Bonecruncher (Commodore)
geraldholdsworth
Post by geraldholdsworth » Sun Nov 12, 2017 11:10 am
Does anyone have any details of the layout of the Commodore 64 and Amiga versions of Bonecruncher (i.e. where the maps and passwords are located)?
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
sbadger
Re: Bonecruncher (Commodore)
Post by sbadger » Tue Nov 21, 2017 2:48 pm
I have sprites and maps as png for amiga if that helps?
A summer ago I started writing a c# version that you could switch between bbc/c64/amiga graphics, and play with a wider fov, i.e zoom out.
stew
geraldholdsworth
Post by geraldholdsworth » Wed Nov 22, 2017 11:05 am
sbadger wrote:I have sprites and maps as png for amiga if that helps?
Hi Stew,
It may help for one part of what I'm doing, thank you.
I'm actually looking to add the functionality of opening both formats in my Repton Map Display (it already opens the BBC and Electron versions) which, in turn, I can then use to create maps for the Repton Resource Page, which is currently undergoing a major rewrite. In the new look page, the maps are full size resolution and, to save space on storing loads of high-res images, are stored in a CSV file with references into a character atlas. However, there is the functionality to use a PNG map if no CSV and/or character atlas is available.
Gerald.
Gerald Holdsworth
sbadger
Post by sbadger » Wed Nov 29, 2017 2:18 pm
My memory tricked me, the maps are BBC version, though I do have the amiga sprites if you still want them?
geraldholdsworth
Post by geraldholdsworth » Wed Nov 29, 2017 8:50 pm
That would be fabby, thank you. I'm guessing that the maps are the same as the BBC version...although I seem to have 1 less password for the Commodore versions than the Acorn versions.
I'll send you a PM with my email address (can't remember if you had it already)
Gerald Holdsworth
