Amiga 500 fast RAM + IDE
classic non-acorn hardware, software & languages
cmorley
Post by cmorley » Wed May 13, 2020 6:14 pm
Made some good progress with my fast 8M RAM upgrade for the Amiga 500. I modified it to generate the CPU clock and with a 68000P10 it will run at 13.7MHz just fine. I might build the overclock capability into the production device.. :-k
So 8MB of fast RAM + IDE interface :)
I might put 16MB of SDRAM on it to fill in some of the holes in the memory map & provide more fast RAM in the ranger RAM area. I think there is another MB or two in the memory map that could be added too for maybe 11.5MB or 12MB increase. 8)
Dev board:
Mandatory SysInfo screenshot:
Re: Amiga 500 fast RAM + IDE
Post by sydney » Wed May 13, 2020 7:45 pm
Woohoo!
I'd love one of those! I won't be able to afford one until I'm back to work but I will definitely be after one. Definitly keep the overclock!
I presume it fits in the cpu socket and if so is it fully internal? And it'll need kickstart 2 or 3 to have the code for the hard drive?
All I'll need after that is a super Denise and I'll be a happy chappy!
The Amiga is a great machine but to use it seriously you need extra ram and at least 1 extra floppy drive, a hard drive is ideal though.
Post by sydney » Wed May 13, 2020 7:51 pm
Looking at the Sysinfo screenshot, does it really say 1.11 times a standard 1200? Is that right?
Also why 13.7Mhz for the overclock?
trixster
Post by trixster » Wed May 13, 2020 7:58 pm
A stock A1200 has no fast ram, so everything shares the 2mb chip ram. This really slows down the 14mhz 020 as it sits waiting for it's chance to access thnis slower ram after the custom chips. if you fit some fast ram you pretty much double the A1200's speed.
Post by sydney » Wed May 13, 2020 8:08 pm
Yeah. I knew about the fast ram doubling the speed but didn'trealise the bottleneck would have affected the performance so badly. Commodre really messed up with the 1200 didn't they? It was my first amiga and I loved it but it should have been so much better. I wonder what the performace would have been like if it came with 1mb chip and 1mb fast ram, with both being expandable on the motherboard.
trixster
Post by trixster » Wed May 13, 2020 8:19 pm
it wouldve been a much more competative machine! commodore really made some bizarre decisions in their later years. in the 4000 the A3640 processor card was deliberately made as cheap as possible and without any local 32bit memory, so it too was crippled by motherboard ram speed. the 25mhz 040 should have been very rapid but it was hamstrung.
cmorley
Post by cmorley » Wed May 13, 2020 9:07 pm
Yes 68000 drop in board when done and dusted. You'll need patched kicstart or 3(?), 3.1 or 3.1.4 to boot from HD.
Yes a stock A1200 has no fast RAM so the 68020 CPU is somewhat crippled! 13.7MHz = 96MHz/7. 16MHz boots kinda but isn't stable.
Fast RAM makes aout a 25-30% difference on A500 if you're compute bound... if you're pixel pushing bound then it doesn't help as much. Chip RAM is slower to access but also gets blocked by DMA so the CPU has to wait sometimes.
marcusjambler
Post by marcusjambler » Wed May 13, 2020 9:09 pm
=D> Awesome...
I'm definitely interested in one if it works with A500+
Marcus
cmorley
Post by cmorley » Wed May 13, 2020 9:10 pm
There FTFY :)
cmorley
Post by cmorley » Wed May 13, 2020 9:12 pm
I haven't tried it in the 500+ yet but it should work... it is supposed to!
If I knew enough about the ST then it could go in there as well :O
marcusjambler
Post by marcusjambler » Wed May 13, 2020 10:16 pm
Also hoping it will work along side my current 2mb upgrade [-o<
cmorley
Post by cmorley » Wed May 13, 2020 10:20 pm
I put one of my 2MB upgrades on that board (you can see the Gary adapter bypassed in the picture) and it has been runnin Keir's Amiga Test Kit memtest for the past 6 hours while overclocked. So far so good 8)
marcusjambler
Post by marcusjambler » Wed May 13, 2020 10:24 pm
Is that the ribbon cable running south?
cmorley
Post by cmorley » Wed May 13, 2020 10:25 pm
No. The 2MB trapdoor card isn't fitted in the photo. The ribbon cable is the IDE cable going off to a CF adapter. I've also tested it with an SD adapter and a CF to SD card adapter- all work fine :)
trixster
Post by trixster » Thu May 14, 2020 12:43 pm
Any thoughts about a MegAChip clone, chris?
cmorley
Post by cmorley » Thu May 14, 2020 12:47 pm
There's a French guy on amibay who does them tuxbar81 IIRC.
edit: I have wondered about an FPGA 8375 Agnus + RAM now they are getting more expensive.. but that would be a major development effort.
Barnabas
Post by Barnabas » Mon May 18, 2020 9:48 pm
I like the sound of this - I think it would go nicely in the new A500++ board I've recently finished building, so would be interested in one of these for sure :D
cmorley
Post by cmorley » Tue Jun 02, 2020 7:14 pm
My PLCC to DIP adapter PCBs arrived today so I soldered one up and put a 68HC000 into this project.
Adapter jenga:
Obligatory sysinfo screenshot:
Yey success. This CPU runs quite happily at 36MHz in this setup. Quite the speed boost over a 7.1MHz stock A500 :)
I could get a bit more performace out by doing some tuning on the fast RAM. I'm quite pleased with this though as I didn't consider reclocking the CPU at all when I designed the development board. It's allowed me to learn quite a lot about 68000 systems.
Now I need decide what products to make out of all this :shock:
Boydie
Post by Boydie » Mon Jun 15, 2020 11:12 am
Just ordered an A500, so would be interested in one as well.
Probably ought to get a 2MB upgrade as well.
Post by sydney » Mon Jun 15, 2020 11:23 am
How did I miss that update? 36MHz? What speed is the cpu rated at?
cmorley
Post by cmorley » Mon Jun 15, 2020 11:29 am
It is marked as a FN20... what it really is is anyones guess.
Kazzie
Post by Kazzie » Tue Jun 16, 2020 8:42 am
If you feel the need for speed, perhaps "Fast as N2O"? :wink:
RiscPC 600 under repair
Return to “other vintage hardware, software and languages”
