Risc OS RPI GPIO using BASIC
pixelblip
Post by pixelblip » Thu Mar 29, 2018 11:48 am
Hi there
This is a long shot.
Is it possible to program the Raspberry pi GPIO pins in BBC Basic on Risc OS at all?
It would make life much easier.
I am trying to fiddle around with it on Raspbian but Python is not my forte......it would be much nicer in BBC Basic ........I was mucking around with LED Matrix's
pixelblip
Re: Risc OS RPI GPIO using BASIC
Post by pixelblip » Thu Mar 29, 2018 11:54 am
Ah I found this....maybe it might be what I am looking for.....if anyone knows of any other links please shout.
REPEAT
SYS "GPIO_WriteData" ,17,1
SYS "GPIO_WriteData" ,17,0
UNTIL FALSE
https://www.raspberrypi.org/forums/view ... hp?t=22250
Post by flaxcottage » Thu Mar 29, 2018 12:52 pm
Yes, Tank's GPIO module is the one to go for. You have that.
Other ways to go include 'bare metal' programming of the GPIO pins in Assembler or to use BBC Basic in Linux which include easy access to the GPIO pins.
pixelblip
Post by pixelblip » Thu Mar 29, 2018 2:30 pm
Ahh thank you. What a lifesaver BBC basic will give you access to those
helpful
Post by helpful » Fri Mar 30, 2018 2:28 am
You should come along to the ROUGOL meeting on Monday 21st May, as our guest speaker will be Andrew Conroy who is bringing along a selection of his Raspberry Pi projects, all controlled using GPIO from BBC BASIC.
Andrew's stand at the SW Show
pixelblip
Post by pixelblip » Fri Mar 30, 2018 7:31 am
Thanks helpful that sounds right up my street. I will try to make that if I can get a day off work on Tues.
helpful
Post by helpful » Sun May 06, 2018 12:54 am
I've put up the info for this month's ROUGOL meeting here - viewtopic.php?f=25&t=15053
