ICE T65/Z80/6809
Tom swift
Re: ICE T65/Z80/6809
Post by Tom swift » Tue Jul 21, 2020 8:46 am
bprosman wrote:
Tue Jul 21, 2020 8:40 am
What do you mean by :
I just can't nudge it. I hacked together pins for the DIP. I'll make it right when I get those PreciDips in.
heh... I used 2 40-pin male single row right angle pin headers and shaved the pins down a bit so a machine pin 40-pin DIP can fit onto them for stability. Turns out it wasn't so stable. Oh, I didn't use your adapter for this one. I soldered the pins directly to the GODIL.
Aww... so Trenz got back to me and said that is the only model they make. All well. Shame. I really like the small footprint of it.
fraido
Post by fraido » Fri Aug 21, 2020 2:36 pm
Hi, i'm looking for a Z80 ICE and i found this awesome project! Simply amazing!
But i need some help and hints with the FPGA board, at the moment the GODIL seems to be still available but it could suffer of some compatibility issues due to its strong pullups and level shifters, is it right?
https://shop.trenz-electronic.de/en/Pro ... nik/GODIL/
Instead the XC6SLX9 "eepizza" boards seems not to be available anymore. Is there on the web a good working board?
Could this board will be good?
https://www.aliexpress.com/i/4000035732305.html
16Mbit NVRAM/FLASH could be enough to store the configuration?
I need the ICE to debug old arcade PCB boards, mainly Z80 CPUs but 6809 too.
Can you help me choosing the right hardware? Thanks for your support.
Post by hoglet » Fri Aug 21, 2020 4:45 pm
Correct - it depends on the design of the target system.
If the data bus is "split" with resistors (like on the Spectrum) that is problematic.
Sorry, I'm not aware of any kind of replacement at present.
Nor is anyone actively working on cloning the EEPIZZA at present.
You would need to get a pinout of the connectors. Positioning of the power/ground pins is critical.
Also, you need to check if the USB connector is power only, or whether there is a UART.
That's enough space for ~6 designs, so you could just about fit a useful multiboot configuration in there.
Sorry, there isn't a good answer at the moment...
bprosman
Post by bprosman » Sun Aug 23, 2020 12:29 pm
Unfortunately too many issues with my son going on that require attention as well as my living room is a construction site :?
Ordered one of these to see how far the are off the EEPizza board.
Issue is that there might be replacement boards available but you don't have control over the availability / continuity of the supply. So you might end up designing "buffer boards" , every time a board becomes unavailable, or you could stack an (extra) adapter in between.
bprosman
Post by bprosman » Mon Sep 07, 2020 11:15 am
Got the boards in, of course they are a bit off the EEPizza board.
Unfortunately the Micro USB does not have a UART connected, of course it is possible to have this connected to the FPGA pins via a TTL (3V3) - USB adapter.
Attached the schematics and layout of the board, hopefully Hoglet can say something about it as he has way more knowledge about this than I have.
The board has a +5V connection on the connector.
Schematics :
SPARTAN-6_FPGA_S602_V12_SCH.pdf
(131 KiB) Downloaded 7 times
Board Layout :
S602 Board Layout.pdf
(53.05 KiB) Downloaded 6 times
This is where I ordered them :
https://nl.aliexpress.com/item/4000035732305.html
JannievanZyl
Post by JannievanZyl » Wed Sep 09, 2020 9:42 am
My timing was terrible with this :)
I ordered the EEPizza with all the bits and at the same time ordered the ICE PCBs (5 of each CPU type).
Order was accepted and paid, but never arrived and EEPizza went offline (seriously hope they're OK...) but the PCBs arrived within a few days.
So, now I'm all dressed up and nowhere to go as the saying goes... :(
bprosman
Post by bprosman » Wed Sep 09, 2020 5:00 pm
Hope that David/Hoglet can/will share his view on this latest board. That seems to be available more widely on AliExpress as a S602 board.
Post by hoglet » Wed Sep 09, 2020 5:16 pm
I'm sure I'm stating the obvious here, but it's defintely not compatible with the existing CPU adapter boards, and it doesn't have a USB UART, which is a show stopper for me.
If I was planning to re-design the CPU adapter board (which I currently have no plans to do), I don't think I would pick this board.
There are a few options I would consider:
1. Cloning the eepizza board
2. Switching to the DE0 Nano (expensive, and would require work to the FPGA designs to produce an Altera version)
3. Switching to the Mojo V3 (a widely available Spartan 6 board)
4. Switching to a Spartan 7 board (like the QMTECH XC7S15)
None of these are ideal, and all involve quite a lot of work.
bprosman
Post by bprosman » Wed Sep 09, 2020 9:58 pm
Seems to be retired as well (atSparkFun) but maybe there are other sources.
I agree designing your own board gives the most flexibility (independency).
Regards, Bram
JannievanZyl
Post by JannievanZyl » Fri Sep 11, 2020 10:34 pm
So...if anyone has a spare eepizza board to go, I'm happy to trade for really good South African red wine or equivalent. :)
But seriously, I really would like to get this ICE going but would need to get the original parts, don't have enough knowledge to redo the work done by others. :)
bprosman
Post by bprosman » Sat Sep 12, 2020 8:12 am
Let me see what I can do with this board. The lack of a serial port shouldt be the end of the world, in the end the original Godil didnt have one either and needed a serial level shifter.
JannievanZyl
Post by JannievanZyl » Sat Sep 12, 2020 9:49 am
Thanks Bram! :D
