Hardware scrolling part of the screen
TobyLobster
Post by TobyLobster »
I was thinking about keeping the top four or five character rows of a MODE 2 screen fixed in position, then under a timed interrupt changing the CRTC register for the 'screen start address/8' when the electron beam has passed that point in order to horizontal scroll the rest of the screen. Then restoring the register back once the rest of the screen is displayed. Would this even work?
I could instead write (restore) the top part of the screen every update, but that takes a lot of time.
Re: Hardware scrolling part of the screen
Post by Rich Talbot-Watkins »
No, that won't work, because the CRTC only reloads its address counters from R12/13 at the end of its conceptual frame, i.e. when the vertical counter reaches R4.
But that helps us to consider how we might be able to achieve this! What if we tricked the CRTC into finishing its frame early, by setting the vertical total (R4) to a value midway down the screen? Then it would reload R12/13, and this time we would have to give it an R4 which genuinely takes it to the end of the PAL frame.
Turns out that this technique isn't particularly timing sensitive, and I wrote up how to do it in this article a few years back!
TobyLobster
Thanks Rich, that looks like exactly what I wanted! =D>
TobyLobster wrote:
Tue Oct 12, 2021 1:09 pm
Good luck getting it working! You'll find that the timing isn't particularly critical, but it's a bit fiddly to implement for the first time. Basically you just need two interrupt points - one at the top of the static area, and one at the top of the scrolling area (these days I would probably use User VIA timer 1 for that, using the latch to measure the two different periods of time). Remember to make sure interlace is off, or it won't work as expected, and remember you'll probably need to mess with the addressable latch to constrain the wrap-around to 16k in the scrolling part!
kieranhj
Post by kieranhj »
This reminds me I'm at least a year late to present the "Intro to CRTC Registers - part 2" which was intended to cover "Vertical Rupture" in some detail. :-k
TobyLobster
kieranhj wrote:
Wed Oct 13, 2021 11:53 am
Yes please!
Put together the most simple example I can manage of this, in Owlet.
TobyLobster
Rich Talbot-Watkins wrote:
Wed Oct 13, 2021 6:03 pm
Put together the most simple example I can manage of this...
Excellent, that's working nicely. Thanks again.
nicolagiacobbe
Post by nicolagiacobbe »
Thanks RTW. It is the easiest way I have found to dive into Vertical Rupture, I'll put it to good use soon.
Post by cmorley »
A very neat demo with some great comments. =D>
Return to “programming”
