RISCPC accessing parallel port in BASIC
Post by sydney » Fri May 11, 2018 10:55 am
The RISCPC has a bidirectional parallel port so I was hoping to do a bit of interfacing with arduinos or raspberry pi's with it. Is it possible to access the parallel port from BASIC or will I need to learn arm assembler?
Re: RISCPC accessing parallel port in BASIC
Post by RobC » Fri May 11, 2018 11:50 am
Have to admit that this isn't something I've done but the RISC OS Programmer's Reference Manual suggests that the Parallel_Op SWIs allow you to access the parallel port registers. You can access the OS SWI calls from BASIC using the SYS command.
Post by sydney » Fri May 11, 2018 12:39 pm
RobC wrote:Have to admit that this isn't something I've done but the RISC OS Programmer's Reference Manual suggests that the Parallel_Op SWIs allow you to access the parallel port registers. You can access the OS SWI calls from BASIC using the SYS command.
I'd read that page but was unsure how to use OS SWI calls. Trying to run before I can walk!
Post by RobC » Fri May 11, 2018 3:02 pm
There's some info on how to use the SYS command here.
From memory, it's fairly straightforward once you get used to it but it's years since I did any serious BASIC programming on RISC OS.
Might be worth playing with something like OS_Plot just to get started as it's like using the BASIC PLOT command.
sirbod
Post by sirbod » Sat May 12, 2018 6:00 am
From a brief look at the Parallel_Op documentation, I'd say you use Parallel_Op 2 to set the direction, then Parallel_Op 0 to read or Parallel_Op 1 to write.
Post by jgharston » Sat May 12, 2018 9:46 am
Something like:
SYS "Parallel_Op",2,0,NOT 32:REM Set as output
SYS "Parallel_Op",1,data:REM Write to parallel port
SYS "Parallel_Op",2,32,NOT 32:REM Set as input
SYS "Parallel_Op",0 TO ignore,data,status:REM Read from parallel port
The documentation doesn't actually say which way about bit 5 is to set input or output, so SYS "Parallel_Op",2,0,NOT 32 and SYS "Parallel_Op",2,32,NOT 32 may be the wrong way around.
