Help required for the new BBC games archive
Re: Help required for the new BBC games archive
Post by leenew » Mon Jul 04, 2016 5:03 pm
Ok I am stopping until I get a definitive answer as to what to do.
Got discs 91 to 95 done with Bem but each shot is 942K.
Got disc 91 done with beebem at 640x512 each shot is about 5 to 8K
Lee.
Post by sydney » Mon Jul 04, 2016 5:15 pm
640x512 on beebem:
1280x1024 scaled down to 640x512 on beebem:
I think the second image looks better. I've not seen any b-em images to compare so if you have a similar screengrab could you post it then we'll know which way to go.
If you zip up the images from b-em and email them to me I'll see if I can reduce the file size as I downloaded a batch image manipulation tool when I first looked at this.
Post by leenew » Mon Jul 04, 2016 5:51 pm
emailed.
Post by tricky » Mon Jul 04, 2016 6:49 pm
Data point, my b-em 640x512 images are usually under 10k.
Are they actually BMPs just with a .png extension?
I can't remember which emulator had which settings, but i think they both have s few.
Post by leenew » Mon Jul 04, 2016 7:09 pm
Yep .bmp with a .png extension! :D
I started with default settings as that is what Paul said to use, but they are rather large...
Lee
Post by sydney » Mon Jul 04, 2016 7:12 pm
Lee, you have mail.
Post by leenew » Mon Jul 04, 2016 7:39 pm
Cheers Simon,
I will do discs 96 to 100 tomorrow or Wednesday...
Lee.
Post by leenew » Mon Jul 04, 2016 8:59 pm
Telly was rubbish so did 96 to 100...
Simon I will email them to you now...
I will try and work though the rest tomorrow...
Lee.
pau1ie
Post by pau1ie » Mon Jul 04, 2016 10:02 pm
I have got the release type working on my laptop. I wanted to add a column to the game table, and add another table for descriptions, but the user I am using to connect doesn't have these privileges, which is probably wise as I am using the website user. Can you either give me a user with better access, or run the following to create the structure required:
alter table games add column ( reltype char(1));
create table reltype (
  id char(1),
  name varchar(255)
ALTER TABLE `reltype`
  ADD UNIQUE KEY `id` (`id`);
Post by sydney » Mon Jul 04, 2016 10:56 pm
I think this is the rest of the screenshots, from disk 103 to 112.
EDIT: :oops: Forgot to resize them so uploaded new zip with resized images.
resized.zip
(131.9 KiB) Downloaded 31 times
Post by leenew » Tue Jul 05, 2016 8:42 am
Hi Simon,
Not sure they were on the list!
All the text adventures were on discs 91 to 100.
There are about another 80 random Mode 7 games/ bad screen shots on my list that I will do today if possible... them I will upload them all together.
If anyone notices any other bad/incorrect screen shots then let us know!
Lee.
Post by sydney » Tue Jul 05, 2016 9:19 am
leenew wrote:Hi Simon,
Lee.
leenew wrote:Telly was rubbish so did 96 to 100...
Which list are we working from?
Using screenshots.xls I removed everything up to and including disc 100 which left the following:
PAGE	TITLE	Good / Bad	comments	DISC
43	secret diary of adrian mole	b		112
48	star trek RH	g		111
49	Strategy 2	b		111
55	world cup manager	b		111
15	dicer	b	Mode 6	110
48	star trek game	b		110
48	Strategy 1	b		110
51	timetrek	b		110
21	golden shot	b		109
30	mastermind GAMES PACK 1	b		108
26	j.r	b		107
11	city defend	g	re do shot	106
45	soccer supremo	b	Mode 6	106
31	micro olympics	b		104
8	bright eyes	b	Mode 2/5	103
Post by sydney » Tue Jul 05, 2016 9:22 am
Ahh. You started at 91! Discs 1 to 90 still need doing then.
Post by leenew » Tue Jul 05, 2016 10:02 am
Yep!
There's about 80.
I have done 20 already :D
Lee.
PitfallJones
Post by PitfallJones » Tue Jul 05, 2016 10:33 am
Here's one fix - Castle Raider currently has a picture of Castle Quest
PJ
Post by leenew » Tue Jul 05, 2016 10:34 am
Good spot 8)
PitfallJones
Post by PitfallJones » Tue Jul 05, 2016 10:38 am
And Cholo shows a title screen (Although adding title screens might be a nice stage#2 task...)
PitfallJones
Post by PitfallJones » Tue Jul 05, 2016 11:03 am
Here's some more fixes - mostly strange rez games - like Boffin - it has some really wide rez I don't think I've seen in any other game...
Arcadians
Boffin
Contraption
Nutcraka
Qwak
Sentinel
And
Shoveit
fixed.zip
(40.04 KiB) Downloaded 27 times
Post by leenew » Tue Jul 05, 2016 12:49 pm
Cool.
I have re-taken the rest of the Mode7 and the dodgy shots and will email them to Simon when I get home, and then upload the lot.
2 games I had problems with were "Curse of the Middle Kingdom" and "Lords of Time" on discs 59 and 98 respectively.
Curse would not load on B-Em (Disc changed error) but did on BeebEm.
And Lords of Time would not load on B-Em, it just crashed out, but loaded on BeebEm..
These need looking at.
I will try them on the real beeb tonight.
Could someone else confirm the problem please.
Lee.
Post by tricky » Tue Jul 05, 2016 4:42 pm
Could also use jsbeeb ;)
Post by leenew » Tue Jul 05, 2016 4:46 pm
Yep. Will do Richard, but the idea of these games is that they just work, whether it is on a real beeb from disc, from Datacentre, or from BeebEm, B-Em, or JSBEEB.
It's a lot to check! But most have already been checked and are fine :D
Lee.
Post by tricky » Tue Jul 05, 2016 4:52 pm
I only meant to get the screenshots done, making the games compatible, or fixing the emulators are also good goals.
Post by leenew » Tue Jul 05, 2016 4:54 pm
Aah!
Well I *think* most of the dodgy ones have been re-done now.
I will upload them all tonight when I get in.
Then it's up to eagle eyed people to spot errors....
Lee.
Post by leenew » Tue Jul 05, 2016 5:39 pm
You have mail Simon!
***Simon - take particular notice of Curse of the middle kingdom - I did that one with Beebem and may not be as good.
Lee
pau1ie
Post by pau1ie » Tue Jul 05, 2016 9:55 pm
The database is designed to take more than one screenshot per game, so I did the following (The screenshot used is the one with the lowest "main" number). It would be worth checking that I haven't messed up. If you click on a game to get into the detail screen you can change the gameid number after the ? to the one below. I think there was a typo in Micro Olympics, so I corrected that, and I already had a better screenshot for 1984 so uploaded that.
update screenshots set main = 9000 where gameid in (1838, 248, 1894, 1907,1918 ,1937 ,1954 ,1966 ,1973 ,1974 ,1977 ,1986 ,1987 ,1997 ,1999);
insert into screenshots (gameid, filename,main) values (1838 ,'DISC103-BrightEyes.png',100);
insert into screenshots (gameid, filename,main) values (248 ,'DISC014-MicroOlympics.png',100);
insert into screenshots (gameid, filename,main) values (1894 ,'DISC106-CityDefend.png',100);
insert into screenshots (gameid, filename,main) values (1907 ,'DISC106-SoccerSupremo.png',100);
insert into screenshots (gameid, filename,main) values (1918 ,'DISC107-JR.png',100);
insert into screenshots (gameid, filename,main) values (1937 ,'DISC108-MastermindGamesPack1.png',100);
insert into screenshots (gameid, filename,main) values (1954 ,'DISC109-GoldenShot.png',100);
insert into screenshots (gameid, filename,main) values (1966 ,'DISC110-Dicer.png',100);
insert into screenshots (gameid, filename,main) values (1973 ,'DISC110-StarTrekTheGame.png',100);
insert into screenshots (gameid, filename,main) values (1974 ,'DISC110-Strategy1.png',100);
insert into screenshots (gameid, filename,main) values (1977 ,'DISC110-Timetrek.png',100);
insert into screenshots (gameid, filename,main) values (1986 ,'DISC111-StarTrekRH.png',100);
insert into screenshots (gameid, filename,main) values (1987 ,'DISC111-Strategy2.png',100);
insert into screenshots (gameid, filename,main) values (1997 ,'DISC111-WorldCupManager.png',100);
insert into screenshots (gameid, filename,main) values (1999 ,'DISC112-SecretDiaryOfAdrianMole.png',100);
I also imported the release type which is on the game detail page, and added a play button to that page while I was there. Next I need to try to get my head around the genre and release type search!
EDIT: These are the screenshots from resized.zip posted by sydney. I see I have a number posted since that need to be taken care of. Tomorrow!
PaulH
Post by leenew » Tue Jul 05, 2016 10:10 pm
I think Simon is having his birthday as he hasn't sent me the re-jigged screenshots back yet.
Just tried Curse of the middle Kingdom and Lords of Time on the real beeb and both work with DTRAP set on datacentre (as stated on the menu) but they do need investigating why they crash on the emulators....
Lee.
Post by sydney » Tue Jul 05, 2016 10:41 pm
At work atm. Might get them sorted when I get in (2am) if I'm not too tired.
Post by sydney » Wed Jul 06, 2016 3:10 pm
Lee - you have mail!
I think the site is absolutely fantastic! When I was doing the screengrabs the other night it was a case of click on the game, click download, click open in beebem and I was away! My laptop isn't up to running jsbeeb but there really isn't much difference when the game loads instantly into beebem.
I've updated my best games list and Jason mentioned that a 'Top 50' section on bbcmicro.co.uk might be a good idea. Certainly it might help those new to the beeb get a good idea of what the beeb can do and avoid some of the less playable games out there.
Also what do people think about a 'Random Game' button?
Post by leenew » Wed Jul 06, 2016 6:10 pm
Here are the screenshots that I did and Simon has ensmallened :D
EDIT by sydney: I removed the attachment and uploaded a new one later in the thread.
Along with the ones Simon did himself, that should be the majority of the bad ones eradicated :D
Lee.
Post by sydney » Wed Jul 06, 2016 7:22 pm
I'm afraid I didn't make em smaller I just made them pngs. I'll have a look when I get home and do what needs to be done.
