Old copy of CUPL for DOS needed
Ezzio
Post by Ezzio » Wed Mar 14, 2018 8:56 am
Good morning everybody,
I am currently working on programming some old Signetics 82S100/PLS100 PLAs to fix a couple of Commodore computers that I own.
I found a freeware version of WinCUPL, but it doesn't support these older chips. I believe CUPL for DOS is now abandonware and I thought you could perhaps help me locate a copy of this software for DOS, which supports all these old integrated circuits. I saw there was a thread in this forum sometime ago about it.
Any help would be greatly appreciated. Thank you!
Yours,
Ezzio
Re: Old copy of CUPL for DOS needed
Post by BigEd » Wed Mar 14, 2018 10:48 am
I don't know the answer, but I did find this:
https://www.math.purdue.edu/~wilker/mis ... 001/DISK1/
Ezzio
Post by Ezzio » Wed Mar 14, 2018 11:54 am
Thanks, BigEd!
I already downloaded that version and unfortunately it is missing in the CUPL.DL library the 82S100 and PLS100 definitions.
It seems like this copy was, for whatever reason, stripped-down to support only a couple of PALs.
I keep looking...
Post by daveejhitchins » Wed Mar 14, 2018 3:51 pm
@Ezzio
I have a working copy of CUPL (not sure what version! Maybe Phill could let us know?) - tested by Phill (Prime). I Could 'loan' you the disc to make a copy or take an install - see below.
The only thing I'm worried about is it had a limited number of installs! It worked by keeping a count on the disc - IIRC on a track beyond 80! You could install and then uninstall - that would keep the number of installations. The way I got around this was to install it - do an HD image to tape - then uninstall it and recover the HD image from tape. I know Phill's done an install so you should be OK. Maybe there's a way round this today? Anyone any ideas?
It may be worth looking at it using ADI and making a copy with that? I currently don't have a set-up I could use, though.
Ezzio
Post by Ezzio » Wed Mar 14, 2018 3:56 pm
Hi Dave H,
the way around is that you let me have an image of the floppy disks and I return to you a cracked version :D
I enjoy doing reverse engineering, so I can pretty surely deal with this limitation. From the way you described it, the protection seems pretty trivial.
Do you have a chance to make images of the disks you have? That would be awesome!
Yours,
Ezzio
Post by daveejhitchins » Thu Mar 15, 2018 7:45 am
daveejhitchins wrote:@Ezzio
But I could sent you the disc, if you have facilities to image it?
Just PM me your address, if you can image.
