I've just converted a utility from BASIC to 6502 assembly language and it runs fine except for one thing: if I *RUN it instead of *LOADing it then CALLing the code, it produces a Syntax Error when it exits.
I'm sure there's something I'm supposed to do before I return to BASIC or is my use of zero page addresses &70-&75 making BASIC unhappy?
Syntax Error after *RUN
Re: Syntax Error after *RUN
There should be no practical difference David and using &70-&75 is fine. I suspect you're doing something subtly wrong in your code such as, are you perhaps (example only) mistakenly using &0700 onwards (instead of &0070) which tends to be the keyboard input buffer? I think you are leaving some residual character(s) somewhere like that such that when you *RUN and return, BASIC subsequently tries to parse the debris.
- Rich Talbot-Watkins
- Contact:
Is it on the Electron? Something to do with this perhaps?
Ha! Your memory is way better than mine Rich!
I was thinking about the other thread because this program also uses OSFILE and I'd forgotten that it modifies the file block, so that was another problem-within-a-problem. But it looks like the same issue with loading from TAPE or ROM immediately after a reset. Loading another file first sidesteps the problem. Thanks for the reminder!
- Contact:
Still not really clear what this problem is, or whether it's an Electron only thing or not. But I've never ever been bitten by it myself!
FWIW it may have something to do with a bug in *RUN under CFS/RFS.
In BBC OS 1.20 and Electron OS 1.00 after *RUN loads the file it tries to update the OSFILE block with the length of the file, except that *RUN did not set the address (stored at &C8) of the OSFILE block. If !&C8 points into the code image some four bytes of it may be corrupted. Try:
which has *RUN safely copy the computed file length over itself. (Credit to John Kortink for finding this bug.)
*TAPE
!&C8=&C2
*RUN
Thanks for the tip, regregex, and welcome back!
