High Score Challenge S11 - R3 - Boffin
Re: High Score Challenge S11 - R3 - Boffin
Finally did 13 with only one life lost, straight through 14, floundered on 15.
Only if you get good enough, only if you get GOOD enough!!!
Ed......
Yeah, I think I like this more than Chuckie Egg as well now that I have got into itCMcDougall wrote: ↑Thu Feb 07, 2019 6:10 pmBoffin2 certainly did, hence I loved it more than chuckle egg & monsters![]()
Lee W
Proud owner of many Electrons, some Beebs, a couple of Archies, some Commodore 64s, Amigas, Atari STs and an Atari Falcon 030
Lemmings are for life, not just the 90's... https://www.lemmingsworld.me
Got to level 8. Boy this one is a little tricky. Need to think on how to do this one...
New high score = 93520
Lee W
Definitely the last go from me. Sorry Col.
126985
126985
Sneaking up on.....and I do mean sneaking.....200k....
Ed......
Now it's starting to get really crazy. I'm not a fan of the 'yellow' levels.....
Ed......
Ed......
- FourthStone
Broke 200k myself, thought I might get a longer rest from playing but everyone has caught up
For some reason I had the impression the game had 13 levels... anyone know how many total levels there are?
Score: 210365
Score: 210365
I thought cave 15 was impossible and then cave 16 came along and zapped my remaining lives in the wink of an eye!
There will be NO REST for you FS......FourthStone wrote: ↑Mon Feb 11, 2019 7:59 amBroke 200k myself, thought I might get a longer rest from playing but everyone has caught up![]()
Ed......
- FourthStone
I'm feeling the same way about cave 19, cannot work out how to get one horseshoe tucked away between two platforms...
Indeed it's been a great season with lots of close scores
New high score =135365
Lee W
Well, unluckily, didn't make through leve 16 I think, the one before the yellow spider screen (the 2nd yellow screen)....had I gotten that, I'd be 2nd but because I didn't, I'm still where I was but with a slightly higher score.
Ed......
- FourthStone
Today's effort... I didn't complete cave 19 even with 11 attempts but I did work out how to get the last horseshoe so hopefully can push a little further next run, it's all about precision pixel placement at these levels.
Score: 254280
Score: 254280
Can't even remember what cave I was on, but its a real bugger.
Dont think I'm going to get further than this.
- FourthStone
Finally finished cave 20 and there are only 20 caves in total
Bad news is that caves 21-40 are a repeat of 1-20 with reduced colour but no other penalties enforced which makes for good scores but a long game.
Caves 41+ have a time limit which means you have to perfectly time every move and collect time potions in correct order without slow downs to be able to complete the level... it was quite challenging and a nice twist after the easy'ish 21-40 caves.
I made it to cave 43 and can't see myself progressing further for now.
Score: 560495
Score: 560495
Wow, you are kicking serious butt FS......nice going. i think it's safe to say your lead is likely to hold up.
Having trouble with the yellow spider level where you get chased right away. I'm sure I'll eventually figure it out but not in time to catch you I don't think.
Ed......
- CMcDougall
- FourthStone
If it's the jumping one where you have to jump across multiple platforms, jump all the way to the last platform then drop down and use the umbrella just before hitting the deck.
Sometimes though the guy jumps to far or fast and ends up dying, next turn be ready with right and jump keys already pressed down and the timing seems to change a bit to allow a continuous series of correctly timed jumps, remember to ignore the last horseshoe...
If you've timed it right you can use the tramp behind the spider to reach the last horseshoe then carefully come back underneath it to finish the cave.
Yes, it is that cave..... I was attempting to get the last horseshoe exactly how you described before you told me so guess I was on the right path to success, just couldn't find the right spot. One time I got to this level with 18 lives and lost them all very quickly. Should have saved that one to practice, ah well...... thanks for the tips, at least I know I'm on the right track.FourthStone wrote: ↑Tue Feb 12, 2019 7:39 pmIf it's the jumping one where you have to jump across multiple platforms, jump all the way to the last platform then drop down and use the umbrella just before hitting the deck.
Ed......
Level 18 is bugger. It's not that I don't know how to solve it, I do.....it's just that the timing is so critical that right off the get go you could be just trying to bump your score up with no chance of completing the level.....interesting but tough.
Ed......
- FourthStone
I was down to 3 lives left trying to get past cave 18 on my previous high score run, the timing and luck factor is crucial... the next cave is even better
but after that it's all cream
In practice on my Master i have gotten through this level. You're right, it is very tight timing, especially that first jump. I always feel if I can get that first one done then I have a real chance. The 2nd last one I played, I get onto that ledge and hit the wrong key and as they say, that's all she wrote....it is fun though. I hardly remember 19 on the Master but I do remember it being tough.FourthStone wrote: ↑Wed Feb 13, 2019 7:37 pmI was down to 3 lives left trying to get past cave 18 on my previous high score run, the timing and luck factor is crucial... the next cave is even betterbut after that it's all cream
Ed......
Finally, passed 200,000!
Such an enjoyable game.
Finally got past 18 to 19 and the agonizingly horrible jumps just start all over again......blah.....
Ed......
- FourthStone
