High Score Challenge S11 - R1 - Donkey Kong Jr.
Post by KarateEd » Mon Jan 07, 2019 8:48 am
Season Eleven: Round One
Donkey Kong Jr. by TopCat96
:arrow: Round One starts at 9pm on Monday the 7th of January and ends at 9pm on Monday the 21st of January
:arrow: http://www.bbcmicro.co.uk/game.php?id=255
Link to Overall High Score Table...http://stardot.org.uk/forums/viewtopic.php?f=46&t=16309
Here's your chance to monkey around but don't go ape over it!!!........
Re: High Score Challenge S11 - Donkey Kong Jr.
Post by FourthStone » Mon Jan 07, 2019 9:39 pm
Starter score, takes some getting used to this one.
Score: 29600
Post by CMcDougall » Mon Jan 07, 2019 10:16 pm
had this BITD, but never liked it, still don't as it's Nintendo carbon copy rubbish :x
first time to level2 :shock: , but kept getting hit on top ropes with blue annoying things :roll:
a few goes got me 8,700
col
Post by klintworth » Mon Jan 07, 2019 11:34 pm
Going for the Low Score Challenge! :lol:
Post by KarateEd » Tue Jan 08, 2019 1:07 am
I'm winning the low score championship so far......never liked this bitd either.....
Post by KarateEd » Tue Jan 08, 2019 1:24 am
OK, now I'm losing the LSC.....
Post by richardtoohey » Tue Jan 08, 2019 6:21 am
Don't worry, I'll be along shortly to give you some low scores to beat :D
Guess you are playing on a Master going by the mangled characters at the top of the screen? Maybe I'll make a slight diversion to make a Master-compatible version ...
Post by KarateEd » Tue Jan 08, 2019 7:13 am
I think I know what to do on level 2 but it's firstly, hard to get there and then hard to achieve but we will persevere.
We will check this game on my Master to see if it does the same Richard.
Post by KarateEd » Tue Jan 08, 2019 7:35 am
OK, I have Mark's 4 way OS switch and when I use the 1.2 OS, the characters are just fine. I also tested it on 3.50 and the characters were wonky.....so, Paul, if you have Mark's 4 way OS switch, use 1.2 to get everything right. If not, it's a good idea to get. It will make your Master more compatible with Beeb software. btw, I like real hardware best. Only took 2 tries to get a better score than I had on the emulator.
Post by richardtoohey » Tue Jan 08, 2019 7:45 am
Leave me SOME excuses for my rubbish scores, Ed, please ... [-o<
e.g. "Oh, I was too busy working on corrupted characters under MOS 3.2 to play the game much"
Post by KarateEd » Tue Jan 08, 2019 7:57 am
Post by KarateEd » Tue Jan 08, 2019 7:58 am
Oh dear, Richard - you don't need any excuses, honest. You achieve this greatness all on your own.....really, it's a skill but I'm very happy you still compete......
Post by fwibbler » Tue Jan 08, 2019 6:53 pm
Well my first attempts were too embarrassing to post but i've managed a crap score now so...
Post by FourthStone » Tue Jan 08, 2019 8:03 pm
Second round (after level 4) is brutal, made it to level 2 but died a silly death on the first trampoline so hopefully can push higher with better luck and timing.
Score: 39900
Post by KarateEd » Tue Jan 08, 2019 8:53 pm
Really having trouble with level 2 but I'm sure I'll get it eventually......
ctr
Post by ctr » Tue Jan 08, 2019 10:35 pm
I didn't know this was a thing on the beeb. It's a bit tricky.
7,200
Post by FourthStone » Tue Jan 08, 2019 11:04 pm
It's another one of those pixel perfect and slightly frustrating logic games but underneath it's not so bad once you work out a way through each level barring of course the random monster bits.
Ed, which part on level 2 is giving you trouble?
For me, it's usually the top vines that bring me undone due to the unpredictable bird patterns, I try to wait near the left until a bird drops low, then race across to the middle area where the vines are longer and try to dodge the next bird then up and finish.
The bottom section is tricky but not so bad if you get your jumps right, make sure the second moving vine is all the way left before dismounting ](*,)
Post by KarateEd » Tue Jan 08, 2019 11:13 pm
New milestone - 10k........
and Richard, I hope you know I'm only joking.....
This is indeed a Tricky (not the programmer) game......
Post by KarateEd » Tue Jan 08, 2019 11:16 pm
I've yet to get to the vines after several tries. I usually die trying to get from the short hanging bar to the climbing dashed ropes.....haven't succeeded in getting there yet. I think it's just execution.
Edit: It was execution. I didn't get through all of level 2 but I see how to do it. If I had moved faster across the ropes I think I'd have been fine. Anyway, I picked up a few more points.
Post by KarateEd » Tue Jan 08, 2019 11:58 pm
Post by KarateEd » Wed Jan 09, 2019 2:22 am
Almost got through the 2nd level, froze at the wrong spot. I'll get it soon.
Post by KarateEd » Wed Jan 09, 2019 6:53 am
A bit better....new milestone - 15k....exactly
Post by richardtoohey » Wed Jan 09, 2019 7:32 am
Whimper ](*,) ](*,) ](*,) It's not a bad game but ... :oops:
Got to almost the top of level one a couple of times but go to pieces soon after. I didn't bother reading the instructions for any of the levels, what's the point ... :-({|=
Post by richardtoohey » Wed Jan 09, 2019 8:07 am
A tiny bit further ... 4,000 ...
Post by KarateEd » Wed Jan 09, 2019 8:33 am
A couple of hints:
Instead of just randomly going through the level, getting past the monsters, try to knock them off with the apples and other objects that give you 400 points. The monsters yeild 800 points. Besides, on the first level, it's difficult to get to the end if you don't 'bonk' the ones on the last vines. They are merciless in chasing you.
Be patient, sometimes moving gets you lower on lives.
As far as I can see, all these levels have a route to get through them, although I've not seen level 4 yet. Patience rewards. The monsters are easy to kill once you see how slow some of them move.
Keep it up Richard, you're doing fine. I was about there when I got started on this too.....
Post by KarateEd » Wed Jan 09, 2019 8:55 am
Last one for the wee hours of the morning. Finally saw level 4, now to become good at them all now that I know what to do.
But.....I'm not scaring you yet FS......
Post by KarateEd » Wed Jan 09, 2019 10:52 am
OK, maybe I'm starting to scare you now because I think I've figured out how to do this, now it's just a matter of refining and tuning to get it better.
Post by KarateEd » Wed Jan 09, 2019 7:13 pm
Another bump up this AM
Post by fwibbler » Wed Jan 09, 2019 8:06 pm
My latest attempts...
Post by klintworth » Wed Jan 09, 2019 10:04 pm
I’m using my new Compact with MOS 5 ! I guess the OS switcher may not work with it! On holiday in Quebec City until Sunday - getting very scared with these high scores! That’s why I’m working on the LSC!! :lol:
