GCC for RISC OS 3
Midar
GCC for RISC OS 3
Post by Midar » Tue Nov 06, 2018 10:39 pm
Hi!
I know there's GCC for newer versions of RISC OS, but the binaries generated by it do not work on RISC OS 3. This is not just a matter of 26 bit, which is easy to solve by compiler flags, but also missing SWIs used by crt.
Has anyone ever tried patching the crt and libc so that it still works with RISC OS 3? Or is there even a different GCC than the ROOL one, possibly even one for RISC OS 3?
flibble
Re: GCC for RISC OS 3
Post by flibble » Wed Nov 07, 2018 2:38 am
Not me
I think you might be confused, there are two compilers for RISC OS (ish), GCC and Norcroft (currently provided by ROOL). ROOL doesn't distro gcc.
If the current gcc, from riscos.info doesn't work on risc os 3, this version may be suitable (2.7.2)
http://www.drobe.co.uk/archives/index.p ... ang/c/gcc/
If you're looking for an older versions of the Norcroft compiler that work on RISC OS 3, this is it.
http://www.4corn.co.uk/articles/acornc5/
Midar
Post by Midar » Wed Nov 07, 2018 11:37 pm
That's right - by the ROOL one, I mean the riscos.info one. I was under the impression that this is targeting ROOL?
The ancient GCC might be useful to see if the crt could be used with a newer one. Maybe -nostartfiles -nostdlibs and then explicitly linking the old versions will be enough. I'll give that a try!
Midar
Post by Midar » Thu Dec 20, 2018 9:45 pm
I tried both now, however, I could not get either to work:
* gcc fails to find UnixLib. -mstubs also doesn't work to use a C library. I don't know which version I need for that and where to get it.
* The Acorn C compiler comes on 6 disks. I'm using adffs. When I run the installer on the first disk, it asks me to insert the second disk. When I do this, it asks me to insert the first disk again, but the popup is modal and I can no longer switch disks in adffs.
