New game in development - Polymer Picker
sa_scott
Re: New game in development - Polymer Picker
Post by sa_scott »
ChrisB wrote:
Tue Nov 23, 2021 7:36 am
What Richard said. Having played with the code when the diver moves there's much more time taken with unplot/plot etc. Than when the fish just move. This might be alleviated with some sprite code. Alternatively why not tie the oxygen to TIME which will decrement at a constant rate.
Thank you both. Funnily enough, I did tinker with TIME a bit later on, but I was still getting the same result. I looked at a couple of games from the archive for ideas on implementation - Professor McBrolly, and BlocBusta. They both utilise TIME, the former achives a consistent countdown, while BlocBusta has an air supply, which appears to decrement in a consistent fashion, but it does use a tick counter, rather than explicitly refer to TIME.
I've had to leave the code for a while, as I have a lot going on the rest of this month, which is annoying for me personally. I'll just have to grit my teeth!
Stephen Scott, Digital Media Muckerupper
www.sassquad.net
sa_scott
Post by sa_scott »
Some further amends/enhancements for v0.03:
  • The air supply now counts down in a more timely fashion. It flashes when it gets too low. I've not yet devised a mechanism to replenish the air supply.
  • I've added some temporary characters to represent your boat. This may form the basis of replenishing your air supply.
  • The bottom of the screen is used less for the sand now, and more for a simple clean status area. The air supply is drawn at the bottom now, leaving the top of the screen clear.
Glad I managed to crack the air supply issue though.
polymer-picker-v0-03.ssd
Polymer Picker v0.03 disc image
(6.25 KiB) Downloaded 4 times
polymer-picker-v0-03.zip
Polymer Picker v0.03 zipped disc image
(3.19 KiB) Downloaded 3 times
www.sassquad.net
jms2
Post by jms2 »
Just to let you know where I'm up to as well...
I have designed some sprites for it (identical to yours, but with colour) using the Creative Assembler tool, and have modified POLY1 to assemble the sprite plotting code and load the sprite data. My previous changes to POLY2 (moving all the variables into bytes) are now unnecessary, but what I need to do is change the co-ordinates for sprite plotting to 160 horizontally x 256 vertically.
Currently my plan is to plot the man and the fish using machine code, and also use the routine to do collision detection as well (rather than use POINT). Everything else will remain as-is.
I'll keep going with my v0.02 version in parallel to your changes because at the moment there remains the possibility that it won't work!
sa_scott
Post by sa_scott »
jms2 wrote:
Thu Nov 25, 2021 8:05 am
Many thanks for your efforts on this jms2. Really appreciate the fact you're using free time labouring on this.
I do have a plan to introduce predators of some kind into the mix (giant squid, sharks, barracudas) - since there is a risk of the screen getting too busy, perhaps the predator should roam the sea in a similar manner to the big goose from Chuckie Egg?
For now, one idea is that you have to reach your ship to get a refill of oxygen. I could introduce strong currents to restrict how quickly you can swim, either on a level only basis, or some kind of random factor. This could be changed by amending the values by which the diver moves accordingly, while being aware that this may affect the collision detection routine.
As usual, I have lots of ideas, and either not the time, or the programming clout to fulfil them!
www.sassquad.net
Post by richardtoohey »
sa_scott wrote:
Thu Nov 25, 2021 9:22 am
You're doing a lot better than me =D>
Trying to get back into the swing of things and writing a game is definitely on the bucket list. But I just get too ambitious and want to do something fantastic straight away but I need to crawl first!
jms2
Post by jms2 »
Getting there... doesn't actually work yet though...
sa_scott
Post by sa_scott »
jms2 wrote:
Thu Nov 25, 2021 10:56 pm
'Tis a thing of beauty!
I'm running out of VDU characters as I've defined sea grasses, crabs and shrimps, gonna have to expand into pre-224 range, which I think is problematic on non Beebs. I might be wrong though.
www.sassquad.net
sa_scott
Post by sa_scott »
Thu Nov 25, 2021 9:12 pm
Believe me, I'm making this up as I go along. And when I can't do that, I scour scanned magazine listings, or the BBC games archive, and browse the listings there, and reuse and recycle! :lol:
www.sassquad.net
jms2
Post by jms2 »
OK, I have got a version with sprites working! As I said before, it's based on version 0.02.
POLY1 is the loader. This also assembles the code and loads the sprites.
SPRITE is the sprite designer, from Creative Assembler. DEMO is the game from the same book.
The sprites are saved with the names LDIVER, RDIVER, LFISH and RFISH.
The sprites get loaded into memory between &2C00 and the bottom of the screen at &3000 (there is some free space). HIMEM is moved down to suit.
The code is assembled at &900. The usable space extends up to &BFF I think, but it doesn't use anything like that much so far.
The diver and fish are plotted using a co-ordinate system with an origin in the bottom left corner (as per graphics as usual) but X goes from 0-79 and Y from 0-255. Accordingly, comparisons with the bag positions require an adjustment to be made (which is in the 'check' procedures).
Collision detection is done by a machine code routine rather than point. It looks at a pair of pixels rather than just one, and is looking for them both to be red. This is represented by a value of 3.
One thing I cannot figure out is why the bags always appear in the same pattern every time (on every level)... whereas if you run PROCbags from the command prompt, you get a random distribution.
I hope this is helpful and that you can integrate it with your latest developments!
PP with sprites.zip
(7.61 KiB) Downloaded 8 times
sa_scott
Post by sa_scott »
jms2 wrote:
Sat Nov 27, 2021 6:25 pm
Amazing!
I've just noticed this in my version of the game. Even with the Q%=RND(-TIME) present, supposedly to kick the seed generator, it doesn't seem to be working. This happened in an earlier version of Androidz - I kept getting the same positioning every time, but adding the seeder changed it. Wondering why it's no longer random?
Other than that, I can't thank you enough for your efforts so far. I'll definitely have a rummage and see how I get on!
www.sassquad.net
jms2
Post by jms2 »
Glad you like it! For the avoidance of confusion, I'll stop messing about it with it now and let you digest the changes. But if you have any questions, please ask.
Here are some further observations:
- I wanted to be able to plot the sprites against a background colour of 0 (so the colours don't get messed up). Accordingly I redefined the sea to be colour 128 and used VDU19 to make it blue. The black edge to the mountains is now colour 8, redefined to black.
- I haven't made the bags into sprites. I don't think this is worth doing, as its better to have them as solid red anyway.
- The collision detection could be improved. At the moment, all it does is call the routine which converts X,Y coordinates into an address. Then it looks in that address to find the value for two red pixels (3). Ideally you'd probably develop a bit of machine code to be called via USR which returns TRUE if either of the pixels is red. I can probably knock this together quite easily.
- The diver and fish are not animated. I think animating the diver would be quite nice, and this could be done by defining new sprites shifted one pixel across and with the legs swapped round. Actually making the animation work would be tricky though - X movement would require swapping between (1) keeping the X coordinate the same and plotting the alternative sprite, and (2) Incrementing X and reverting to the original. Whereas Y movement would simply increment and decrement as usual, keeping with whatever sprite is currently displayed. The diver would only kick his legs when swimming in the X direction.
- Your idea of implementing 0xcode's bubbles effect would be very nice. But you'd have to find space for the code, and critically make sure you have some spare zero page addresses for it. I haven't looked at how possible this would be. Obviously it could be cut down a bit because you'd only need bubbles to rise from the diver, not all over the screen.
Post by lurkio »
sa_scott wrote:
Sun Nov 28, 2021 1:05 am
I think it's because the value of TIME will always be the same -- because bbcmic.ro will always allow the same amount of "Beeb time" to elapse before the game starts running because the bbcmic.ro emulator is deterministic. You need to introduce an "external" random time-delay.
Try this:
IFGET Q%=RND(-TIME)
https://bbcmic.ro/#%7B%22v%22%3A1%2C%22 ... %5Cn%22%7D
jms2
Post by jms2 »
I came to the same conclusion, so I moved the seeding statement to after the “press space to load game” stage in the loader. But it didn’t help - maybe I messed it up in some way.
Post by lurkio »
jms2 wrote:
Sun Nov 28, 2021 2:39 pm
I suspect it's because the RNG is being reseeded with the value -3 on line 197:
197MOVE0,0:L=LE%/PI:OX%=-32:OY%=0:A%=RND(-3)
jms2
Post by jms2 »
Well spotted! That must be it. It never occurred to me to go looking for a further re-seeding. Stephen, was this intentional? I can see how it might have been (makes the levels predictable).
sa_scott
Post by sa_scott »
jms2 wrote:
Sun Nov 28, 2021 5:01 pm
Sorry for the delayed response, all. Yes, the A%=RND(-3), indeed the whole PROCmt procedure, was drawn from the game Wishing Wells (http://www.bbcmicro.co.uk/explore.php?id=828) - check out line 1640. This bit of code has no purpose.
In any case, removing it has resolved the issue. The items now display in a proper random manner. Even the mountains now render in a more random manner, so that wrinkle really was affecting the whole of the game!
Here's a work in progress screenshot.
I've been working slowly on the Basic version, and have incorporated the temporary boat graphic (which is where you can refuel your air - eventually), along with some sea grass. I was somewhat stumped by the non-random issue though. It did occur to me that the TIME amount would end up being the same each time I reset the emulator, and rebooted the game.
I had a chat with my 11yo daughter about the game. She suggested adding sharp coral - if you get injured, that can reduce your air supply, and perhaps introduce a shark to the proceedings! Add a bit of peril to the game while trying to refuel your tank!
I might not be able to work on this game for a little while, due to other commitments, but I'm not short of material to dive into now. The machine code is definitely better in terms of movement and speed!
I'm so grateful for all the time you've all spent looking into these problems. It's definitely spurring me on to get this over the line before Christmas :-D
www.sassquad.net
sa_scott
Post by sa_scott »
It's been a while since I gave an update. I've focussed more on the Basic version, which is the version I've attached here.
I've added a few more enhancements to the gameplay element:
  • I've modified the control keys to Z,X,' and /, with the Return/Enter key allowing you to swim faster.
  • Swimming faster consume more of your air supply, so use it wisely.
  • I've added a 'shark' to the game, which homes in on your position, slowly to begin with.
  • If you touch the pink coral, this will injure you. The shark will pick up your bleeding, and home in you faster.
  • I'm hoping to add or change the fish to include more 'spiky' fish, such as pufferfish, so you can also get injured like with the coral.
  • The 'boat' remains static, and without purpose. I'm hoping to add some kind of 'zone' underneath it, so you can get replenished air supply, and get first aid, so the shark stops tracking you quicker. Getting these mechanics to work cohesively, without consuming memory or speed, is going to be tricky.
  • I've fleshed out the instructions a bit more.
The game mechanics are slowly coming into play. I'm contemplating whether it is feasible to have 'caves' where hard to reach junk must be collected. But this would play havoc with collision detection I fear, certainly with the Basic version.
One thing the game needs is sound! I'm wondering how to get the sound of 'bubbles' into the game. The only sound I can think of is the completion sound at the end of each level of BlocBusta (http://bbcmicro.co.uk//game.php?id=1297) - but I'm wretched at envelope creation - the theory is just too dense for me!
Hope you appreciate this update. Hoping to return to the assembly language version from next week, depending on how the day job goes this week.
polymer-picker-basic-v0-04.zip
(4.07 KiB) Downloaded 1 time
www.sassquad.net
