BeebEm Alpha Fork with SID and PAULA sound
dominicbeesley
Post by dominicbeesley » Sun Dec 01, 2019 11:45 pm
I've been experimenting with emulators and had a go at implementing the SID and Paula sound cards in BeebEm. I've added an alpha release on GitHub at https://github.com/dominicbeesley/beebe ... ossy-alpha
The installer contains some sample disc images for SID and Paula demos. (For Paula the files are quite large and slow to load from DFS so I've included an .adl file too - OSGBPB is _slow_ in DFS!).
If you want to try out more Paula tunes then you should be able to replace the files in the M directory with Amiga ProTracker files of your choice - most seem to play well on the included modplayer - let me know any you find that don't and I'll look to update the player.
The included SID files are a bit hit and miss, some don't work but most do and sound pretty good. Playlist1.ssd and Playlist2.ssd are good starting points
Thanks to Chrisn for helping me get this working and allowing me to do a pre-release.
The usual caveats for Alpha software apply
D
dominicbeesley
Re: BeebEm Alpha Fork with SID and PAULA sound
Post by dominicbeesley » Mon Dec 02, 2019 7:50 pm
Is there genuinely no interest or have I done something daft? So far it looks like nobody has tried the download or have I made a balls of publishing it on GitHub?
Post by hoglet » Mon Dec 02, 2019 8:04 pm
I'm seeing two downloads:
http://www.somsubhra.com/github-release ... em-windows
dominicbeesley
Post by dominicbeesley » Mon Dec 02, 2019 8:49 pm
Both me i thought...
Site Admin
Post by Arcadian » Mon Dec 02, 2019 8:50 pm
Oh, I downloaded, installed and ran the emu this morning - listened to all the Amiga mods was absolutely amazed with the quality! I'll definitely be needing a hardware equivalent of the Paula board at some point!! Great work Dom!
Post by hoglet » Mon Dec 02, 2019 9:00 pm
Tomorrow I must try your 1MPaula project on the Beeb 1MHz Bus FPGA board:
viewtopic.php?p=240700#p240700
Can you give me the three-line summary of the best available demo for this?
jregel
Post by jregel » Mon Dec 02, 2019 11:37 pm
I will be, just working today and had a meeting this evening, so no Beeb time.
dominicbeesley
Post by dominicbeesley » Mon Dec 02, 2019 11:43 pm
Thanks Arcadian, my two downloads must have been counted as one then! Glad you liked it. If you want to make more then you can try any of the 4 channel "mod" files that are less than 400K from https://modarchive.org/index.php?reques ... ery=105534 download the file and get them into the M directory with adfs explorer or similar
Hoglet, the modplayer on the Paula.ssd or Paula.adl discs (on Git for Paula fpga and BeebEm) is the only thing I've written. However, as above any of the mod files above should work. I could post up the code for the player - it should be easy enough to integrate it into a larger demo
Also, I've attached another .adl with a few larger mod files
D
Paula2.zip
(413.51 KiB) Downloaded 21 times
Site Admin
Post by Arcadian » Tue Dec 03, 2019 12:39 am
Aw, thanks for posting the extra disc - have had the three new tracks playing for the past half hour - really enjoyed them. I'm super busy with events for the next week so won't have time to put any mods together for at least a week but if you're taking requests I'd love to hear a disc of the Pinball Dreams tracks! ;)
dominicbeesley
Post by dominicbeesley » Tue Dec 03, 2019 2:50 pm
Here you go...
Paula3.zip
(411.38 KiB) Downloaded 22 times
Post by Pernod » Tue Dec 03, 2019 6:53 pm
Thanks, they sound great! I'm surprised I didn't recognise most of the tracks on the Pinball Dreams selection, I probably spent more time on Fantasies and Illusions.
jregel
Post by jregel » Tue Dec 03, 2019 9:32 pm
Wow - very impressive!
I created a quick disc containing some of my favourite mods from back in the day, written by Dr Awesome.
Awesome.zip
(297.21 KiB) Downloaded 20 times
dominicbeesley
Post by dominicbeesley » Wed Dec 04, 2019 5:38 pm
Thanks all,
Those Awesome tracks truly are! I neary included 12th warrior on the 2nd disc!
D
dominicbeesley
Post by dominicbeesley » Thu Mar 05, 2020 1:56 pm
I've updated this a little. There are now new disc images (attached) the main difference is a new menu system and slightly updated hardware detect code and it's all shifted up in memory to allow page to go up to &2000 so ADFS can be used for faster loading.
I've also made a B-em version of the emulation here https://github.com/dominicbeesley/b-em/ ... st-release there's a pre-built windows .zip here which contains a scsi hard drive with a load of tunes on. For non windows users it should work though I've not had a chance to test this properly on Linux.
You should be able to unzip and run b-em.exe. You will then need to:
Enable paula:
Settings->Sound->Paula
Enable ADFS:
Model->BBC B w/1770
ROMS->[empty slot]->LOAD->ADFS130
Enable SCSI:
Disc->SCSI Hard Disc
Reset
You should then be able to run mod menu in the $.MODS.ONE directory
The SCSI disc in the release can also be used in BeebEm in the usual way
D
paula.zip
(1.73 MiB) Downloaded 12 times
dominicbeesley
Post by dominicbeesley » Sun Mar 08, 2020 9:48 pm
I'd be very interested to hear any feedback (positive or negative) on the b-em download, especially if anyone has managed to run it on Linux, either here or by PM.
Dom
nicolagiacobbe
Post by nicolagiacobbe » Wed Mar 11, 2020 7:58 pm
Thanks for the effort, I love having another emulator to compare and test.
I have tacked the building process under Linux (Lubuntu 16.04), it works. My first impression is that of an enhanced GUI and a little slower than b-em 2.2 but I haven't still measured the speed so take it with salt. The building process has been summarily logged in the attached log file.
log.log
Terse log of the compiling process for b-em w/ SID under Linux 16.04
(2.09 KiB) Downloaded 12 times
dominicbeesley
Post by dominicbeesley » Wed Mar 11, 2020 10:14 pm
Thanks Nicola, that is very helpful!
I've made a change to the source on git hub to get rid of those types, I think the rest (getting allegro) is covered in the general build instructions.
Did you try the "Paula" sound - did it work ok?
D
