Layout trouble: wrapping of long topic subtitles
feedback, comments and suggestions pertaining to the stardot forum
Post by BigEd »
Having recently updated my browser - Chrome - I'm finding that longer topic titles (actually, see below, long subtitles), when they belong to multi-page threads, are formatting very poorly. (I'm now running version 89.0.4389.82 (Official Build) (x86_64).)
Two examples visible here:
(I appreciate that the forum software is complex and not something we'd want to customise.)
Latest Firefox (86.0) is fine:
In (a very old) Safari all is well:
sweh
Re: Layout trouble: wrapping of long topic titles
Post by sweh »
I see that if I have the screen set to zoom in (eg 125%). At 100% it looks normal.
Rgds
Stephen
Post by BigEd »
Yes, I probably have a narrow setup, relative to font size, compared to many. But chrome can pretend to be an ipad, and that has the problem, even in landscape orientation.
Looks like the problem is when "left-box" of a multi-page thread needs to wrap (that's the long line of description below the topic title) - at that point, "pagination" seems to grab the vertical extent of the containing thing - which might be "row" or might be "row-item".
dominicbeesley
Re: Layout trouble: wrapping of long topic subtitles
Post by dominicbeesley »
I'm suffering the same now on my Android phone. It makes it pretty hard to use the forum. Have we worked out if Chrome or the sites cxs is at fault? I coyote message take a look later
dominicbeesley
Just sneaked a quick look and I have a quick "fix" no guarantee that this won't break other stuff but it might be worth a punt as the site is more or less unusable now on my phone.
Either: remove "float: left" from the .left-box style
Or: remove the "left-box" style from the topic-poster divs altogether
Or: add $("DIV.topic-poster").removeClass("left-box") somewhere on page as a bodge?
I'm sure a better css coder will be along to tell me that there is a better way but that is my 5 minute solution.
D
Post by BigEd »
Oh, that's good - a small change, and to CSS, which is defined in the theme. We already have a pair of themes, it seems, so our beloved board admins must already be comfortable with a quick copy-and-tweak.
Post by danielj »
Can people check if this is working properly now? I went and got my hands dirty under the bonnet....
Post by BigEd »
excellent - worked for me when I changed board preference (board style), from prosilver muted edits to ordinary prosilver.
(also I cleared the browser cache)
many thanks!
MartinB
Post by MartinB »
I can’t remember what mix of devices I was seeing it on - I just got used to it I think - but its fixed everywhere now thank-you, Windows and IOS. Well done Daniel, you are a very clever man.... 🤓 =D> 8)
Post by danielj »
MartinB wrote:
Mon Mar 29, 2021 10:29 pm
No, just stupidbrave enough to use vi on the live forum and copy what someone else suggested!
jms2
Post by jms2 »
Worked for me too, like BigEd I found I had to change the board style as well before it came into effect.
dominicbeesley
Works for me too
D
Post by DutchAcorn »
Also noticed this. I normally use Opera but had to switch to Edge. The issue is still there, at 100% zoom level.
Post by danielj »
Check the theme you're using and delete any cache, then force refresh the page. Edge and chrome use the same rendering engine so if fixed on chrome it should be OK on Edge!
sweh
Post by sweh »
Looks OK on my chromebook, where I first saw the problem. =D>
Rgds
Stephen
Return to “stardot FORUM”
