Lady Bug
lovebug
Re: Lady Bug
Post by lovebug »
well that didnt go well and I managed to get the enemys in a loop of conflicting logic and freeze the whole game :lol: :lol:
Re: Lady Bug
Post by fwibbler »
lovebug wrote:
Tue Sep 14, 2021 2:12 am
fwibbler wrote:
Mon Sep 13, 2021 3:27 pm
Oh nothing spectacular.
I was just going to mention it on my very sporadically updated website.
ah thanks
i just had a thought about the enemy aiming logic so im probably gonna make another update :lol: :lol: :lol: :lol:
currently the enemys are allowed to turn 180 but if I prevent this it should hopefully stop them getting into that loop where they keep doing a 180 turn for a while
gonna try an experiment ....
Hmm, I've been kind of relying on that feature to be any good at the game... :oops:
lovebug
Re: Lady Bug
Post by lovebug »
fwibbler wrote:
Tue Sep 14, 2021 8:19 am
whatever works is cool :D
ive been trying to think up some enemy aim logic that will allow enemys to find ladybug while avoid turning into blocked paths and not use too many cpu cycles
or maybe I should just leave it alone as it plays ok right now and might get too diffucult if the enemys are better at finding a path to ladybug
lovebug
Re: Lady Bug
Post by lovebug »
i cant figure it out how to use github :( so i'll post here
build 2508 - changes to player controls
my ladybug controls have always been a little weird
if you turn before a corner the ladybug could either keep moving in the current direction until the corner is reached and then turn in the direction or could move backwards away from the direction you intended to go
so I have tried to fix it and now if you press a direction before youre at a corner then ladybug will continue in its current direction until the corner is reached and then turn
its still weird but slightly better ?
FILES DELETED
----- edit ---- this might be worse ? ladybug seems too slippery now
i need to think about this
----- edit 2 ---- yeah this was junk, now deleted
lovebug
Re: Lady Bug
Post by lovebug »
build 2508
fixed 2 minor bugs in playSound function
removed jsr enemyRelease and surrounding code from updateEnemyTimer function
added jsr enemyRelease into gameLoop
enemyRelease function altered to check if its time to release an enemy but then delays the release until (vsyncCounter and #7) = (sprite number - 1) * 2
originally all enemys were in sync on the same frame and could arrive at junctions at the same time causing heavy cycle load on that frame while the aim logic calculates where the enemys should go
by staggering the enemy release frame the enemys should arrive at juctions on different frames and reduce the cycle load per frame (well thats the theory anyway)
I made this change because I could sometimes hear that timer tick bleep would be delayed by 20mS and im assuming that a frame overrun caused by the enemy aim logic had occurred (random path can take several loops to find a valid path (lazy programming !)). maybe its beebems fluctuating frame rate on my laptop ?
ladybug.ssd
(30.5 KiB) Downloaded 4 times
source code.zip
(185.12 KiB) Downloaded 2 times
lovebug
Re: Lady Bug
Post by lovebug »
build 2509 - found another bug
for some strange reason I had the two variables used in the swram test defined to use visible mode 7 screen memory locations 7cfe 7cff
fixed now
swrBank			= page8000 - 1		; storage for bank number of swram
swrBankOriginal		= page8000 - 2		; storage for original system bank number
ladybug.ssd
(30.5 KiB) Downloaded 2 times
source code.zip
(185.17 KiB) Not downloaded yet
