The Dreaded goto
The Dreaded goto
Post by Coeus » Fri Nov 02, 2018 10:54 pm
I don't usually feel the call of the goto statement but what about this function:
int mmb_find(const char *name)
    const char *cat_ptr = mmb_cat + 16;
    const char *cat_end = mmb_cat + MMB_CAT_SIZE;
    const char *cat_nxt, *nam_ptr;
    int cat_ch, nam_ch, i;
    while (cat_ptr < cat_end) {
        cat_nxt = cat_ptr + 16;
        nam_ptr = name;
        do {
            if (cat_ptr == cat_nxt)
                goto found;
            cat_ch = *cat_ptr++;
            nam_ch = *nam_ptr++;
            if (!cat_ch && !nam_ch)
                goto found;
        } while (!((cat_ch ^ nam_ch) & 0x5f));
        cat_ptr = cat_nxt;
    return -1;
found:
    i = (cat_nxt - mmb_cat) / 16 - 2;
    log_debug("mmb: found MMB SSD '%s' at %d", name, i);
    return i;
this could be re-written without the gotos, keeping the same logic:
        nam_ptr = name;
        do {
            if (cat_ptr == cat_nxt|| (!(cat_ch = *cat_ptr++) && !(nam_ch = *nam_ptr++))) {
                return i;
        cat_ptr = cat_nxt;
    return -1;
Clearer? If not, any other alternatives?
Re: The Dreaded goto
Post by flaxcottage » Sat Nov 03, 2018 9:59 am
Best not to jump out of a loop. The second way is technically better.
Post by paulv » Sat Nov 03, 2018 10:06 am
The if evaluation took me a couple of reads as you have equality and assignation in the statement so on first read, it looks like you've missed a couple of = symbols out accidentally but they're actually correct as they are.
For clarity, it may be worth doing the assignation before the if rather than inline to avoid confusion.
EDIT: but that then means the code changes its behaviour so I see why you've done it inline. Just makes for the need for a more attentive read through the code.
Phlamethrower
Post by Phlamethrower » Sat Nov 03, 2018 1:15 pm
When goto's become ugly/confusing I tend to try and restructure the code into a subroutine, so that the goto's become return's:
static inline int cat_name_cmp(const char *nam_ptr, const char *cat_ptr)
    const char *cat_nxt = cat_ptr + 16;
    do {
        char cat_ch = *cat_ptr++;
        char nam_ch = *nam_ptr++;
            break;
        if ((cat_ch ^ nam_ch) & 0x5f)
            return -1;
    } while (cat_nxt != cat_ptr);
    return (cat_nxt - mmb_cat) / 16 - 2;
    int i;
    do {
        i = cat_name_cmp(name, cat_ptr);
        cat_ptr += 16;
    } while ((i == -1) && (cat_ptr < cat_end));
    if (i != -1)
    return i;
If the compiler's any good it should be able to inline the function, avoiding any inefficiencies that an actual function call would introduce. Of course if you're using a vintage compiler then it's not likely to be that good at optimisation, so if you're concerned about code size/speed then an ugly/confusing function may be the best option.
Diminished
Post by Diminished » Sat Nov 03, 2018 3:42 pm
I've sometimes resorted to "do { } while (0);" to avoid a goto (in which a break statement will jump you to the end of the block).
It's messy if you want to jump out of multiple blocks, though. The goto is probably clearer.
