Tower Defence Game - Part II
ChrisB
Post by ChrisB » Wed Feb 22, 2017 5:46 pm
So - it's been about 18 months since I touched this and have been meaning to get back to it but real life (tm) got in the way. So to carry on from the thread on retrosoftware:
http://www.retrosoftware.co.uk/forum/vi ... f=19&t=954
I've actually managed to set up a new development environment (old laptop died) and seem to be able to understand and modify my code - which is nothing short of a miracle :).
I've moved almost all game logic into assembler including loading of wave and level files (at the moment there will be 5 levels with 6 waves of up to 63 enemies each). I've also concatenated some of the disparate data files into monolithic chunks of data which should speed up loading and mean I don't hit the 32 file limit of the DFS. Looks like the requirement will be for a standard BBC with double sided disk drive.
Gameplay wise there is now a transition of waves (although not levels) and an indication of the level of your tower. I've also fixed the minor screen corruption from the bullets and display which level/wave you're starting. Also I've noticed that my superb design abilities (blind luck) mean that I can move the sprites in all 4 directions rather than just the three I had previously thought which should improve the level layout. I've also got placeholder content for intro and loader.
Things to do in no particular order:
  • Complete level logic including clearing out storage areas and allocating starting gold
  • Scoring and highscore routine - possibly with a table.
  • Sound - this might be a biggie
  • Possibly reallocating some of my code to different memory areas to be "nicer" - not sure it's necessary.
  • Level design and balance - this will be a considerable amount of work
(Admins - If this thread is in the wrong place please move it)
Re: Tower Defence Game - Part II
Post by tricky » Wed Feb 22, 2017 6:26 pm
Great that your back on it, really looking forward to playing it.
ChrisB
Re: Tower Defence Game - Castle Defender
Post by ChrisB » Sun Mar 05, 2017 7:42 pm
Update time - Firstly we have a name - "Castle Defender". I was forced to commit to this because I asked Dethmunk for some graphics which he as very kindly provided - and they are most excellent. Tricky - you've finally got the shading you asked for back in June 2015.
I've now added scoring - with a highscore. I might refine this to give maximum level reached - but not sure at this stage. I have completed the wave and level logic and because it seems I have some space in the code changed the way the waves are loaded (now using file handling) meaning I can keep them as a chunk of data (split per level for convenience.) This now means we're down do a single sided disk as the requirements - it might even fit on a 40 track disk.
Because Dethmunk is so fast with his graphics it has spurred me on to finalise level design - so we now have 4 screens rather than 5. Actual wave design and balance is still to do but some experiments yielded good results. I've moved some memory around that means I'm only using a couple of lower pages &900 - &AFF - should be safe.
Also new is an instructions screen and screen decoration outside of the game itself.
Lastly I've added some sound. Still a bit to do but using the OS routines doesn't seem to be causing performance issues. It definitely feels like a game now - rather than a tech demo.
Current things to do are:
  • Finish off the sound.
  • Identify a bug that double counts some hits
  • Wave design and balance
  • Game over logic - Win vs lose - probably with a pretty graphic - I seem to have space.
It does feel like I'm on the home stretch!
Post by fwibbler » Sun Mar 12, 2017 4:57 pm
This is great! I'm really looking forward to this.
Are there any plans for an Electron version?
I only ask as I've just bought one and plan to get a MegaGames cartridge for it in due course...
Cheers!
ChrisB
Post by ChrisB » Sun Mar 12, 2017 5:25 pm
It's not a platform that I was ever familiar with BITD - if someone can give me a list of things I'll need to change I might be able to have a look when it's done. However I'd rather concentrate on getting a Beeb version out first.
From things I recall seeing I've got a custom screen mode (256x256)- is that supported ? Also right now I'm working with 3 channel sound (although I'm sure that could be cut down - it's only bleeps and whistles..). It also requires a disk system at the moment.
ChrisB
Post by ChrisB » Sun Mar 12, 2017 8:47 pm
Progress this week:
  • I've now added a Lose and Win message with a nice big piece of text - not quite as I envisaged (the bit manipulation just got the better of me) but I think effective. I've also used this for a lever transition message. It's also been my first foray into self modifying code :shock:
  • The highscore now has a percentage of the game complete and I believe that I now have all of the support code more or less complete.
  • I've fixed the double count bug
  • The sound is nearly complete (I have one "tune" left to do).
  • Dethmunk has finished the graphics off - and they are spectacular. Preview below...
I now have to get into the waves and balance work.
Post by FourthStone » Sun Mar 12, 2017 11:09 pm
This looks amazing! Can't wait to play test it :-)
Big fan of Kingdom Rush so if you're ever at a loss for inspiration that series of games pretty much defines the tower defence genre.
"Dodge This!"
kieranhj
Post by kieranhj » Mon Mar 13, 2017 6:55 am
Seconded! Great work, this is looking really nice. Can't wait to play it. :)
Dethmunk
Post by Dethmunk » Fri Mar 17, 2017 1:08 pm
You're welcome Chris. Enjoyed doing those graphics... Looking forward to the finished game. :D
Post by RobC » Fri Mar 17, 2017 2:41 pm
What a beautiful game! Really excellent work.
ChrisB
Post by ChrisB » Sun Mar 19, 2017 11:20 pm
Having said that the game is complete I keep finding things to add/fiddle with. The major achievement this week is actually putting together the first level and waves.
Other things I've added/changed.
  • Rationalised the sound calls - I was missing a lot of interrupts when things got hectic.
  • Added a quit function.
  • Added a "speed up" function for when things are going well.
  • Tidied up some of the text effects
  • Completed last "tune"
To do in the rest of the levels and then we might be somewhere near release..... :shock:
Post by tricky » Sun Mar 19, 2017 11:36 pm
Well done, keep it up.
ChrisB
Post by ChrisB » Sun Apr 02, 2017 5:47 pm
Just a quick note. Still working through levels (always knew this would be time consuming). I am about half way through level 3 (of 4). It's hard to judge the difficulty level - am I just rubbish - or is this level actually impossible ;)
pau1ie
Post by pau1ie » Tue Apr 04, 2017 2:11 pm
I just tried this on a real BBC Master with datacentre and it works fine, and looks amazing. The only download I could find was from August last year - is that the latest you have posted? From your comments you have done quite a lot since then.
I like it a lot!
ChrisB
Post by ChrisB » Tue Apr 04, 2017 6:21 pm
Fantastic - thanks for the feedback. It looks a lot better these days.
Yes - that is the last download there will be another one "soon".
ChrisB
Post by ChrisB » Sun Apr 09, 2017 5:36 pm
Having said it was "complete" I've been doing more code this week... :?
When lots of sounds were playing my interrupts were being missed on the vsync causing the screen to flash. I've therefore re-jigged the interrupt code to use a second timer to fire at the end of the screen to reset the palette. This seems to have fixed the problem and the play-field is now rock solid. It might not be the "best" way to do this but it seems to work.
However in doing so I blew my budget for the code at &0900 - &0AFF. Because &B00 seems to cause the emulators in "Master" mode problems I have split the code into two versions - one for the B/B+ and one for the master. They are identical except the master has a block of code at &0E00 to &11FF rather then the BBC B at &0900 to &0CFF. My main code references the "low" code so I have a B and Master version of that. I've added this to the loader the automatically get the right version for the machine you're on.
And finally - since I "gained" two pages I've added a "flash" to the sprites for when they are hit which makes it more obvious what is going on.
I'm also progressing with the levels/waves and am about half way through the final level 4. After that will be a tweaking/rebalancing exercise - but I hope that will be a minor effort.
Site Admin
Post by Arcadian » Sun Apr 09, 2017 5:43 pm
Really looking forward to seeing the final version of this - is there any chance you could post a little video of the latest build whilst we await the completed release? :)
ChrisB
Post by ChrisB » Sun Apr 09, 2017 10:03 pm
Hmm. Seems Beebem under Windows 10 doesn't play nice with video export :(
If you can point me at a good way to capture the video I'll see what I can do...
Post by lurkio » Sun Apr 09, 2017 10:16 pm
ChrisB wrote:Hmm. Seems Beebem under Windows 10 doesn't play nice with video export :(
Quick and dirty way: film your computer screen with a smartphone!
ChrisB
Post by ChrisB » Mon Apr 10, 2017 6:10 pm
Ok - Recorded using a screen recorder so not the best quality but here's the first two waves played with deliberate mistakes :D
https://youtu.be/uvvMuyl4jWs
Balance is still being tweaked but I would expect that the first level (five waves) should be reasonably easy to beat.
Post by tricky » Tue Apr 11, 2017 6:40 am
Looking great.
sirmorris
Post by sirmorris » Tue Apr 11, 2017 6:55 am
Awesome! One of my favourite genres. Great work there.
ChrisB
Post by ChrisB » Fri Apr 14, 2017 2:49 pm
Update time - After some playtesting I discovered it was possible to "spam" a level with a single or few high level towers. Consequently I've re-jigged the costs considerably. As a side to this I've ended up basically doubling all the gold values since larger number are always better :wink:
I've also reduce the score digits by one since I don't think it's possible to get scores that big (will wait to be proved wrong).
I've also finished off the remaining waves which means the game is complete. It looks like it might be time for a release.... :!: [-o<
oss003
Post by oss003 » Fri Apr 14, 2017 3:21 pm
Great job, nice game .... =D> =D> =D>
Keep up the good work!
Greetings
Kees
