Viewdata Service
Rfairman
Re: Viewdata Service
Post by Rfairman » Fri Sep 13, 2019 9:37 pm
Can I ask what you are using on the beeb to correctly display telstar I have connected via serial cable and a hayes emulator in a PC
Regards
*STEVE
Post by *STEVE » Sat Sep 14, 2019 1:38 am
Regards
The beeb is running Commstar which I burned to a ROM. It has a normal terminal mode and a 'viewdata' mode which works perfectly in mode 7 for telstar.
  • BBC Model B+ 128k
  • BBC Master 128k (work in progress)
  • +more
John_Newcombe
Post by John_Newcombe » Sun Mar 22, 2020 11:01 pm
Just to let you know that Telstar now has a dial up service. All V23 (1200/75 baud) modems should work including the Acorn Prestel adapter.
The access number is 01756 664433 and whilst this is still a experimental, it is my intention that this becomes a permanent addition to Telstar.
The system uses a couple of Dowty Quattro modems attached to SIP connections via analogue telephone adapters (ATAs) and seems to be very reliable.
More details here if you are inclined... https://glasstty.com/wiki/index.php/The ... he_Service
Enjoy!
