High Score Challenge S14 - R08 - Manic Miner
Re: High Score Challenge S14 - R08 - Manic Miner
Not great yet but slowly getting there. Sometimes it would be great to have better remembery than forgettery.
Post by M_Ron »
I can’t get the disc image to load - says something about the disk being double sided and the wrong disk type being selected but I can’t find anything in Beebem’s menus.
Sorry for the shameful technophobia but can anyone help?
Post by MartinH »
... GAH! Eugene's Lair was *HARD*! 3 hours later, I finally made it through to die very quickly on Processing Plant!
9170!
Post by MartinH »
M_Ron wrote:
Wed Sep 23, 2020 6:59 pm
BeebEm does that to me too - I just hit ok twice and then it loads normally...
Post by chrisn »
MartinH wrote:
Wed Sep 23, 2020 8:00 pm
Same here... 10,538
I get the same msg, the disk appears to still boot correctly and I can play the game on BeebEm.
Have you tried booting?
Post by MartinH »
Made it to the Vat... I think I'm missing something, because I can't get all of the keys.
12122
Don't panic. Just hit <ENTER> twice and it will load and you'll be fine. The nerves will calm and you will be into gaming goodness.
That last jump, forgot about that one......didn't succeed this time but I will now that most of that one is figured out.
Made silly mistakes, hopefully can push further.
Score: 20348
MartinH wrote:
Wed Sep 23, 2020 9:41 pm
Spoiler for level 7:
I think there are a couple ways to do level 7. The way I do it means I get all the keys before I face a perfectly timed jump over the last kangaroo, but it has to be perfect, it's why I haven't done it yet.....gotta get the jump down.
Got the jump down and that's it for the night.....bedtime.
Post by Venger »
Up to level 14 now. Frustratingly, the game before, I had 27250 and wasn't quick enough to press print screen. The lack of a high score table is frustrating!
Post by MartinH »
Wed Sep 23, 2020 11:57 pm
Ah, thanks!
Post by MartinH »
And armed with that new information... I encountered Kong and had a flashback to that horrendous Hard Hat Harry level! At least he ain't chucking barrels this time!
13300
Ailasue
Post by Ailasue »
This is more difficult than I remember. Looking at some of the scores so far, I need to try harder :D
Post by fwibbler »
It's harder than the Spectrum version I think.
Anyway, a small improvement...
Kweepa
Post by Kweepa »
I had to play through the whole game when I ported it to VIC-20.
The hardest level by a large margin is yet to come - The Warehouse.
I think I died 100 times.
chrissawer
Post by chrissawer »
Got a bit further this evening - score 8378
Post by MartinH »
After much effort I defeated Kong - I didn't realise they were switches, I thought they were things to avoid! Got past the amoebas and the Endorian Forest (that last apple was tough) and ended up in a new nightmare...
18356
Pretty sure I finished 12 but the game put me back in the same level after reaching the end... hmm.
Score: 25760
Post by MartinH »
Finally managed to get through that pesky telephone level. Amusingly, on this run, I managed to get Eugene stuck at the top of the screen, making it a cake walk to get to the exit. Not quite sure how I did it, but I think I collected the last item just as he reached the top of the screen. I wish I'd taken a screenshot. Is this supposed to happen, or have I encountered a bug?
Anyway: 22398!
Post by fwibbler »
Funnily enough that happened to me this evening. First time it's happened to me.
Eugene is supposed to move down and sit on the exit. He moves quicker on the BBC version than in the Spectrum original which makes it harder.
MartinH wrote:
Fri Sep 25, 2020 10:05 pm
...Amusingly, on this run, I managed to get Eugene stuck at the top of the screen, making it a cake walk to get to the exit. Not quite sure how I did it, but I think I collected the last item just as he reached the top of the screen. I wish I'd taken a screenshot. Is this supposed to happen, or have I encountered a bug?
I've had the same thing, it's either perfect timing or a bug, happens very rarely and nice to get if the jump is messed up which probably happens more often than it should.
Fri Sep 25, 2020 10:35 pm
It's a perk if you get it right. It's not a bug, I've done this several times.
Post by Venger »
A small increase in score but still level 14 :(
Post by MartinH »
Sat Sep 26, 2020 6:11 am
Ah, thanks for clearing that up!
Had a good run after lunch - and got to Level 14. Now I need to get there with enough lives to have a proper go.
26504
Post by MartinH »
Level 14 is INFURIATING! I just had an almost perfect run upto 14, with three lives intact and lost them all very quickly indeed. I don't think it helps that Willy seems to become more erratic and unresponsive when there's a lot going on on the screen. Worse yet, having had that good run my score was actually worse than the one I posted previously!!! ](*,)
I feel the need for beer :D
