Image sizes
dp11
Re: Image sizes
Post by dp11 » Sun May 27, 2018 8:57 am
broken for my too , sorry :(
Re: Image sizes
Post by danielj » Sun May 27, 2018 9:00 am
Can you post a picture of it being broken? (and can you see what the link is for the image and post that too?
Re: Image sizes
Post by danielj » Sun May 27, 2018 9:06 am
OK - the issue is probably that you're suppressing mixed ssl/http requests and tricky had linked the image via http - I've changed that to https now, so you should see it. If you're set up like that you'll probably find that many externally linked images on the forum won't work - it's something you'll have to change on your end.
dp11
Re: Image sizes
Post by dp11 » Sun May 27, 2018 9:18 am
Still no luck for me :(
Re: Image sizes
Post by danielj » Sun May 27, 2018 9:28 am
Browser? I think it's your end alas, it's fine on my phone and computer, even after forcing reloads?
dp11
Re: Image sizes
Post by dp11 » Sun May 27, 2018 9:35 am
I'm using chrome on computer and phone. I've just tried IE on computer too and I don't get the image :(
The url appears to be :
 https://stardot.org.uk/forums/download/file.php?id=37787&mode=view
The the webpage the comes back says "
The selected attachment does not exist anymore."
Re: Image sizes
Post by danielj » Sun May 27, 2018 9:49 am
Works for me - even after wiping my cache?
dp11
Re: Image sizes
Post by dp11 » Sun May 27, 2018 9:51 am
Doesn't work for me . Some sort of permission thing ?
Re: Image sizes
Post by BigEd » Sun May 27, 2018 9:58 am
Feels like permissions. Danielj, can you have a look in a logged-out state?
ctr
Re: Image sizes
Post by ctr » Sun May 27, 2018 10:01 am
I can't see the image either, whether logged in or out. If I use wget I get a straight 404 not found.
Is it expecting a cookie to say you've accepted cookies? I've somehow avoided accepting the cookie permission thing.
Edit: This is unlikely to be the problem. Other images work OK. It's just this one.
Re: Image sizes
Post by sydney » Sun May 27, 2018 10:01 am
I can see the image both logged in and logged out.
Re: Image sizes
Post by sydney » Sun May 27, 2018 10:05 am
I just 'tested user permissions' as BigEd and I could see the image.
Re: Image sizes
Post by BigEd » Sun May 27, 2018 10:19 am
Very odd. I've tried three browsers. I checked some other recent posts and the images are OK but of course they might be different in some way.
viewtopic.php?p=204017#p204017
I notice tricky mentions using PNG format.
Re: Image sizes
Post by Elminster » Sun May 27, 2018 10:22 am
Seems to be that one image. I can see everything except that one image. Cant see it on Mac in Firefox or ipad in Safari. And I accepted everything yesterday.
Re: Image sizes
Post by Elminster » Sun May 27, 2018 10:25 am
Still, I sneaked off and tidied up what I was doing at Revival:<br>
<img src="https://stardot.org.uk/forums/download/file.php?id=37787&amp;mode=view" class="postimage" alt="Image"><br>
(double size, but only 3K as a .PNG)<br>
If I manaully put in the URL
I get:
Information
Re: Image sizes
Post by Elminster » Sun May 27, 2018 10:29 am
Same error on Mac on Safari and Chrome. Never used Chrome on stardot before (I use it for flash sites only).
Tried logged in and logged out. Same.
Tested with and without 'accepting' cookies message.
Re: Image sizes
Post by danielj » Sun May 27, 2018 10:48 am
How about now?
Basically the file had been uploaded, attached to the post, then deleted and included as an image - whilst this is a tidy way of showing an image, it means that the attachment gets orphaned in phpBB and it's possible that displaying orphaned images is somewhat unpredictable...
Re: Image sizes
Post by BigEd » Sun May 27, 2018 10:57 am
That's fixed it! I think that might be a trick which tricky does quite a bit- perhaps it's now a trick too far? This slightly earlier post does the same, I think:
viewtopic.php?p=203040#p203040
Re: Image sizes
Post by danielj » Sun May 27, 2018 10:59 am
Yup - basically I think phpBB doesn't like it - add to that, we do delete orphaned files...
Re: Image sizes
Post by BigEd » Sun May 27, 2018 11:00 am
Hmm, is there any way to check whether embedded images have been recently reaped? Or how many?
Re: Image sizes
Post by danielj » Sun May 27, 2018 11:06 am
Not really - we hit a point where we had several gigabytes of orphaned files. so we tend just to scrub them - it's usually when people have started posts, added attachments and stopped before submitting or else deleted the post. There's no way of telling which post an orphan should belong to. (I just zapped about 30, most of which were me testing things).
Re: Image sizes
Post by tricky » Sun May 27, 2018 11:13 am
I do sometimes linked to an attached file if it doesn't display, but never delete the attachment. It does look like the attached image has disappeared of scramble, but not by me, maybe before the two attachment fix.
Re: Image sizes
Post by BigEd » Sun May 27, 2018 11:16 am
ah, the multi-attachment bug - that would explain it. And should mean that reaping files is generally not going to be problematic. Phew!
Re: Image sizes
Post by danielj » Sun May 27, 2018 11:21 am
It could well have been that - I suspect we're OK now if that was the case.
Re: Image sizes
Post by 1024MAK » Sun May 27, 2018 3:31 pm
Each member can see the attachments they have by going to their user control panel, there, there is a menu item "manage attachments".
I don't know if orphaned files would show up here though.
Re: Image sizes
Post by hoglet » Sun May 27, 2018 3:44 pm
1683 attachments :shock:
Re: Image sizes
Post by jgharston » Mon May 28, 2018 12:10 am
I've been trying to get https working on mdfs.net, but something's not right as it comes up with "insecure site: self-signed certificate". At some point I/somebody/gremlins killed uploading images to the Wiki, and I've been prioritising that at the moment.
Re: Image sizes
Post by danielj » Mon May 28, 2018 5:23 am
You have to use a cert from an external provider, eg. Let's encrypt (which is free). It sort of proves the server with the cert is the server that requested the cert (but not who that actually is), and allows encrypted comms.
Re: Image sizes
Post by Elminster » Mon May 28, 2018 9:19 am
As Daniel says, over the last few years there has been a lot of tightening up on https, I.e. force tls 1.2, and the move away from allowing self signed certificates. Java is a particular pain. Were as development system you used to use self signed and only real ones on prod, you now have them everywhere, to stop the winging messages.
Re: Image sizes
Post by CMcDougall » Mon May 28, 2018 8:53 pm
viewtopic.php?f=45&t=13893
^ some of the pic's in this thread have gone pear shaped, on my mobby anyways, not checked lappy....
Only noticed as someone on ebay from France wanted a copy of my roms!
EDIT: just used that link straight into browser (still on mobby) & now they show proper :?
