Attachment types permitted
AndyF
Post by AndyF » Fri Jul 20, 2018 4:29 pm
Although a decent range is present, .uef (tape files) is not.
Any chance of adding that please ? =D>
Mime type (as if you need to know) simply can be set at "application/octet-stream" I guess to make sure the browser tries to download it by default rather than open it. Maybe.
Andy
Re: Attachment types permitted
Post by danielj » Fri Jul 20, 2018 6:42 pm
The usual trick if a particular type isn't accepted is just to zip it. I'll see about adding UEF though :)
edit: done :)
MartinB
Post by MartinB » Fri Jul 20, 2018 6:46 pm
What is the allowed list? Is it shown somewhere?
AndyF
Post by AndyF » Fri Jul 20, 2018 9:26 pm
edit: done :)
Thanks Daniel. :)
Kind of. Click 'Attachments' then 'Add Files' as per normal, then when the browser file selection window opens (on a PC, unsure quite how a Mac handles this, very similar I expect) the 'allowed types' drop down you can view the types there. :)
Andy
MartinB
Post by MartinB » Fri Jul 20, 2018 10:14 pm
Thanks Andy 👍
Post by CMcDougall » Thu Aug 02, 2018 9:33 pm
may be should also allow Bitmap Image, as thats what BeebEm414 defaults to for capture screen for high scores!
had to change it in paint prog to jPeg, but lost quality of pic :(
Post by danielj » Thu Aug 02, 2018 9:55 pm
Use png - not sure if bmp will display in browser...
Post by 1024MAK » Thu Aug 02, 2018 11:13 pm
Not a good idea to allow bmp, as that then allows uncompressed image files. As Daniel says, convert to png :wink:
Post by Elminster » Fri Aug 03, 2018 9:12 am
Probably needs a feature request to give option in beebem to save as png as that is most popular web format after all the gif shenanigans
ctr
Post by ctr » Fri Aug 03, 2018 10:00 am
On the menu in beebem select:
File | Screen Capture Options | PNG Format
then select:
Options | Save Preferences
and you don't have to change it again.
