Epson HX20 - first laptop !EVER! 1981+
Re: Epson HX20 - first laptop !EVER! 1981+
Col,
I'll look out fir another 'bomber' game. Or, I'll just need to re-write parts of the existing BOMBER game to create one. I'd guess that the 'City Bomber' has a similar plane/bomb mechanism, just that the game draws a 'city' on the screen as a target which is then progressively bombed (until the 'people' that live there wave enough white flags?). Prob not TOO different as a program?
You keep saying unkind things about MP3 files. I've loaded some progs from MP3, and they seem to work just as well, in my experience. The HX is concerned merely with what they sound like. I was never bothered with using MP3 because I was always thinking towards the idea of using something like the HXTAPE process, so I could convert sound <--> text, and I always understood that MP3 would be zero use for this. Regarding the WAV files, I've taken the quality of the WAV down pretty low and they still work fine. CD quality is 44k, 16 bit. The HXTAPE processes go down to 8k, 8 bit.
If you've had problems with MP3, may be something else than JUST the fact they're MP3?
Oh, that reminds me. One game I found (originally from Japan think) came as an MP3. Called Jumping Pawns or something like. Uses some UDG (User Defined Graphics (?) characters so if you run the game you may need a total reset? Not quite sure about the rules, either. But the graphics are certainly interesting. Need to find the original version.
Geoff
Geoff
- CMcDougall
- Contact:
hi Geoff,
I meant the ONLY 2x MP3 files I found on net for the HX20 where VERY bad quality, using an old encoder from 1993 when MP3s roughly started, plus the left channel had nothing, only on the right 1/8th volume, where the HX20 NEEDS the left (so does all my many other 8bit machines
don't worry about trying to make / re-make / fix old programs, as never have the time nowadays
(EDIT : found video of Bomber -Simon N Taylor : https://www.youtube.com/watch?v=s7WSqUFdmYE
but if you do come across something good on net, like the HX20 demo program on YouTube, pop it here
(EDIT: https://www.youtube.com/watch?v=atklmnxwTNU : seem he has also lost the prog 9+yrs ago reading the comments
that also goes for the ProWrite ROM image which is also still MIA
Col.
Col.
Col,
I've got a BAS program called HXDEMO, but I'm sure it's not the same as the one in the video. Some of the bits of the demo may be similar, some of the graphics things, sound (?), but there's quite a bit of text, and text printing.
This prog is about 17k in size, so there'll be a problem unless you've got 32k RAM (or 24k with the FORTH ROM active ??).
The prog I have seems to be 'official' EPSON/SEIKO.
Any interest. If it IS too big for your RAM, you could always chop out sections you're not interested in (the text bits and the LPRINT bits?) and keep the more interesting bits (graphics, sound). But of course, just now, it may be too big to load in order to edit?
Regarding the Jumping Pawn game, I've found the original, and it is actually a WAV. There's a 'blog' about someone's recovery of the prog from a tape, which is interesting, plus some comments about the program which you may find interesting
http://www.chrismcovell.com/diary.html
You can d/l the .WAV directly from there if you're interested, but read the comments first.
Geoff
Geoff
Hello Col,
Further to ongoing discussion, have you seen mention of the FLASHX20 system.
Try http://members.aon.at/nkehrer/
This looks very interesting, to attach a PC to your HX and, via the facilities of the PC, provide floppy disks (as per the TF-20) and full monitor access (via a sort of display adaptor/emulator).
I downloaded the system to try, but it does not work for me. BUT I'm pretty sure this is merely because there's something 'broken' with the High Speed connector in my HX, and this is why the link to my TF-20 also does not communicate. Hopefully, the system will work for you?
Geoff
Geoff
- CMcDougall
- Contact:
^not had a chance to play with that Geoff... & totally forgot how to use it, But!
... just found another CM6000, this time with a Expansion Unit, dated 14Dec1993 (battery install date) & since 4 years younger than the other one, the battery was only white dust, and did not kill the screen ribbon or the +/- lines, but was Very close
without expansion on, i first got "CONFIG ROM MISSING" (after probably 20yrs not on!
2nd time I get "HALT 42 62 6102"
Nigel / 'Pernod' will get these different roms imaged once I get a beeb setup to do it
board very different, with no 4xRAM chips, now a single RAM on a carrier board and wires going to pads /chip legs on MB
Thanks, will take a look at the ROMs when available. The other one had 8x2K RAM whereas this has a single 32K RAM, seems odd that an earlier version would have double the RAM.CMcDougall wrote: ↑Wed Jun 05, 2019 10:26 pmNigel / 'Pernod' will get these different roms imaged once I get a beeb setup to do it![]()
board very different, with no 4xRAM chips, now a single RAM on a carrier board and wires going to pads /chip legs on MB![]()
I took another look at the emulation awhile ago and it seems the CPU needs more work, the dual processor configuration is not yet implemented.
- CMcDougall
- Contact:
more pics & what it 'does', never found any manuals for this at all, the people who used this 1989 to 1995?? probably all dead
as you can see, it sat doing nothing with the cables /tape boxes on it getting a tan for 5yr?? then sat in a dark cupboard never entered for 20yr
note the different fKey strip on top...
so after switch on, it gives 3 beeps, then the picture of the Telephone & wee man
as per older machine .
pressing :
F1 = CHECK OUT , ROOM ?_
F2 = ROOM ENQUIRY, ROOM?_
F3 = NO ROOM TABLE
F5 = >5/89/69 ;>;;1{
shift F1 = ADMIN CALLS, 1 STORAGE LEVELS, 2 REPORTS , _
shift f2 = EXTNSION TABLES, 1 GUEST TELEPHONES, 2 KIOSK TELEPHONES, 3 ADMIN TELEPHONES, _
shift f3 = 1 COST 5 NAME, 2 TRUNKS 6 PABX, 3 PASSWORD 7 IMMED, 4 PRIVACE 8 MODE _
shift f4 = DEVICE, 1 PRINTER, 2 CASSETTE, _
shift f5 = 1 DIAGNOSTICS, 2 TERMINAL MODE, _
the expansion part that is needed to get above, or it just beeps & says "CFG ROM?" also found the adaptor, but it has the wrong plug on end, so useless
it spits out 9.3V with no load on it.
pressing :
F3 = NO ROOM TABLE
- CMcDougall
- Contact:
I blew some 128/16k eproms again as per last time to turn it back into a usable machine, and its now ok, all keys work
again putting them in HX20 & now also in expansion add on
when 16k rom FF for first 0-1FFF then 2000+SkiWriter
& FF for first 0-1FFF then 2000+Forth
in expansion rom sockets, 13B = FF+Skiwriter, 14B = FF+Forth
after putting in the date & time, and reset, it then shows on screen:
1 MONITOR
2 FORTH
3 BASIC
4 SkiWriter (TM)
original 4x16k eproms below for archive :
1 MONITOR
2 FORTH
3 BASIC
4 SkiWriter (TM)
- Attachments
- 13B-CM6127H-3 v1dot6(expansion.rom
- expansion 13B left
- (16 KiB) Downloaded 49 times
- 15E-CM6127H-2 v1dot6.rom
- MB rom0 right
- (16 KiB) Downloaded 48 times
- 13E-CM6127H-1 v1dot6.rom
- MB rom2 left
- (16 KiB) Downloaded 47 times
- 14B-CM6127H-4 v1dot6.rom
- expansion 14B right
- (16 KiB) Downloaded 51 times
Thanks for those. Since there's 64K of ROM I suspect the expansion unit introduces some banking. The top 8K of ROMs 15E and 13B are identical, suggesting 13E/15E are somehow switched with 14B/13B. The HX20 and expansion unit both have their own 32K RAM too, suggesting that maybe the whole ROM/RAM is switched between HX20 and expansion unit.
Did you need to put your custom ROMs in the expansion unit, shouldn't they just work from the HX20?
- CMcDougall
- Contact:
thanks for looking into this now again 'new' HX20 setup Nigel
I tried with 'FF & SkiWriter' on just the motherboard (rom4 /11E socket) without the expansion connected, but it did not show ... BUT
can try again as completly forgot about the setting Date/Time thing first
need to have the power off for a good 5mins before its memory is cleared, as it still remembers its settings
& even basic prog with no batterys at all (and USB 5v mobile adaptor unplugged)
I suspect only sockets 13E and 15E are valid options.CMcDougall wrote: ↑Sun Jun 09, 2019 7:31 pmI tried with 'FF & SkiWriter' on just the motherboard (rom4 /11E socket) without the expansion connected, but it did not show ... BUT
can try again as completly forgot about the setting Date/Time thing firstso it *may* work.
That'll be the CMOS RAM, 32K on each of those carrier boards.CMcDougall wrote: ↑Sun Jun 09, 2019 7:31 pmneed to have the power off for a good 5mins before its memory is cleared, as it still remembers its settings
& even basic prog with no batterys at all (and USB 5v mobile adaptor unplugged)![]()
- CMcDougall
- Contact:
hi again Geoff, yes that worked !
had to press any key about 12 times until it hit the target
is there a left /right key?? tried most keys but that just drops the bomb....
Did you scan your Forth language manual, or a even just a photo of the page so I can use MONITOR to edit a byte so that it runs correctly ?
Cheers, Col.
- 1024MAK
- Contact:
That AC/DC adaptor is most likely an unregulated type (a transformer, rectifier and smoothing capacitor), hence with no load the output voltage will be a lot higher than the voltage it’s rated at.CMcDougall wrote: ↑Sun Jun 09, 2019 11:27 amalso found the adaptor, but it has the wrong plug on end, so useless![]()
- CMcDougall
- Contact:
yip, can see a resistor & a 16v 1000uF cap.
but, the wrong plug, just found another one being the right plug for HX20,
So, wonder what 'CM Buffer power unit' is for with mono earphone plug on it ?? external printer or the disc drive Rare unit or scanner
Edit: pic up as £7 mobby crap
EDIT2: better pic
- CMcDougall
- Contact:
another rummage before skip, & found it!
a search on Google gives no clues at all, some kind of Modem perhaps??
baud rate going by switch settings is 1200baud...
pics :
Maybe a serial printer buffer? It contains a CPU, ROM, and 32K RAM so there's a runnable machine there. ROM dump?CMcDougall wrote: ↑Mon Jun 17, 2019 8:46 pma search on Google gives no clues at all, some kind of Modem perhaps??![]()
pics :
- 1024MAK
- Contact:
It could be a MODEM maximiser, that is, a speed changer. This would allow the computer and the MODEM to operate at different speeds, while the buffer, err, buffers the data...
- CMcDougall
- Contact:
just checked this, and the 16k eprom was read at 8k,
not as 16k
or my beeb just things it's a rubbish machine
knew you would ask that! this time it's only a 8k/64 eprom, as peeled back sticker to confirm
code gives no clues (to me) what its for....
I powered it on from the original EPSON 9v 600mah adaptor, the PWR light came on
- Attachments
- CMbuffer.rom
- 8k CallSafe V5.2
- (8 KiB) Downloaded 35 times
Thanks, I thought it was intentional, ie. you could swap between internal/extension ROMs, so top of each set would contain vectors.CMcDougall wrote: ↑Tue Jun 18, 2019 9:15 pmjust checked this, and the 16k eprom was read at 8k,
not as 16ksure one of the other machine roms did that too, maybe the rom code tricks the beeb prommer to think its 8k,
or my beeb just things it's a rubbish machineanyways, re upped the now full 16k from a beeb socket again to force it
Thanks again. It's definitely a 32K buffer for a modem. Won't be able to get this to do anything useful in emulation, but at least it'll document the ROM and the hardware.CMcDougall wrote: ↑Tue Jun 18, 2019 9:15 pmknew you would ask that! this time it's only a 8k/64 eprom, as peeled back sticker to confirm
code gives no clues (to me) what its for....![]()
I powered it on from the original EPSON 9v 600mah adaptor, the PWR light came on![]()
Hi everyone. Total newbie here.
I unfortunately do not own a Epson HX20 but I am trying to see how it works via an emulator.
I've tried with the eHC-20 emulator but can't make the roms that I have to work with it. I know HXEmu can do it too, but would like to try eHC-20 first.
Can anyone point me in the right direction here? Thanks!
- marcusjambler
- Contact:
New toy!! I wasnt expecting it to work since It did so badly on the auction...
Actually its immaculate
Even the battery 'looks' unused. It came with the Epson case and a print out of some BASIC programs.
Marcus
Marcus
- CMcDougall
- Contact:
^ yes Marcus, lookin good as no change of blue colours on the LCD ribbon, so no powdery rust has crept to it!
When you cut the battery lead off, both mine had no good shiny copper within, just black due to battery corrosion, even right upto the plug 1cm away....
no tape deck? nice... now get those games typed in and saved off to laptop as .WAV files & uploaded!!
- marcusjambler
- Contact:
Cheers Col
So, the print-outs.. They're not games.
Definitely work related and possibly code to work out signal processing filter values...
Anyway, I'll type them in... Can you/someone point me to the manual for exporting programs out the sound socket
Marcus
That was lucky!!no change of blue colours on the LCD ribbon, so no powdery rust has crept to it!
Marcus
Hello Marcus,
Maybe you've tried the save now, and it worked OK.
You need a couple of mini (3.5mm) jack leads, and connect like to like to your laptop. The sockets on the HX indicate the destination, so it's mic on the HX to mic on the laptop.
I used the SOUNDRECORDER application on my laptop, quick and easy, part of W7, but other versions have things too. If you want to be fancy you could mess with a full blown audio system, I've heard of some using Audactity. One little problem with SRec is that you need to tell it to save as WAV, but once that's set it's no problem, I found.
I just used Media Player to 'play' the WAV to LOAD back to the HX.
I fiddled a lot with the HXTAPE application (code in PHP) to translate the WAV to TXT, and back, to allow reading of the saved files, but this is rather more of a fiddle. But I did (with a lot of help from the code originator in Italy) get it working, which allowed loading of some code from listings on the web back into the HX.
Oh, the manual command you need to save is SAVE "CAS1:NAME.EXE",A
The NAME.EXE is saved as part of the saved file, and MUST be matched later when you LOAD. The ,A is to save as ASCII rather than encoded BASIC, and is optional, but saves some messing if you try to do anything re the HXTAPE stuff.
Geoff
Geoff
- DutchAcorn
- Contact:
Has anyone successfully installed this in a regular HX-20? I have burned the image in a 16K EPROM (repeated 0-2000H and 2000-4000H) and installed it in 11E/ROM4, then re-initialised the HX-20 but without success: it does not show in the menu?
- CMcDougall
- Contact:
/\ works in my two, now that they are back to 'original'
You may have to do the Date set thing first, then have to go into Basic first, then into SkyWriter.
It does ask to go into Basic first if you don't
See pics here near start of this thread, to show what you should get :
viewtopic.php?f=45&t=13893#p183342
- DutchAcorn
- Contact:
Yes, did the "Date set thing" (ctrl-@), now tried with an 8K EPROM as well. Also tried keeping battery disconnected for 5 minutes.CMcDougall wrote: ↑Sun Mar 22, 2020 11:09 am/\ works in my two, now that they are back to 'original'
I can't seem to find the rom dump that Pernod posted as part of your 16K ROM dumps. The "SkiWriter (TM)" string is nowhere to be found in your rom dumps, bit mystified here.
- CMcDougall
- Contact:
/\ it defo had SkyWriter txt at start of rom. Will upload mine after 8pm when lappy on /kids bed.
I did use a 27128 (16k) rom, with FF in first &2000 then the 8k rom, got it in the depths of net, where I got the old right channel only MP3s that needed to be on left channel to load..... can't even remember how I got there!
- CMcDougall
- Contact:
as mine is still not 'original' off shelf, I had to use the 16k eprom
yours won't, should be a 2764 8k rom, which should go in rom slot4 (near dip switch thing for DOS)- Attachments
- skiWriter.rom
- 8k rom slot4
- (8 KiB) Downloaded 34 times
- DutchAcorn
- Contact:
Thanks for that, Col. Somehow my HX-20 does not seem to read ROM4. If I put the skiwriter rom in socket 12E it does show up in the menu.
One detail; it has a 16K internal expansion.
