High Score Challenge S11 - R9 - Impact!
Post by KarateEd » Mon May 13, 2019 4:28 am
Season Eleven: Round Nine
Impact by Klintworth
:arrow: Round One starts at 9pm on Monday the 13th of May and ends at 9pm on Monday the 27th of May
:arrow: http://www.bbcmicro.co.uk/game.php?id=2431
Link to Overall High Score Table...http://stardot.org.uk/forums/viewtopic.php?f=46&t=16309
If you don't 'break out' you may lose your marbles!!!.....
Re: High Score Challenge S11 - R9 - Impact!
Post by klintworth » Mon May 13, 2019 6:01 pm
Starter score - not got beyond first level yet!! 43300
BBC B Issue 4 & 7, BBC B (USA), BBC Master, Electron, BBC Master Compact, Olivetti PC128S, Castle A7000+
Post by M_Ron » Mon May 13, 2019 8:37 pm
Cool game!!!
Post by fwibbler » Tue May 14, 2019 7:16 am
I cannot get the '*' key to work...
I've tried using the Default mapping and the Logical one without success.
Any thoughts anyone?
Thanks.
(Edit)
I've setup the user keyboard mapping so that the @ key is now the * key, which works on the BBC when I press it, but still no joy in the game itself...
Post by FourthStone » Tue May 14, 2019 7:28 am
Oh boy this one is zippy, anyone know what star key (adjust position) does?
Score: 109600
Post by fwibbler » Tue May 14, 2019 7:58 am
Ok, I got it now.
Had to press ever key on the board to find it but finally found it.
So, my first score first thing in the morning so I may struggle to beat it.
Post by fwibbler » Tue May 14, 2019 2:49 pm
It allows you to aim the ball before it launches.
Also it allows you to implement the upgrade selected in the box at the bottom right.
Post by chrisn » Tue May 14, 2019 3:29 pm
Great choice of game... I never really played this before, but it's good. I got to level 3... 125,000
Post by fwibbler » Tue May 14, 2019 3:40 pm
Never actually liked this one BITD, preferred Arkanoid on the Speccy.
However, this one seems a tad easier.
Post by FourthStone » Tue May 14, 2019 7:41 pm
Which key was it? I feel like I'm missing something here :lol:
Post by fwibbler » Tue May 14, 2019 7:43 pm
Its the }] key next to the Enter key.
Post by M_Ron » Tue May 14, 2019 8:45 pm
Would you explain how to do this, please? I cannie get it to work!
Post by fwibbler » Wed May 15, 2019 7:58 am
As you collect the U shapes, the symbols in the bottom right box are underlined in turn.
Pressing the 'activate' key activates that powerup.
Post by KarateEd » Wed May 15, 2019 6:01 pm
My score is rediculously low but I've not played this one before and don't really get how some of it works. Seems a good game though and if I get a chance I'm sure I'll beat this less-than-novice score.
Post by FourthStone » Wed May 15, 2019 7:44 pm
Thanks for that =D>
One thing to note is that the U shapes when collected and not used give a bonus at the end of the level, 1000 points for each U collected.
Another thing to note is now that I know how to use the powerups my gameplay has gotten worse due to focusing on getting powerups :lol: ](*,)
Post by chrisn » Wed May 15, 2019 10:36 pm
There's info on the power ups available, and some tips, here.
A small increase, still on level 3... 135,300
Post by KarateEd » Thu May 16, 2019 5:32 am
Got to level 2...... 46,700
Post by KarateEd » Thu May 16, 2019 6:28 am
Last one for the night ...... 76,200
Post by FourthStone » Thu May 16, 2019 9:55 am
Anyone have details for bonus items? I know a few, others are not so obvious or I haven't tried them as yet...
Score: 120700
Post by fwibbler » Thu May 16, 2019 12:54 pm
1st Not sure : Makes invisible blocks visible
2nd Not sure : Destroys badies on screen
3rd Not sure : 3 missiles (destroy everything in their path)
Post by chrisn » Thu May 16, 2019 4:59 pm
It's all in the link I shared (plus some more tips)...
Slowdown - 1 token
Halves the speed of the ball. May be selected more than once if you collect more tokens.
Magnet - 2 tokens
Allows you to catch the ball and hold it (for about two seconds).
Divide - 3 tokens
Splits the ball into three.
Wide - 4 tokens
Enlarges the bat.
Torch - 5 tokens
Lights up invisible bricks.
Laser - 6 tokens
When selected, you can fire laser bolts by pressing RETURN.
Smart bomb - 7 tokens
All aliens are removed from the screen and do not reappear.
Missile - 8 tokens
Up to three missiles can be launched, one at a time, by pressing RETURN. Missiles can destroy multi-hit bricks with a single hit.
Force field - 9 tokens
An invisible force-field encircles the ball and allows it to smash through bricks and aliens without being deflected. With the aid of the force-field, the ball can pass through, but not destroy indestructible bricks.
Post by fwibbler » Thu May 16, 2019 6:33 pm
Knowing about the unused token bonus at the end of each level helps...
Post by FourthStone » Thu May 16, 2019 7:23 pm
Ah missed your link in all the excitement :oops:
Helps to know about the aliens, sometimes they actually help by deflecting the ball to a few remaining bricks that the ball seems doggedly determined to bounce logically around and missing ](*,)
Post by KarateEd » Fri May 17, 2019 3:15 am
A bit better - 94,900
Post by KarateEd » Fri May 17, 2019 3:32 am
Post by fwibbler » Fri May 17, 2019 4:41 am
Couple of tips:
First job is to activate the magnet powerup. This enables you to aim the ball and also helps you collect other tokens.
After that, the extended bat helps as does the wrecking ball.
Those three powerups can be combined.
Post by KarateEd » Fri May 17, 2019 4:57 am
ok, broke the 100k mark - 112,200
Post by KarateEd » Fri May 17, 2019 5:13 am
Also something to note - when you finish a screen, if you have collected some tokens then you get 1000 Bonus for each token that's been collected. I got 7 collected on one screen, finished the screen and got 7000 points in bonus.
Post by FourthStone » Fri May 17, 2019 9:14 am
Great minds :wink:
Also something to note - when you finish a screen, if you have collected some tokens then you get 1000 Bonus for each token that's been collected./quote]
Post by FourthStone » Fri May 17, 2019 8:33 pm
Blasted through levels 3 and 4.
Score: 189700
