:
10 PRINT'J%
The output on screen when you run program 1 (which CHAINs program 2) is as follows:
0
10
Is this behaviour well known and/or documented? I've never come across it before, and I wouldn't have expected it to work because I wouldn't expect the value of the implicit LOCAL variable J% in DEFPROCb in program 1 to be transferred to program 2 at all.
Re: BBC BASIC: DEFPROC "promotes" local integer variables?
Post by jgharston » Fri Jul 12, 2019 12:55 am
Yep, it's documented. CHAIN does not change any of A%-Z% regardless of how A%-Z% have been set at the point of the CHAIN.
The only thing that restores local variables to their previous value is ENDPROC or =returnval. There's really no such thing as "local" variables in BBC BASIC, there are only "current" variables and "saved" variables.
Richard Russell
Post by Richard Russell » Fri Jul 12, 2019 9:26 pm
Yes. Understanding that BBC BASIC doesn't have 'local' variables in the traditional sense can be important, such as what happens if you exit from a FN or PROC via any mechanism other than the = or ENDPROC (e.g. an ON ERROR); in that case the 'saved' variables never get restored and the 'local' variables suddenly become 'global'!
What would be really useful is a statement that restores those saved variables without exiting from the FN/PROC, so that in the event of a trappable error being detected you could restore them before activating the error handler. So useful in fact that I have added exactly that to BBC BASIC for Windows and BBC BASIC for SDL 2.0: RESTORE LOCAL. I suspect this could easily be added to any BBC BASIC interpreter, since it doesn't need any new keywords and is activating a mechanism that must already exist.
Rich Talbot-Watkins
Post by Rich Talbot-Watkins » Mon Jul 15, 2019 11:28 am
Also, consider the following:
10 PROCp(23)
20 PRINT a%
30 END
40 DEF PROCp(a%)
50 PRINT a%
60 ENDPROC
a% continues to exist outside PROCp after it's called (albeit with a default value) - which is something you wouldn't expect if it was genuinely a local variable. Acorn BBC BASIC has no way of deleting a variable which has been defined (other than the nuclear option, CLEAR!) - don't know if that's also true of Richard's BASICs, but I don't imagine there to be much reason to support it because of the way BBC BASIC works.
Richard Russell
Post by Richard Russell » Mon Jul 15, 2019 12:52 pm
The way the heap is managed means that you cannot 'delete' a local object (other than via CLEAR as you say), all you can do is to set it to zero or some other special value. The effect of that differs depending on the kind of object it is: if it's a scalar variable then afterwards the variable 'exists' but has the value zero (and is thus indistinguishable from an ordinary global variable). However if it's a local array (or in the case of my BASICs a local structure) then what's stored in the heap is a pointer, and setting that pointer to zero does establish a state different from an ordinary global object of the same type.
Contrast the program you listed with this one:
   10 PROCp
   20 PRINT a(5)
   30 END
   40 DEF PROCp
   50 LOCAL a()
   60 DIM a(9)
   70 a(5) = 23
   80 PRINT a(5)
   90 ENDPROC
Now the PRINT statement at line 20 reports an error ("Bad use of array" in BB4W/BBCSDL and "Undimensioned array" in ARM BASIC V) so although it hasn't been 'deleted' it is distinguishable from a global array.
Rich Talbot-Watkins
Post by Rich Talbot-Watkins » Mon Jul 15, 2019 1:43 pm
Can you redimension it outside the PROC in this case? Normally that's not allowed, but is there special dispensation given to arrays which have been nullified in this way? (I would assume it works, otherwise it wouldn't be possible to call PROCp more than once!)
Post by lurkio » Mon Jul 15, 2019 4:13 pm
Never knew that. How curious.
>LIST
   10 ON ERROR PRINT a$:END
   20 a$="hello"
   30 PROCa
   40 END
   50 DEFPROCa:LOCAL a$
   60  a$="goodbye"
   70  thisIsAnError
   80 ENDPROC
>RUN
goodbye
>PRINT a$
goodbye
EDITED to add this:
10 PROCp(23)
20 PRINT a%
30 END
40 DEF PROCp(a%)
50 PRINT a%
60 ENDPROC
This is quite an eye-opener. Here's the effect demonstrated in greater detail:
>LIST
   10 ON ERROR PRINT "Error: a% doesn't 'exist'.":GOTO 30
   20 PRINT a%
   30 PROCa
   40 PRINT "Suddenly a% exists and its value is ";a%;"."
   50 END
   60 DEFPROCa:LOCAL a%
   70 PRINT "PROCa has been called."
   80 ENDPROC
>RUN
Suddenly a% exists and its value is 0.
:shock:
Richard Russell
Post by Richard Russell » Mon Jul 15, 2019 5:12 pm
Yes. The array wouldn't be 'local' in any meaningful sense if you couldn't.
Mind you ARM BASIC V has some quirks. For example by my reckoning this ought to work; it does in my BASICs but for some reason it doesn't in ARM BASIC:
   10 PROCp(a())
   20 a(5) = 23
   30 PRINT a(5)
   40 END
   50
   60 DEF PROCp(RETURN a())
   70 DIM a(10)
   80 ENDPROC
ARM BASIC reports 'Undimensioned array at line 20', but it isn't undimensioned (it was dimensioned in line 70 and I've specified that it be RETURNed from the procedure). I have made use of that feature many times and I wouldn't want to be without it, so why it doesn't work in Acorn's versions I have no idea.
Richard Russell
Post by Richard Russell » Mon Jul 15, 2019 5:24 pm
I wouldn't exactly say "curious", it's what you would expect given the way BBC BASIC works, but it's a significant limitation that Acorn versions provide no way to work around it. RESTORE LOCAL allows an error to be passed back down the 'call chain', with local variables being restored at each level, so that each function is given the opportunity to do something in that event:
        ON ERROR PRINT "Error: " REPORT$ : END
        PROC1
        END
        DEF PROC1
        ON ERROR LOCAL RESTORE LOCAL : PRINT "Error handled in PROC1" : ERROR ERR,REPORT$
        PROC2
        ENDPROC
        DEF PROC2
        LOCAL A
        ON ERROR LOCAL RESTORE LOCAL : PRINT "Error handled in PROC2" : ERROR ERR,REPORT$
        A = 1/0
        ENDPROC
which reports:
Error: Division by zero
This is functionality I couldn't live without.
Return to “programming”
