How do you edit your BASIC programs?
Re: How do you edit your BASIC programs?
Post by jgharston » Tue Jan 29, 2019 3:38 pm
Richard Russell wrote:
Tue Jan 29, 2019 1:40 pm
lurkio wrote:
Tue Jan 29, 2019 9:37 am
Just to clarify: you’re looking for BASIC code that would construct a blank .SSD in memory; add a file to the .SSD — the content of the file being a tokenised BASIC program which the user has been editing and wants to test in BeebEm (or another emulator); and then write the .SSD to a file on the host filesystem?
Yes, that's one option.
MkImg creates disk images from a specified list of files, and is written in BASIC, so the core can be ripped out of it. The simplest way to create a disk image is just the catalogue followed by each file, one after another, each padded to 256 bytes. BeebEm can be started up with a disk image selected on the command line, eg BeebEm filename.ssd, and if the boot option is set it boots it as though Shift-Break has been pressed (and the correct filing system is the default for the selected disk image).
Post by jgharston » Tue Jan 29, 2019 3:44 pm
Sat Jan 26, 2019 5:30 pm
I've been experimenting with doing that using BeebEm, but it's seemingly not as straightforward as I expected. What's the simplest way of running a BASIC program from the Windows command line? Will I have to make a .ssd or .uef file, and if so which is the simpler of the two to build? Do any of the other Beeb emulators make it any easier?
The -KbdCmd option allows a string of key presses to be passed to BeebEm. So, if you have VDFS loaded and enabled by default (which gives you access to the host machine's file system), something like:
BeebEm -KbdCmd *VDFS\nCHAIN\s2\Sfilename\s2\S\n
I haven't checked if this is subject to the size of the keyboard buffer, or if it is fed in from a "higher" level.
Edit: Ah ha. It is 'typed' into the system, and depends on your keyboard map, and is specified by keynames, not characters. So, on my system:
C:\Apps\Emulators\BeebEm\BeebEm.exe -KbdCmd \s'\SVDFS\nCHAIN\s2\S'H.DEVELOP.BASICTESTS.COLOURS\s2\S\n
selects VDFS and CHAINs "H:\Develop\BasicTests\Colours"
Post by lurkio » Tue Jan 29, 2019 3:51 pm
Tue Jan 29, 2019 3:22 pm
lurkio wrote:
Tue Jan 29, 2019 2:54 pm
I suppose I was thinking more of the delay while the user waits for the program encoded in the UEF to load into the emulated Beeb's memory from the emulated cassette recorder.
So is the default to load at the same speed as a real Beeb would load from a tape?
Yes. For most, if not all, Beeb emulators, that seems to be the case. It's certainly true of BeebEm.
I might argue that's taking emulation too far!
Some original tape software from BITD had clever loaders that did "entertaining" things -- like printing "humorous" messages on screen -- while the large main program was loading. We'd miss out on such rich amusements if tape loading wasn't emulated in real time. :wink:
what about leveraging the ROM Filing System?
Is that actually much faster than loading from tape? I use RFS a bit because it's part of the utility software for my modern SWROM/SWRAM board in my real Beeb, and it doesn't strike me as being fast -- or it's not as fast as disc, anyway.
I do think that the most user-friendly way to achieve what you seem to be aiming for is to create a .SSD: most (probably all) Beeb emulators start up in Model B mode, with DFS installed, by default; and programs are quick to load from .SSD; and you won't need to rely on software or utility ROMs that don't come as part of the standard BeebEm installation package. I strongly suspect that that's why the creators of BeebAsm chose to export assembled code to .SSD rather than any other emulated media format.
Anyway, just a thought. You may have other requirements that I haven't fully appreciated.
Post by jgharston » Tue Jan 29, 2019 4:02 pm
Doing:
cd H:\Develop\BasicTests
H:\Develop\FileTools\Images\MkImg H:\test.ssd Colours -opt 3
C:\Apps\Emulators\BeebEm\BeebEm.exe H:\test.ssd
sort-a works, but my system is configured to boot into ADFS. Doing *DISK shows Colours is there, you'd need a !BOOT file to CHAIN it, and if using MkImg to create the disk image you'd have to use an external file list as I haven't got around to adding a -add switch yet.
Theoretically:
H:\Develop\FileTools\Images\MkImg H:\test.ssd -a !BOOT -opt 3
with !BOOT containing CHAIN"Colours"<cr> would do it. If doing it from an IDE it would be simpler to write it all out from the IDE manually.
Richard Russell
Post by Richard Russell » Tue Jan 29, 2019 5:17 pm
I don't have any "requirements" since I'm not the OP! I'm personally not interested in running programs on a Beeb (or an emulator) or in 'retro-computing' of any sort. I get my kicks from pushing BBC BASIC to its limits on modern hardware, most recently in leveraging the power of GPU shaders (see this YouTube video and this one, both from BBC BASIC for SDL 2.0).
I was simply offering a suggestion that one might be able to modify SDLIDE to run the program not in BBCSDL, which of course is what normally happens, but in an emulator like BeebEm. Unfortunately doing so seems to be far more complicated than I ever imagined, so I'll leave it to others to experiment with if they are so inclined. SDLIDE is itself written in BBC BASIC and Open Source.
dominicbeesley
Post by dominicbeesley » Thu Jan 31, 2019 11:30 am
Thanks All,
The responses in this thread have helped me to get somewhere. My current temporary solution is to use SLIDE/BBCB4W editor and save in RTR's BASIC format. I'd not realised how trivial the differences where between that and Acorn format so I've just got a simple script to convert.
Next, when I get a minute I intend to build that script into the Perl TubeHost script to automatically convert on the fly any files named .bas and present an alternate without the extension in Acorn format. When I get time I'll have a go at changing SLIDE to save as Acorn format too.
Incidentally, RTR - how/why did the different BASIC formats come about?
D
Richard Russell
Post by Richard Russell » Thu Jan 31, 2019 2:00 pm
There were two main factors. Firstly, the CPU families for which I've written BBC BASIC interpreters (Z80, 8086, IA-32) are all little-endian, that is they expect 16-bit values stored in memory to have the least-significant 8-bits in the lower address and the most-significant 8-bits in the higher address. Secondly, the format in which tokenised BBC BASIC programs are saved to file is the same as how they are stored in memory, so for example you can load a program using *LOAD and save it using *SAVE.
With those processor families It therefore made much more sense for the 16-bit line number (at the start of each program line) to be in little-endian format rather than the big-endian format used by Acorn. Had I not reversed the order of those bytes (in memory) the speed of GOTO, GOSUB and RESTORE would have been adversely affected, because it depends crucially on how quickly you can scan the program to find the destination line. Being able to take advantage of the 16-bit loads supported by those CPUs gave a worthwhile benefit.
It would in principle have been possible to change the memory format but keep the file format the same, by juggling the bytes on CHAIN/LOAD and SAVE, but losing the ability to *LOAD/*SAVE programs would have been a big price to pay. Being able to do that is particularly valuable for overlays and modular programs.
Swapping the order of the line number bytes does not of itself explain why the line-length byte was also moved (from after the line number to before it) but having decided to use a different format it gave me the flexibility to make more changes. Having the line-length byte first 'felt' more natural to me (and still does), and reversing the order of all three 'header' bytes had a kind of symmetry!
Soruk
Post by Soruk » Thu Jan 31, 2019 2:48 pm
Thu Jan 24, 2019 9:38 am
tom_seddon wrote:
Thu Jan 24, 2019 12:54 am
JSBeeb's tokenizer does something interesting: it runs the tokenizer from the BASIC 4 ROM!
All versions of BBC BASIC (with the possible exception of Brandy, I need to check that) allow you to run their built-in tokeniser via a cheat involving EVAL.
A bit late to the party here, but no, this will not work in Brandy. Its internal structures are not visible to a running BASIC program, indeed PAGE = 0 on Linux and Windows builds.
Richard Russell
Post by Richard Russell » Thu Jan 31, 2019 4:04 pm
So what memory is visible to a running BASIC program? Presumably everything between LOMEM and HIMEM is, otherwise indirection would not work. What about above HIMEM? Would a workaround be for the tokeniser to copy its output to somewhere in that range, maybe at END?
Soruk
Post by Soruk » Fri Feb 01, 2019 11:32 am
Memory between LOMEM and HIMEM is certainly visible, HIMEM is, by default, the top of the memory allocated to BASIC programs and data, with a couple of exceptions nothing is readable above HIMEM.
The exceptions are:
1) Raspberry Pi GPIO MMIO space - as returned by SYS "RaspberryPi_GPIOInfo" TO present%,gpiomem% - 4K is accessible though less than that is significant.
2) MODE 7 video memory at &FFFF7C00 to &FFFF7FFF. (&FFFF7FE8-&FFFF7FFF writes are ignored, reads return 0 - unlike the BBC Micro, scrolling updates the screen memory so &FFFF7C00 is always the top left character cell).
I'd need to look at what the tokeniser does - while Brandy can load tokenised files (both yours and Acorn), it saves as plain-text.
Richard Russell
Post by Richard Russell » Sat Feb 02, 2019 3:14 pm
When I get time I'll have a go at changing SDLIDE to save as Acorn format too.
Version 1.00a of SDLIDE, released today, supports loading (but not saving) of Acorn-format programs.
LordVaderUK
Post by LordVaderUK » Tue Feb 12, 2019 10:39 pm
Hello all,
Can someone help out a newbie (to retro computing, but not to computing generally) with what is probably a really BASIC question...
I am writing a BASIC program, using the BBC Basic adaptation called SDLIDE, which seems pretty good. I can test and run the program in emulated mode on my Mac, perfect.
However I want to run it on the BBC Micro. I have RetroClinic's excellent DataCentre which allows me to save the program onto a USB stick and then load it onto the BBC. However, this is where I'm getting stuck.
If I save the program as tokenised basic, it has a .BBC file type, so for example the file is called MYPROG.BBC - but The BBC won't load this, keeps saying "bad name". If I remove the extension, it just says "file not found".
I'm obviously making a fundamental mistake, so my apologies for asking. But I am just getting (re)started in the world of BBCs...
Thanks in advance.
Post by lurkio » Wed Feb 13, 2019 6:41 pm
I am writing a BASIC program, using the BBC Basic adaptation called SDLIDE, which seems pretty good. I can test and run the program in emulated mode on my Mac, perfect. However I want to run it on the BBC Micro. I have RetroClinic's excellent DataCentre which allows me to save the program onto a USB stick and then load it onto the BBC. However, this is where I'm getting stuck. If I save the program as tokenised basic, it has a .BBC file type, so for example the file is called MYPROG.BBC - but The BBC won't load this, keeps saying "bad name". If I remove the extension, it just says "file not found". I'm obviously making a fundamental mistake, so my apologies for asking. But I am just getting (re)started in the world of BBCs...
The way I normally transfer a BASIC program from Mac to Beeb via DataCentre is to first use BeebEm to save the program to a .SSD disc-image. (You can paste the program listing into BeebEm first.) Then *IMPORT the .SSD into RAM drive 0 on the DataCentre: *IMPORT -0 Prog.SSD
But if you want to load the tokenised BASIC program-file straight from the USB stick into your Beeb's RAM (bypassing the .SSD stage altogether), then you have to do this:
[Ctrl-Break]
*RAM
*DRIVE 5
*LOAD Prog 1900
I'm assuming that PAGE is at &1900 on your Beeb. If not, then amend the last line accordingly.
Is this what you were after?
mr-macrisc
Post by mr-macrisc » Wed Feb 13, 2019 9:14 pm
What about Risc OS on a raspberry pi and use something like strongEd.
That's assuming risc os on pi can read and write bbc compatible floppy.
dominicbeesley
Post by dominicbeesley » Thu Feb 14, 2019 9:06 am
The problem you're encountering is that SLIDE uses Richard Russel's newer tokenized format instead of Acorns.
You should be able to save as text format from SLIDE then load it into the beeb using *EXEC.
D
Richard Russell
Post by Richard Russell » Thu Feb 14, 2019 9:38 am
As I've mentioned, since SDLIDE is itself written in BBC BASIC adapting it to output Acorn-format tokenised programs would not be difficult (the latest version already loads Acorn format files). Saving would be somewhat slower but that's not likely to be relevant with the size of program you can fit in a BBC Micro!
The code would need to be something like this, instead of the current code in FNsave(). Note that the only significant change is to reverse the order of the first three bytes in every line:
      BPUT #F%,&D
      FOR N% = 0 TO nLines% - 1
        a$ = Buffer$(N%)
        BPUT #F%, MID$(a$,3,1)+MID$(a$,2,1)+MID$(a$,1,1)+MID$(a$,4);
      NEXT
      BPUT #F%,&FF
dominicbeesley
Post by dominicbeesley » Thu Feb 14, 2019 10:30 am
It's on my round tuits pile!
D
fordp
Post by fordp » Thu Feb 14, 2019 1:35 pm
I am not sure how it works but Windows allows you to dig in to zips and treat them like a subdirectory. You could do the same for SSD, DSD and MMB files and then you could use any editor on the PC to edit basic programs.
FordP (Simon Ellwood)
Richard Russell
Post by Richard Russell » Thu Feb 14, 2019 1:51 pm
Not 'tokenised' (internal format) BASIC programs, which is what programs in an SSD are likely to be. "Any editor on the PC" is only going to be useful for plain text files, such as might be created by *SPOOL and/or loaded with *EXEC, but they are the exception.
fordp
Post by fordp » Sat Feb 16, 2019 11:14 pm
Yes you could. When you edit a file from a zip file your plain text is not saved literally but transformed to another set of bytes and thus could an SSD file be transformed.
dominicbeesley
Post by dominicbeesley » Fri Mar 01, 2019 12:46 pm
      BPUT #F%,&D
        a$ = Buffer$(N%)
      NEXT
      BPUT #F%,&FF
That worked! I've added an option for an extension ".ffb" for Acorn BASIC.
One thing that had me going for a while was line numbers, or rather, lack thereof. Listing a program with line numbers of 0 on the beeb causes a hang (I think deliberately as a simple anti-tamper?).
Would it be safe when saving to .ffb automatically start numbering missing lines at 1 and increment by 1 until a genuine line number is found and then restart from there?
D
Richard Russell
Post by Richard Russell » Fri Mar 01, 2019 2:22 pm
You could do that. The risk, of course, is that even if you increment the line numbers by 1 there's no guarantee that there will be enough numbers available to 'fill the gap'. For example somebody might have numbered just a couple of lines, say 100 and 200, and if there are more than 99 un-numbered lines between them your suggested technique would fail. :(
For that reason I would normally prefer to renumber the entire program (for example using the '10 20 30' button in the SDLIDE toolbar) which will avoid this problem. It not only renumbers the lines but also fixes up the references to those lines in GOTO, GOSUB and RESTORE statements (so long as the destination line numbers are not calculated).
dominicbeesley
Post by dominicbeesley » Fri Mar 01, 2019 4:08 pm
Fair enough, I'll do that then!
So far it is working well!
D
Post by jgharston » Fri Mar 01, 2019 4:29 pm
The DataCentre RAMFS is a DFS-alike filing system, everything "looks like" DFS, so in particular that means seven-character filenames, no extensions. Also, specific to the USB drive, the ***ONLY*** actions supported are load, save, cat, import and export. So, for example, no RUN, no OPEN, no BGET - and so no DUMP, no Acorn SRAM SRLOAD.
So, any files on a USB drive that you want to load via RAMFS with the DataCentre MUST be solely seven characters maximum, and compliant with DFS character usage - so no embedded '#', '$', etc.
Also, a BBC BASIC file saved from a Russell-type BBC BASIC will be Russell format files, not Acorn format files, so you will need to convert them to Acorn format to load them into a BASIC that expects Acorn format files. As Richard has pointed out, the SDLIDE is itself written in BASIC, so you can modify it to save in Acorn format. On RISC OS I have my BasConv utility that does this with any arbitary file.
