png does the same
Edit:
How can it be a) cumbersome and b) quick and easy, at the same time?KarateEd wrote:I just <SHIFT><PRTSCRN>, paste into Paint, crop in paint, close paint and paste again. It's cumbersome, quick and easy. Works every time. I've only had trouble this way with stuff I've taken with my camera which won't be happening any more because it's no longer connecting to my computer properly.
Ed......
Trust me Wouter, when you're me, it can be.... it's cumbersome if you read the words because it 'appears' to be many steps. In reality, at first it was cumbersome because I almost never used Paint but now it's quick and easy because I get it done in about 30 seconds, start to finish. Until you know the process, it's slow.... and dare I say..... cumbersome. I'd say it's truly a Retro way.Wouter Scholten wrote:How can it be a) cumbersome and b) quick and easy, at the same time?KarateEd wrote:I just <SHIFT><PRTSCRN>, paste into Paint, crop in paint, close paint and paste again. It's cumbersome, quick and easy. Works every time. I've only had trouble this way with stuff I've taken with my camera which won't be happening any more because it's no longer connecting to my computer properly.
Ed......
Yep, that works, thanks!FourthStone wrote:You can link to your own files once they're uploaded, I've had the same issue before but not sure what was causing it... seems ok for me to post jpg or png as inline at the moment though... maybe it's a browser issue?
What you can try is attaching as normal, then preview, then copy the attachment link address, then paste as img tag as below...
You can also remove the inline tag so that your message only contains the img tag... make sense?
actually, I figured you probably meant it like this, i.e. a series of simple steps, but still 30s for 1 pic is not so fastKarateEd wrote:Trust me Wouter, when you're me, it can be.... it's cumbersome if you read the words because it 'appears' to be many steps. In reality, at first it was cumbersome because I almost never used Paint but now it's quick and easy because I get it done in about 30 seconds, start to finish. Until you know the process, it's slow.... and dare I say..... cumbersome. I'd say it's truly a Retro way.Wouter Scholten wrote:How can it be a) cumbersome and b) quick and easy, at the same time?KarateEd wrote:I just <SHIFT><PRTSCRN>, paste into Paint, crop in paint, close paint and paste again. It's cumbersome, quick and easy. Works every time. I've only had trouble this way with stuff I've taken with my camera which won't be happening any more because it's no longer connecting to my computer properly.
Ed......
Ed......
Well, yes and no - as I'm retired, time isn't of the essence for this task as I don't have a boss anymore. I crop the picture and do the resave so it's not unreasonable especially since I also get it up online in that time frame.Wouter Scholten wrote:actually, I figured you probably meant it like this, i.e. a series of simple steps, but still 30s for 1 pic is not so fastKarateEd wrote:Trust me Wouter, when you're me, it can be.... it's cumbersome if you read the words because it 'appears' to be many steps. In reality, at first it was cumbersome because I almost never used Paint but now it's quick and easy because I get it done in about 30 seconds, start to finish. Until you know the process, it's slow.... and dare I say..... cumbersome. I'd say it's truly a Retro way.Wouter Scholten wrote:
Ed......
Why aren't you updating my score?KarateEd wrote:High Score Tables Updated......
Ed......
Hi Barbarossa,barbarossa69 wrote:Why aren't you updating my score?KarateEd wrote:High Score Tables Updated......
Ed......
I know it's bad... but it's not THAT bad...
Yeah that is my best score, it's showing now.KarateEd wrote: If your last score was 14,575 then it's up to date. Try refreshing the page. If you just go back and forth between pages then it won't show the updated image. You have to refresh the page too.
If that's not your last score then I don't have another higher score for you. Perhaps you could upload it if it is higher than this.....and no, it's not that bad. This is a pretty hard game that takes time to master.
Hope that helps,
Ed......
This game really requires time put in or you have had to play these types of games your whole life almost. I'm much the same as you, just stubborn.barbarossa69 wrote:Yeah that is my best score, it's showing now.KarateEd wrote: If your last score was 14,575 then it's up to date. Try refreshing the page. If you just go back and forth between pages then it won't show the updated image. You have to refresh the page too.
Hope that helps,
Ed......
I think it's pretty apparent this sort of game isn't my forte...
KarateEd wrote:Only a few more hours to put in nominations for the next season folks. Kindly put any you have before 9 PM this evening UK time.
Thanks,
Ed......
FourthStone wrote:KarateEd wrote:Only a few more hours to put in nominations for the next season folks. Kindly put any you have before 9 PM this evening UK time.
Thanks,
Ed......
I find level 3 the hardest of the first 5 levels at least. Once I figured out how to get through 3, and it took several times, then life got easier. Now level 6 is my bane.MatthewThompson wrote:New high score, still can't get to level 4 .
I had exactly the same issues with level 3 but keep at it and you'll break through. Once you do, you will probably get through it nearly every time after that.MatthewThompson wrote:marginally better score, but still level 3 again, the jump in difficulty from level 2 is large , and too much going on at times and very difficult to see things sometimes too.
