GridRunner WIP
fizgog
GridRunner WIP
Post by fizgog »
Hi everyone,
I’ve been trying to learn 6502 for the past month, since digging out my BBC from the loft and decided to work on creating a game.
I've always liked GridRunner on my friends C64 and was surprised it’s never been converted to the beeb.
Started working on a real beeb, then switched to using BeebASM in Visual Code as it was much easier :)
I managed to find a disassembly of the game, so I decided to work on this, seems the original used character based graphics so I tried first doing it this way using the user defined characters on the beeb, then realised this was too slow so switched to using sprites for the graphics.
Decided on using the Vic20 game as a starting point as it’s supposed to be the best one, so I’m using Mode 2 although it has less columns than the Vic20.
I might also create a 40 column Mode 1 version later on, to give the user more choice.
Following still needs to be worked on: -
Instructions need adding
Joystick support - although I’ve not got a joystick to test with :(
Timings - Enemies, ship and bullet need tweaking
Sound - Anyone know of any good tutorials on
Collision detection - still has a few problems
Ship Explosion
I've attached a ssd file of what I've done so far.
Regards
Shaun
gridrunner.ssd
(6.25 KiB) Downloaded 20 times
nicolagiacobbe
Re: GridRunner WIP
Post by nicolagiacobbe »
Seems excellent. Everyone would assume the most has been done.....
Out of curiosity: how much memory remain to implement audio and instructions?
(BTW, it is really fast! are my reflexes so slow or it is really faster than the original?)
fizgog
Re: GridRunner WIP
Post by fizgog »
Thanks,
I'll probably add instructions to basic loader file so it won't impact on the game,
In terms of memory, the game is currently compiling from 1900 - 2780, so should be plenty of space to play with for sounds and explosion animations etc.
There is also the possibility to relocate the sprites down to 0900-0BFF if I'm running out of space
Definitely faster than it should be, it needs tweaking
Also managed to download a Vic20 and C64 user manual last night, so I'll be going through these at the weekend to try and understand the sound system.
fizgog
Re: GridRunner WIP
Post by fizgog »
Thanks,
Update
Whilst reading through the manuals for Vic20 and C64 on sound, I've added some instructions to the basic loader and also new Mode1 version (larger play area, but lacks the colours of Mode 2)
To access this version press 1 on the instruction game control screen rather than 2 or the spacebar
GridRunner.ssd
(11 KiB) Downloaded 15 times
nicolagiacobbe
Re: GridRunner WIP
[attachment=0]Screenshot 2021-06-20 at 12-17-56 jsbeeb - Javascript BBC Micro emulator.png[/attachment]
Hello and thanks for the game.
I have tested both versions (MODE 2 and MODE 1) one after the other and, as a strictly personal opinion, I prefer the wider and more coloured MODE 2 version. I am just adding a suggestion: the game would be more immersive if it where fullscreen, do you have enought time to draw the chars as 8 x 12 blocks instead of the actual 8x8? This way you could fill the screen but I do understand that it would be much more complex. Another option (but at the moment I do not know if it is viable) would be to separate each screen row by two pixel tall blank lines (a la MODE 3), that would extend the screen vertically but for that we should ask tricky and the other geniuses of the forum. For example, I have tried putting 8 in register 9 of 6845 and the result is a nice extended screen with black lines between rows, once centered could be a possible alternative.
Friga
Re: GridRunner WIP
Post by Friga »
Hi- had quick game and it seemed quite playable - good work!
I dont think I have played the original (or not in the last 30 years), but it seemed familiar. I preferred the MODE 1, 4 colour - just seemed more appropriate resolution. May MODE 2 grid could be thinned out a little.
I could not move up and down (using beebem?) could be my non-standard US Ergodox keyboard, but not seen that issue on other BBC games. Or is that only on later levels?
fizgog
Re: GridRunner WIP
Post by fizgog »
Progress Update
First thanks for the feedback
Still working on it in my spare time, but i've put Mode1 version on the back burner - didn't like the 4 colours and I only did it as proof of concept
Decided instead of copying the VIC20 game screen layout, I'd make it fit the BBC mode 2 a lot better, by extending the grid, not sure I'm proficient enough to do 12x8 as it goes over character boundary and I've only been coding 6502 for about a month.
Fixed a zapper collisions detections, still some more though to add
Fixed clearing of droid array - this stopped the ship from moving or firing when either starting again or the next level
Added high score screen
Added level select - use up / down to select starting level
Added extra sprite animations for droid leader, also coloured them green to distinguish between the head and the body
Full screen mode
Still more to go, but once I've completed it I'll release the source code to go with it
No ssd this time though as its currently crashing on the stack after a few mins
nicolagiacobbe
Re: GridRunner WIP
Seems really nice. I am eager to test it.
When you are speaking about 12x8 I assume it is 8 pixel horizontal and 12 vertical, isn'it? I have never tacked the problem (and I'd like to) but a possible suggestion could be having two routines for each even and odd values of the vertical Y coordinate, this way the sprite data could be the same (i.e. an ininterrupted stream of 48 bytes). Not willing to state the obvious, just suggesting.
Chuckie
Re: GridRunner WIP
Post by Chuckie »
What about attack of the mutant camels. Jeff Minter still codes just uses 'retro styles' on modern platform.
fizgog
Re: GridRunner WIP
Post by fizgog »
Update
Managed to find some spare time to work on this some more.
  • I've fixed the crash bug
  • Started to implement sound - ship only at the moment
  • Added sound / pause panel to bottom right of the screen, use S for sound on / off and P for pause on / off
  • New leader droid graphics - green was to similar to the ship
  • Fixed some timing issues with enemies
I'm currently working on the ship exploding animation and adding further sounds
Gridrunner.ssd
(12.25 KiB) Downloaded 7 times
fizgog
Re: GridRunner WIP
Post by fizgog »
Quick update
Managed to add ship explosion routine on my dinner break :D
Gridrunner.ssd
(12.25 KiB) Downloaded 9 times
Re: GridRunner WIP
Post by tricky »
I don't know the game, but this is looking great.
Perhaps you would like to give a quick preview and maybe a few words on a thursday dev night zoom?
fizgog
Re: GridRunner WIP
Post by fizgog »
First things first, thanks for all the comments and encouragement.
Sorry I'm not one for public speaking, not something I like doing, so I'll give it a miss if you don't mind, thanks for the offer though. :)
I'd also like to thank Rich Talbot-Watkins for both BeebASM and BeebSpriter which I'm using to create this
RTW in the high score for that :wink:
I've fixed and added the following things
  • Shooting to the top of the grid.
  • Bombs dropping down will now wipe out any pods below them, instead of being respawned
  • Added joystick support press J to toggle the icon on and off
Can someone please test this as I don't have a joystick to test with :oops:
I think the only thing left to do is the remaining sound effects. Can't for the life of me understand the VIC sound system so I've been using synth from the following location which I find excellent for playing with.
http://bbcmicro.co.uk/game.php?id=3569
Gridrunner.ssd
(9 KiB) Downloaded 6 times
fizgog
Gridrunner
Post by fizgog »
I've added the remaining sound effects I think
Hopefully barring any bugs I'll consider this finished
Once I've tidied up the code, I'll post it somewhere, probably github
Then I'll need a new project to work on
Gridrunner.ssd
(9.25 KiB) Downloaded 12 times
fizgog
Gridrunner
Post by fizgog »
Finally gone through the code and tidied it up a bit. Code is split over several files as I found it easier to handle and read.
Sprites can be viewed using the excellent BeebSpriter program from http://www.retrosoftware.co.uk/wiki/ind ... eebSpriter
Let me know if I've done anything stupid in my first attempt at coding in 6502
Link is as follows: -
https://github.com/fizgog/Gridrunner
