PHA around JSR
AJW
PHA around JSR
Post by AJW » Sun Jun 28, 2020 11:02 pm
PHA:LDY&85:BEQno8:JSR clyr2:PLA
results in "at Line ____" error , but when PHA and PLA are removed it seemingly works. Can anyone explain why? And if not possible how to preserve the accumulator outside of the subroutine?
Re: PHA around JSR
Post by IanS » Sun Jun 28, 2020 11:09 pm
At compile time or run-time?
If the branch is taken you'll still need to pop the value back off the stack. Is the branch being taken?
(I'm a 6502 idiot, so may have missed the point entirely)
Naomasa298
Re: PHA around JSR
Post by Naomasa298 » Sun Jun 28, 2020 11:14 pm
I think IanS has got it. If the branch is taken and you're not pulling the value off the stack, then you have a problem.
Save the accumulator to memory. Stick it in a zero page location. It's faster than using the stack.
Re: PHA around JSR
Post by sweh » Sun Jun 28, 2020 11:20 pm
You probably want to put the PHA just before the JSR
LDY&85:BEQno8:PHA:JSR clyr2:PLA
AJW
Re: PHA around JSR
Post by AJW » Mon Jun 29, 2020 12:39 pm
Yes that works thanks.. This part isn't speed critical but I agree it's a good idea to use zero page as temporary store, or even better an absolute address as scratch area as they are 1 cycle faster?
Naomasa298
Re: PHA around JSR
Post by Naomasa298 » Mon Jun 29, 2020 12:46 pm
LDA and STA to zero page is 3 cycles. Absolute address is 4 cycles.
AJW
Re: PHA around JSR
Post by AJW » Mon Jun 29, 2020 12:55 pm
Correct I was confusing it with immediate.
Re: PHA around JSR
Post by sweh » Mon Jun 29, 2020 1:03 pm
Naomasa298 wrote:Save the accumulator to memory. Stick it in a zero page location. It's faster than using the stack.
PHA is one byte and takes 3 cycles; PLA is one byte and takes 7 cycles. So 2 bytes and 7 cycles.
STA &70 is 2 bytes and takes 3 cycles; LDA &70 is 2 bytes and takes 3 cycles. So 4 bytes and 6 cycles, and one (temp) storage byte.
Given the lack of memory on the Beeb, sometimes optimising for space is better than for speed. Othertimes, speed is better than space :-)
There are other tradeoffs possible as well; under certain circumstances if you don't care about X or Y registers and the subroutine doesn't modify them, then you can TAX/TAY (1 byte 2 cycles) and then TXA/TYA (1 byte 2 cycles) so only needs 2 bytes and 4 cycles :-)
Naomasa298
Re: PHA around JSR
Post by Naomasa298 » Mon Jun 29, 2020 1:30 pm
True. Though if you're wanting to save the X or Y registers, it's faster to store in ZP rather than TXA/PHA.
Re: PHA around JSR
Post by Coeus » Mon Jun 29, 2020 3:56 pm
So on this space vs. time tradoff, how about this from another post of mine:
       83E1: 48          PHA         ; Save all registers.
       83E2: 8A          TXA
       83E3: 48          PHA
       83E4: 98          TYA
       83E5: 48          PHA
       83E6: A9 84       LDA #84     ; add a new return address that points to the tail of this
       83E8: 48          PHA         ; subroutine which will pull the registers back off the stack.
       83E9: A9 03       LDA #03
       83EB: 48          PHA
       83EC: A0 05       LDY #05
       83EE: BA          TSX
       83EF: BD 07 01    LDA 0107,X  ; grab the return address of our caller and the registers
       83F2: 48          PHA         ; pushed at the start of this routine and push them back
       83F3: 88          DEY         ; on the top of the stack.
       83F4: D0 F8       BNE 83EE
       83F6: A0 0A       LDY #0A     ; now move the top ten bytes of the stack down two bytes
       83F8: BD 09 01    LDA 0109,X  ; removing the copy of the address of our immediate caller
       83FB: 9D 0B 01    STA 010B,X  ; burried the most deeply but leaving the values of the
       83FE: CA          DEX         ; registers pushed at the start of this routine.
       83FF: 88          DEY
       8400: D0 F6       BNE 83F8
       8402: 68          PLA         ; as we didn't adjust the stack pointer when we moved the stack
       8403: 68          PLA         ; down by two bytes, discard two bytes from the top.
       8404: 68          PLA         ; This bit is executed twice, once as part of the original call
       8405: A8          TAY         ; and then again when the calling subroutine returns to here.
       8406: 68          PLA
       8407: AA          TAX
       8408: 68          PLA
       8409: 60          RTS
the code comes from the DFS ROM (Acorn, Opus, Solidisk and Watford all share this). A call to this subroutine at the head of another subroutine takes three bytes whereas if that subroutine did PHA:TXA:PHA:TYA:PHA and then PLA:TAY:PLA:TAX:PLA at the end it would take ten bytes. Also the subroutine above leaves A unchanged. This extra subroutine is going to be much slower, though.
Re: PHA around JSR
Post by hoglet » Mon Jun 29, 2020 4:21 pm
Just in case anyone reading this is confused, there is a typo in the above. It should say:
PHA is one byte and takes 3 cycles; PLA is one byte and takes 4 cycles. So 2 bytes and 7 cycles.
Return to “programming”
