Lode Runner (Electron)
0xC0DE
Post by 0xC0DE »
Working on a disassembly of Lode Runner (BBC Micro version) with the intention of creating an Acorn Electron version.
Question: does anyone know of a (homebrew) Acorn Electron version of Lode Runner? Or, does anyone already have a disassembly or full source of Lode Runner for the BBC Micro? I would rather discover this sooner than later :mrgreen:
0xC0DE
:arrow: Follow me on Twitter
oss003
Re: Lode Runner (Electron)
Post by oss003 »
I started it but then realised the resolution wasn't ideal for the Atom...... :(
I'll have a look how far I got and upload it if you want, it was a snapshot.
IIRC there are some Atom converted parts in ...
Greetings
Kees
loderunner.txt
(213.2 KiB) Downloaded 26 times
0xC0DE
Post by 0xC0DE »
oss003 wrote:
Wed Apr 28, 2021 5:20 pm
Greetings
Kees
Thanks Kees! That will be really helpful to make sense of it all =D>
0xC0DE
0xC0DE
Post by 0xC0DE »
0xC0DE
Dave Footitt
Post by Dave Footitt »
Great job, and great choice of game. Absolutely loved Lode Runner and did briefly consider a NuLA rework of it, but I didn't think there were enough graphics in to make the effort worthwhile. Might be a bit easier now you've disassembled it though!
0xC0DE
Post by 0xC0DE »
Dave Footitt wrote:
Sun May 02, 2021 10:29 pm
Thanks Dave! When the disassembly is finished I will put it on GitHub.
I also hope this road will somehow lead me back to finishing Mountain Panic for the Electron one day :mrgreen:
0xC0DE
0xC0DE
Post by 0xC0DE »
Question to anybody more familiar with the BBC Micro than I am.
I've disassembled this snippet of code from the BBC Micro version of Lode Runner.
.readJoystick
                lda   #$00
                sta   keysPressed
                sta   DDRB            ;set USER VIA Port B as Input
                lda   IRB
                eor   #$ff
                beq   checkMovementKeys ;no active inputs, so check keys instead
                sta   keysPressed
                rts
Is this in fact the standard way of reading a joystick on a Beeb or is something else going on here??
0xC0DE
Post by tricky »
Is that matter compact?
It has the joystick on the user port.
The rest will have to start an and conversion and wait for the interrupt or just wait and then do the next channel/axis.
0xC0DE
Post by 0xC0DE »
tricky wrote:
Tue May 04, 2021 9:39 pm
I just found it while disassembling Lode Runner. It could have been added later by someone, just like the protection code has been disabled in this version. Most importantly, I can remove this code from the Elk conversion I'm working on :mrgreen:
0xC0DE
0xC0DE
Post by 0xC0DE »
I disassembled Lode Runner (BBC Micro version): https://github.com/0xC0DE6502/lode-runner-disassembled
0xC0DE
Snuggsy187
Post by Snuggsy187 »
That's really quick work for such detailed notes ! :D =D> =D> =D>
I always get around 50% annotated, then lose the plot somehow (or get distracted with something else !). Always nice to see redundant cycle/bytes identified. Always tempting to deleted them, until you realise they're needed for timing and stuff like that ! No JMP (&6C) tables ? I find they're the biggest pain when disassembling ! You think you've found loads of unused code, then you find a JMP table :roll: :D
DROP PARCHMENT > POKE LOCK > PULL PARCHMENT > CURSE > BARGE DOOR > GO DOOR
TobyLobster
Post by TobyLobster »
Excellent, nice work =D> =D> =D>
0xC0DE
Post by 0xC0DE »
Thanks both! I'm now at the stage where everything in the source can be removed, moved, optimized, or whatever is needed because there are no hard coded addresses anymore. It's a relatively simple game so it's going fine so far!
0xC0DE
jms2
Post by jms2 »
That's amazing disassembly and commenting work!
I must say this game really gets down to business doesn't it!... loads at &1900, executes at the start not somewhere in the middle, and goes straight into the main game loop with no messing about. I have never seen a game that starts off so "immediately" like that.
0xC0DE
Post by 0xC0DE »
jms2 wrote:
Mon May 10, 2021 8:52 am
Thank you!
It doesn't go straight into the main game loop though. It does some initialisation, relocation, and there is even some disabled protection code.
See:
                org     $5fd0
.init            lda     #$c8                            ;exec address of binary = &5FD0
                ldx     #$03
                jsr     OSBYTE                          ;*FX200,3
                lda     #$e1
                ldx     #$00
                jsr     OSBYTE                          ;*FX225,0 - ignores the function keys
                jmp     defineEnvelope
0xC0DE
jms2
Post by jms2 »
Oh yes, I see now that the exec address is actually not at the start. I saw ".main JMP startgame" and thought that was the entry point!
Even so, having a tight main loop right at the beginning makes this a nice example for a beginner to look at.
0xC0DE
Post by 0xC0DE »
0xC0DE
oss003
Post by oss003 »
Nice job Kelvin .... did you have to change a lot except hiding the code on screen?
Greetings
Kees
0xC0DE
Post by 0xC0DE »
Thanks Kees! Moved most variables to zpage which freed up a lot of memory. Then moved a lot of data lower into memory. Removed things that depend on the OS (sound, keys). And added my own interrupt handler. Now I need to optimize sprite plotting and tilemap checking to gain more speed in MODE 1.
0xC0DE
