^sure was
after all this time to solder it up to work & the 'new' 16k roms burning, I noticed the Return key not registering until 3 presses
so took keyboard to bits a little:
- keySwitches
so the little shaped metal thing was not very good after all these years, so after 6+ different positions
i then got it to beep on my multimeter tester
, put all back together, still did not work
so on close inspection of solder side of the 2pins, it had dry solder joint on one, and could move up/down
soldered on some more, all Working again
pics of Micro Cassette Drive:
- deck10pin
- deck back
interface connector 40pins:
- interface40pin
RS232 lead maybe for it, black left is shielding on right plug to no pins:
- lead
to get this machine to use Ear /Mic on right side of it, need to take tape deck aside/out & do a reset.
here is a little basic prog to load, use laptop volume at 66% to play out
the first 4.5 seconds are not needed , nor the last 6 seconds, as probably just lead in/out
- the WAV
I found two crap MP3s from years back on the WWW, but had to do a bit of fixing, and loaded some progs being:
STATPAK, FUTURE, DAYDATE, AMORTIZE, TENKEY, PHONE, HANDLER, TIMER, & WRITER (11mins total)
have then saved them back out, so if anyone wants them (or interested at all?
) just shout
& AND if anyone can supply more .WAVs of basic progs, especially
City Bomber
let me know !!
