Snapper - no sleep 'till the acorn!
Post by M_Ron » Sat Aug 18, 2018 8:29 am
Can anyone get passed the damn acorn level:
https://youtu.be/YsDDv48lKlo
aerworuld
Re: Snapper - no sleep 'till the acorn!
Post by aerworuld » Sat Aug 18, 2018 9:43 am
There's a cheat kicking about for Snapper :twisted:
Post by M_Ron » Sat Aug 18, 2018 3:30 pm
Lol, well only to same level. I just can't get passed the damn acorn.
I've read about patterns to follow on the arcade version of pacman. Does anyone know whether such things exist on Snapper?
Post by CMcDougall » Mon Aug 20, 2018 11:05 am
cheat disc for it here, don't know whatit does though....
http://www.stairwaytohell.com/bbc/sthco ... CH9_r1.zip
Wouter Scholten
Post by Wouter Scholten » Tue Aug 21, 2018 7:10 am
I had a few emails about this in 1996 from someone who wondered about the fruits, he thought I could try out due to my high scores and so I played the games then to note the order of fruit. With V1 I noted in that email that the acorn repeats, with V2 I noted at the end of the list of fruits only: acorn,... I can't remember if with V2 the acorn repeats, or that I assumed it repeats.
My score with V2 is 184k, so about 20 k higher than your score from a few years ago, not sure if I got more bonuses or got past the first acorn level. I can't try now, everything is in storage. I would assume the acorn level just repeats, and perhaps gets faster. So with "can't get past the acorn level", do you mean you die or that you keep seeing only acorns at each next level? (in V2 I presume)
Last edited by Wouter Scholten on Tue Aug 21, 2018 7:22 am, edited 1 time in total.
Post by flaxcottage » Tue Aug 21, 2018 8:01 am
BITD I taught a student who, amongst his many accomplishments, was able regularly to score over 1 million on snapper version 1. :shock:
He had learned the patterns of movement of the 'enemies' and 'ghosts'. He was put to the test one afternoon and met his target easily within the double lesson and without losing a single 'life'. I do not remember anything appearing after the acorn. The acorn appeared to be the top fruit. If I recall there were multiples at some point.
